MS Industrial 400W PSU issues
  • gamebox
    • Oct 2014
    • 5
    • Serbia
    Hello all.
    I need some advice on "moody" MS Industrial "GOLD MS-400ATX P4" PSU. It is about 7 years old, bought second-hand so I don't know it's history, bottom intake (12cm fan), ratings and pictures below.
    I've tried it with my system (67W TDP Athlon64 with low consumption GPU (Radeon HD4350), 2x1 GB DDR400 ram, 80GB IDE hard drive and 3 mostly idle IDE optical units). It worked fine for about a day and then the computer started switching off by itself in irregular intervals (in use or even when booting - it behaves as if a power supply cord was pulled off). 12V rail sags to about 11.5V in use. Another PSU (KME 350W) runs that system fine 24/7 sagging to about 11.7V, but it has 16A on 12V rail instead of 14A of MS Industrial.
    In another system which presumably puts load on different rails (it's the older 66W TDP Pentium4 with AGP GeForce4 MX440, 2x512 MB DDR400 ram, 12GB IDE hard drive, idle CD-ROM unit) the PSU works well and mostly has no stability issues in use. But, the only exception is when the monitor (17" LG T710BH CRT unit) is switched on - the large starting current pulled by demagnetization coil causes a minor voltage sag on all nearby devices, and the computer (sort of) freezes then. It doesn't switch off and doesn't reboot; it remains on but HDD and CD-ROM activity LEDs light up constantly for a few seconds, the fans slow down for a short while (judging by the sound), and the system remains somewhat frozen (no video output/signal from that point on, no ethernet traffic etc.).
    No capacitors are obviously bad, swollen or leaked inside the PSU. Input ones are HEC 470u 200V, the output ones are JEE (2200u 16V (I presume for 12V rail), the others are a pair of 1000u 10V and a pair of 2200u 10V). No unusual sounds, smells or obvious overheating. One of HEC input capacitors seems somewhat different - not exactly swollen (it is flat on top) but not perfectly "flat" between the three ridges on top surface (it might be visible on photos) - though I've seen many caps looking like that and working just fine, so I came to a conclusion that it could be the metal-forming imperfection. The plug on the bottom of that cap is not forced out either, and there is no evidence of leaking below. It is the one with red marking on top.
    Thanks in advance for any kind of help.
    Pictures:
    http://postimg.org/image/4s139x6it/
    http://postimg.org/image/5iukdjqdr/
    http://postimg.org/image/m6eg2rvpx/
    http://postimg.org/image/mua7a2sod/
    • 31281
    Re: MS Industrial 400W PSU issues
    what's the 5v standby voltage first?
    and bad caps dont always leak or burst.
    • gamebox
      • Oct 2014
      • 5
      • Serbia
      @stj
      Just tested it for a few minutes with Hardware monitor:
      3.3V : 3.22 to 3.33V
      5V : 4.30 to 4.35V
      12V : 12.03 to 12.22V
      5V VCCH : 1.13 to 5.67V
      Confirmed - during EVERY CRT monitor switch-on (demagnetization coil current surge) the system "freezes" and shuts off video signal, often even with the hard drive parking its heads and spinning down. Once the system even rebooted as a result of heavy HDD use, but that never happened so far (the system is in use for over a month).
        • 31281
        5v vcch ? if that's the standby then it's fucked!!!
        infact all the 5v is fucked......
        you need to look a lot closer at the caps starting with the 5v standby line.
        AND DONT CONNECT IT TO A COMPUTER AGAIN!!!
        • gamebox
          • Oct 2014
          • 5
          • Serbia
          @stj Yes, it is probably the standby indicator. In my system powered by KME 350W 5VCCH holds steady at 5.03V.
          The 5V rail of that thing might be overloaded, and 12V remaining stable as it sees little or no load at all. The situation was quite different in my system - 12V sagged to 11.5V with that PSU.
          Do you (or anyone else) recognize the layout and components from the pictures - I guess it is some generic brand? Perhaps I could then read more about that model's flaws, failures and construction... No caps seem strange or bulged on low voltage side. The bigger brown ones on the lower-right side picture, whose values I listed, are probably for "regular" outputs (12V, 5V and 3.3V). Then, small black ones above them could be in the "standby" circuit. I'll obviously have to disassemble the unit again, taking the pcb off this time too... I guessed the input electrolytes were to blame, but obviously it isn't so...
            • 31281
            the 5v standby caps are probably the 2 to the right of the power wires.
            you need to wait for one of the pc psu guys - they will probably recognise the board.
            • lti
              • May 2011
              • 2557
              You should check voltages with a multimeter, not software. Software voltage readings can be completely wrong, like saying that the voltage on the 12V rail is 2V. Since the other PSU gives more stable voltage readings in that program, I would say that this PSU does need repaired, but I don't think the computer would be running as well as it is if that software was accurate.
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                Bios voltage sensors are completely unreliable.
                Judging from the pics, it can do 250W max.
                • gamebox
                  • Oct 2014
                  • 5
                  • Serbia
                  Standby voltage without load is 5.09V, measured with a multimeter. Sadly, I couldn't keep the PSU running while disconnected from the board - I just managed to switch it on by pulling PS_ON to ground, but after a split second it would stop running - I probably need to do something else there too, but I hope this measurement might prove useful.
                  @goodpsusearch It is a low power PSU, no doubt. Ampere ratings on 3.3 and 5 volt lines are about half of those of my KME 350W. God knows what the number 400 means on this one, when even the sticker says combined output on 3.3 and 5V is about 150 W. However, both of my computers are low power, so rating should not be critical. Perhaps though it's not quite enough for my (low consumption) Athlon64 system which draws heavily from 12V, though I would like a bottom-intake super-silent PSU for that system rather than the Pentium4 one which sees less use.
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    Attach a hard drive or an old CD/DVD-Rom and try again.
                      • 31281
                      looking at the state of it,
                      i'd either do atotal (including all small caps) recap with panasonic FR & FK or bin it.
                      • goodpsusearch
                        • Oct 2009
                        • 2850
                        • Greece
                        It's not worth so expensive caps. I would recap it with Teapo, OST and Taicon from dead psus, lube the fan and make sure it keeps the psu cool enough to do its real watts without overheating and the caps not get cooked.
                          • 31281
                          well i only buy FC,FR & FK
                          FK are very expensive it's true, but FR are very cheap for some reason, cheaper than ruby YXF.
                          • goodpsusearch
                            • Oct 2009
                            • 2850
                            • Greece
                            FR are cheaper than FK/FM/FC indeed. I use them in psus even though their esr is a bit too low for that application.
                            • gretti
                              MSI Z370-A Pro, works but does not power off or reboot and USB issues
                              by gretti
                              I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
                              The MSI BIOS included the ME firmware for the board. The size...
                              10-16-2025, 02:14 AM
                            • SoulFreeze
                              Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                              by SoulFreeze
                              Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                              After repairing the above issue, I realized the following remaining problem,
                              Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                              The computer recognizes headphones are connected and displays a popup in windows
                              Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                              06-21-2025, 09:53 AM
                            • Nagyesz
                              Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
                              by Nagyesz
                              I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
                              All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
                              How can I extend its lifespan? Could reflow help?
                              It has ryzen 5 5500h, rtx 2050, no soldered ram.
                              Example of the artifacts:
                              03-01-2025, 11:11 AM
                            • pwnjuice
                              Bitlocker issues
                              by pwnjuice
                              Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
                              Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
                              Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
                              01-06-2025, 05:33 PM
                            • Skgod
                              Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu
                              by Skgod
                              Hey I am having Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu. Works fine when I open any game or whatsapp windows application. The issues are :
                              Black screen, freeze
                              The weird thing is that when as long as the laptop is running on igpu the problem keeps happening. But as soon as I open any game or whatsapp windows application, the laptop works completely fine.
                              When the screen freeze or black screen I used to move the display lid up and down and it usually works like that.
                              So can anyone tell me what would be the possible cause?...
                              10-16-2024, 08:11 PM
