RC battery charger - Not sure where to start *HELP*
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: RC battery charger - Not sure where to start *HELP*
    Hey that ws almost confusing for a while the pg number is almost the same as the part which might be one of these
    http://html.alldatasheet.com/html-pd.../1/L5973D.html
    If the consensus is that that is what it is they are here
    http://www.digikey.co.uk/product-det...6-5-ND/1663375
    EDIT Drat there is also a A5973D and a B5973D I dont suppose the first digits are visible to you? They are indicated to be for automotive use but I have not studied the differences
    • gatewayhd2201
      • Jan 2014
      • 53
      • united states
      and there's an L5973D which I was linked to by the person who was helping me figure all of this on Reddit
      https://cdn.badcaps-static.com/pdfs/...e70fdb3f09.pdf
      http://www.reddit.com/r/AskElectroni...is_not/clxbny4
      EDIT: selldoor you did mention the L5973D in you first post, sorry didn't notice it.
      Are these things easily replaceable? I have this Weller soldering iron http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
        • 31246
        if it's the L5973 you need a hot air system because there is a big pad under the chip than acts as a heatsink.
        • gatewayhd2201
          • Jan 2014
          • 53
          • united states
          I have this http://www.harborfreight.com/1500-wa...UwIn0%3D%0D%0A
          Or will it be too big and generate too much heat?
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            Can you snip the legs lift the body then unsolder the feet one at a time?
            • gatewayhd2201
              • Jan 2014
              • 53
              • united states
              #26
              I don't have anything that small to snip the legs, its very tight. If I press the soldering iron on the body wouldn't it melt the pad under it?
                • 31246
                you can desolder the legs by using an iron to melt the solder, then lifting the leg with a needle or a bent safetypin.
                if you get all 7 unburned legs up, you *may* get enough heat through the chip but i doubt it because that the whole point of the heat pad under it.
                your hot air gun seems too hot also.
                what may be possible is to melt the solder by heating the pad on the other side of the board,
                or using the iron with a bit of fresh solder on the exposed section of the pad at the end of the chip in the foto.
                all this leads to another question though, how are you going to put the new chip on???
                • gatewayhd2201
                  • Jan 2014
                  • 53
                  • united states
                  #28
                  No freakin idea!!!!
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    There might be pads going to the other side of the board. Those are likely for thermal transfer, however they could be functional in the circuit also. But you probably could heat those up and melt the solder under the chip. It will probably take a lot of heat though, as it was designed to do that :P
                    Muh-soggy-knee
                    • Iceberg86300
                      • Mar 2017
                      Did you ever get this sorted out?
                      I have a HYPERION 720i NET that looks to have fried the she component. Possible also a 5v linear regulator, and whatever the black rectangle marked 3110-5260.
                      Looks like graupner was doing the design/manufacture for Hyperion, or vice versa.
                      Now it looks like the "old" Hyperion has gone full graupner. All previous units appear NLA, with only one new model which looks to be a rebrand.
                      I'd really like to fix this one as their new model isn't compatible with the rich software suite.
                        NVDC charger configuration...
                        11-05-2024, 03:28 PM
                        ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                        Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                        The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                        for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                        Narrow VDC applications where the system power source is
                        either the battery pack or the regulated output of the charger.
                        This makes the max voltage to the system equal to the max
                        battery voltage instead of the max adapter voltage. Operating
                        at lower system voltage can improve...
                        11-05-2024, 04:43 PM
                      • flat-earther
                        how to prevent a connected charger from draining battery when not charging?
                        by flat-earther
                        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                        So the battery is backfeeding the charger and being drained.
                        How can I prevent...
                        08-07-2025, 01:04 PM
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                        Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
                        I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
                        So I have put them on the battery testing machine to drain each battery cell down to...
                        09-04-2022, 04:45 PM
