Substituting NEC PS2561 optoisolator for Corsair CMPSU-400CX
  • Agent24
    I see dead caps
    • Oct 2007
    • 4953
    • New Zealand
    My older machine in the lounge started having problems recently, and I decided to check out the PSU first, since I knew it had Su'scon capacitors and was a few years old.
    Annoyingly (because I think now it's the motherboard on the way out) all the capacitors test fine for ESR, but I want to recap anyway, since I got them out.
    Just one problem... while removing some of that crap glue from the PSU, I managed to rip the legs off one of the optoisolators. It's a NEC PS2561 with W suffix which denotes a CTR (current transfer ratio) of between 130 and 260% - and which has a Vceo of 80v.
    The PS2561 is not available in NZ nor can I find a decent substitute.
    Can anyone help? Do I *need* one with a Vceo of 80v? (most I see are 70v)
    -David VanHorn
    Re: Substituting NEC PS2561 optoisolator for Corsair CMPSU-400CX
    Can you trace out to see what kind of Voltage it is being exposed to or how it is being used in the circuit? 70V is more likely to be OK.
    • Agent24
      I see dead caps
      • Oct 2007
      • 4953
      • New Zealand
      It's either the main feedback or the opto which takes the startup signal from the motherboard. I haven't checked which one, I think it's main feedback, have to desolder the PWM controller (on a separate board) to check properly
      -David VanHorn
      • everell
        • Jan 2009
        • 1514
        Here is you a handy cross reference guide.
        Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
        • Agent24
          I see dead caps
          • Oct 2007
          • 4953
          • New Zealand
          Thanks but none of them match up 100% - all have lower voltage tolerance or lower current rating - and I don't know how much the difference may matter in this PSU. Probably it won't matter at all, but I don't really want to see the thing self-destruct.
          -David VanHorn
          • Agent24
            I see dead caps
            • Oct 2007
            • 4953
            • New Zealand
            Bought a "pulled" one from an eBay seller in France, but the markings are nowhere near as nice as the original which makes me suspect it's just another Chinese clone one. Yeah it might work fine, but ugh...
            I'll trace out the circuit and find out exactly what mine was doing, hopefully you can help me work out if another part will work. Rather have a genuine substitute than an unknown.
            -David VanHorn
            • Khron
              • Sep 2006
              • 1350
              • Finland
              Now, in my admittedly limited experience, those optocouplers should have no reason to be subjected to more than... oh, say 20v (although in practice it would most definitely be lower than that).
              Add to that the fact that, let's face it, a designer would have to be (bordering on) insane, to run just about any component on the bleeding edge of its ratings. I've cracked open a LOT of power supplies (ATX's plus an assortment of plugpacks and printer PSU's and whatnot) - more often than not, the optocouplers are either PS2561's (or clones thereof), or PC817's (same "disclaimer").
              https://cdn.badcaps-static.com/pdfs/...b40670876d.pdf
              Match up the variant with the similar CTR range as the original '2561, and you should be on your way
              But, as always, i'm open to corrections in case i'm talking sh*beep*t
              Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
              • Agent24
                I see dead caps
                • Oct 2007
                • 4953
                • New Zealand
                You are right. A designer would have to be insane to run the thing near maximum ratings. But some people do it anyway.
                -David VanHorn
                • kasfamily
                  • Aug 2014
                  • 765
                  • Russia
                  Broken legs in PS2561 easily restore removing part of the housing and solder wire leads.Here as an example
                  • everell
                    • Jan 2009
                    • 1514
                    What type of solder are you using to replace such tiny broken legs?
                      • 31019
                      any fine solder will work, but lead-free is best because you need the strength.
                      it's more about the size of the iron tip
                      • kasfamily
                        • Aug 2014
                        • 765
                        • Russia
                        This
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4953
                          • New Zealand
                          I had a similar idea but figured it would be better to get a new one. Not only is the lead broken off, the case is cracked and I don't know if it still works properly anyway.
                          I think I'll figure out which one is for feedback and which is for PS_ON, use the good one for feedback and the clone one or the closest equivalent I can find for the PS_ON signal. That way if it fails nothing really bad should happen.
                          -David VanHorn
                          • h0m3w0rk
                            Random Shutdowns/Startup Failure with Corsair SFX 450
                            by h0m3w0rk
                            I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
                            For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
                            02-09-2025, 03:19 AM
                            Corsair CX750M [Model 75-002019] - burned output toroid inductor
                            by momaka
                            Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                            So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                            09-19-2021, 08:44 PM
                          • hobostove
                            Corsair RM1000e - Help identify 5VSB Zener diode
                            by hobostove
                            Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                            Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                            There's a 22ohm resistor that's melted and open, but it still has the bands.
                            The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                            It looks like the diode connects the source and drain of a TNY284...
                            03-27-2025, 02:25 PM
                          • W1ngl3t
                            Corsair RM850x (synchronous ATX) need help troubleshooting
                            by W1ngl3t
                            I have a Corsair RM850x that refuses to turn on. I have 5v stby but as soon as I try to power it up it goes 'click' and does not deliver any voltages.
                            I have not been able to find any blown or shorted components and there are no bulging capacitors. I have replaced the APFC controller and for a brief period (2 or 3 on/off cycles) the PSU worked but then the fault returned. Perhaps heating the PFC area is what resulted in the temporary fix?
                            The only option I see now is to start pulling components one by one, but before I proceed, perhaps someone more knowledgeable...
                            03-15-2025, 04:43 PM
                          • bimole
                            Weird behavior on 3.3V rail of a CORSAIR CX600
                            by bimole
                            A colleague gave me an apparently ill CORSAIR CX600.
                            He told me that he heard a banging noise, and smelt the magic smoke.
                            After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                            I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                            It's another story on the 3.3V rail...
                            I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                            02-13-2025, 04:49 AM
