DEll laptop charger full of plastic
  • sparker1
    • Sep 2011
    • 343
    This is a rant that I thought I would share. I have a dell charger that wasn't working - only putting out an unsteady 0.14v but the charger light is nice and bright so I was thinking it was a cord problem. I took it apart and was astonished to find it had been absolutely filled with "stuff". It has been gooped over all the circuit. That makes it impossible to examine it without going mining and possibly damaging components since you can't see what's underneath the "stuff". It is a proprietary brand charger but Dell should be ashamed of the careless manner it's been put together. Is there a need for all that insulation or whatever it is?
    Edit: and yes, it was a cord problem.
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    Re: DEll laptop charger full of plastic
    Is this actually made by Dell ? I have never seen a powersupply made by Dell looking like that inside.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      Dell doesn't make power supplies. OEMs build them for Dell. I have 3 identical Dell adapters (in terms of power ratings), and all 3 have different OEMs and different power cords at the end that plugs into the charger.
      I've seen that white caulk in a lot of genuine power bricks, and indeed, it is a royal pain to remove. The "replacement" aka knock-off ones just use hot glue instead, or no glue at all.
      A working TV? How boring!
      • kasfamily
        • Aug 2014
        • 774
        • Russia
        If desired, the material may be removed, must be carefully and the time needed to dig the tip of the blade, items without damaging, in particular SMD components.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          I have seen this a few times especially in detla power bricks doesn't do any harm and is a pain to remove, also it does transfer some heat away from the components.
          • PeteS in CA
            • Aug 2005
            • 3581
            • USA, Unsure of Planet
            The goop also helps with resistance to shock and vibration. Adapters like that probably get dropped and kicked around a lot if the laptop is carried around much.
            PeteS in CA
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Someone at the factory must have been watching too much porn before going to their shift
              Yeah, I've seen both Delta and LiteON power adapters littered with that white silicone stuff. Fortunately, most of the problems with those IS a power cord issue - either shorted or open.
              • kasfamily
                • Aug 2014
                • 774
                • Russia
                Even with such a dense filling, if dropped or bumped adapter often break off the wire chokes filters.
                • BTubbs200
                  Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                  by BTubbs200
                  Dell Latitude 5420 P137G
                  Board: LA-K491P REV A01
                  I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                  Board seems to have no shorts, all power rails are fine and show high resistance.
                  When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                  01-24-2025, 08:15 PM
                • Johndill
                  Dell Inspiron 7567 LA-D993P odd charger issue
                  by Johndill
                  Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                  There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                  I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                  Here are the tested scenarios:
                  1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                  2. With the laptop off, plug in charger (LED says on) & the front charging...
                  11-16-2022, 10:55 PM
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • PowerAmpFreak
                  Dell Latitude 7280 does not recognize charger
                  by PowerAmpFreak
                  I have a Dell Latitude 7280 which complains during boot-up that the charger wattage cannot be determined. Tested with two different chargers.
                  Any common faults that could be fixed?
                  I replaced the DC jack, the original DELL LATITUDE 7280 DC30100Z300 0DP4VC.
                  How does the communication between the charger and the PC work?...
                  07-28-2025, 07:18 AM
                • exerion5000
                  DELL Alienware 17 R3 (LA-C912P) only work with 120w charger in mode low CPU clock
                  by exerion5000
                  Hello, I received this laptop with the following condition: When I turn it on, it shows the ALIENWARE light and the Alien button lights up, then it does not show an image and it restarts constantly, as the customer had already informed me that the battery was dead, I connected an original charger that I had it for testing, the machine turned on normally and I was able to enter Windows without problems, after a while of testing I noticed that it is very slow (like a Cyrix 425...), and after performing a CPU test the frequency is
                  below normal, as if it were operating in an extreme energy...
                  10-15-2023, 02:12 PM
