Jentec AF1205-E
  • sebr
    • Oct 2010
    • 79
    Jentec AF1205-E
    This is a 5V / 2A PSU from a D-Link Switch. The outpult voltage is oscillating and causes only the switch power led to blink. The switch itself is fine since I tested with another PSU.
    A picture of the PSU can be found here
    All caps tested fine in terms of capacitance and ESR. I'm clueless - what could be the problem here?
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: Jentec AF1205-E
    Load it with a 2.5 ohm, 10W or better resistor. Yes, a 10W will become rather hot, but it's only for a short testing period.
    Replace the two small black caps by the opto.
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
    • sebr
      • Oct 2010
      • 79
      Re: Jentec AF1205-E
      As I plan to keep this switch I did a full recap (excluding the main cap) on this PSU and re-soldered the whole board but still no luck, same symptoms. Fuse wasn't / isn't blown.
        • 31068
        Re: Jentec AF1205-E
        try replacing the opto isolator and the current-source.
        that's the thing that looks like a transistor and has a part number probably ending in "431"
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Re: Jentec AF1205-E
          Also check primary side auxiliary rail diode - this is what gives power to the switch/PWM-FET/controller on the primary side. If not sure where that is, post pictures of the bottom side of the power supply. Please attache them to badcaps.net vs. going to off-site hosting service.
          • sebr
            • Oct 2010
            • 79
            Re: Jentec AF1205-E
            Well I have tested all the diodes and none of them is shorted or open in both directions.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Re: Jentec AF1205-E
              Check the voltage on the cathode of D3 - does it oscillate too? (Also, keep in mind this is the primary side, so that voltage measurement will have to be done with respect to primary ground). If the voltage is oscillating there too, replace those two small caps by the optocoupler, regardless of what their ESR shows, especially if they are of some unknown or bad brand.
              Also check ZD1 and ZD2 are not shorted. And replace the 431 shunt if not - those are fairly common parts and should be easy to find.
              • sebr
                • Oct 2010
                • 79
                Re: Jentec AF1205-E
                Thanks for your quick reply. Well as I wrote before I already did a complete recap (except pimary cap) so I gonna skip measuring on primary side.
                ZD1 and ZD2 are not shorted either. The resistors on secondary measure fine as well.
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  Re: Jentec AF1205-E
                  I guess that doesn't leave much stuff to check now.
                  Okay, I was just making sure. I've just seen people mention they do a full recap and then forgo to replace some of the important small caps. So you are good there .
                  Well, actually do it anyways. That voltage on the cathode of D3 needs to be stable for that small chip to function.
                  After that, you only have solder joints and that 431 shunt to worry about.
                  Perhaps also check the transformer windings. They will appear as a short circuit, but that's fine. We just want to check none are open. On the primary side of the traffo, there are two windings, but they should be separate from each other.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4973
                    • New Zealand
                    Re: Jentec AF1205-E
                    Is the primary controller a Fairchild PowerSwitch IC with integrated FET?
                    I had a power cycling PSU in a network switch, after checking *everything* else, it turned out the FPS IC was bad. Replacing it fixed the PSU. I had to use a newer, RoHS version as the original was EOL. Datasheets were practically identical otherwise.
                    -David VanHorn
                    • kaboom
                      "Oh, Grouchy!"
                      • Jan 2011
                      • 2507
                      Re: Jentec AF1205-E
                      That teeny IC, IC1, on the back of the board, is the SMPS controller. It's like a super-tiny 3842, but otherwise works/does the same.
                      EOL it...
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4973
                        • New Zealand
                        Re: Jentec AF1205-E
                        Ahh! On a quick look I did not notice it...
                        -David VanHorn
                        • Behemot
                          • 4845
                          • CZ
                          Re: Jentec AF1205-E
                          If everyting else was checked or replaced, that really only leaves the driving IC or transformer.
                            Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                            This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-06-2024, 05:30 AM
                          • Natob82
                            Micro Momentary Push Switch?
                            by Natob82
                            Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                            12-21-2022, 05:22 AM
                          • grimacelord
                            NEC TurboExpress On/Off Power Switch Replacement Help
                            by grimacelord
                            I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                            I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                            I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                            11-09-2023, 09:49 AM
                          • SluggerB
                            Help making a switch work the opposite way with a relay
                            by SluggerB
                            I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                            I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                            It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                            02-07-2025, 07:57 PM
                            Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
                            by sam_sam_sam
                            Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
                            ( needs more cam circuits for the machine to work correctly again )
                            https://www.ebay.com/itm/275321870186
                            To
                            3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
                            ( not 4 positions but the right amount of cams circuits )
                            https://www.ebay.com/itm/274660439950
                            I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
                            03-18-2023, 05:12 PM
