DSP-167DP LOW VCC at IC901
  • TJM2005
    • Aug 2013
    • 31
    Originally posted by Agent24
    Did you check D902 and/or D902B yet?
    I just double checked them, both are reading about .47 and are not showing shorted.
    I also swapped out IC901 with another one I had, and it didn't make a difference.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5081
      • New Zealand
      Sounds very strange the Vcc pin is only 1.1v, it should be much higher for sure.
      That IC won't try to start until the Vcc pin is at least 16v, before that it will be in UVLO state.
      There are various other protections built into the IC which will shut down the gate drive if it detects issues,
      But from what I can gather, it only affects drive to the MOSFET, not the startup power to the Vcc pin.
      So even if say the feedback pin is shorted to ground, I believe the Vcc pin would still be at a normal voltage,
      But the IC just won't be sending drive to the MOSFET.
      Normally a low Vcc pin reading would indicate a problem like open circuit or shorted/leaky capacitor C904B,
      Or the diode D902 being shorted.
      Or in your case, the current sense resistors being open and breaking the circuit - but you already replaced these.
      Unless you got very unlucky and have two DOA ICs!
      Are you measuring from the hot side ground?
      What is the resistance from Vcc pin to Ground pin?
      What is the resistance from BNO and COMP pins to Ground pin?
      Did you check or change the optoisolator?
      Also, can we get photos of your board, both sides, and showing the worked areas?
      -David VanHorn
      • TJM2005
        • Aug 2013
        • 31
        • Are you measuring from the hot side ground?
          • Yes, scope ground on the - pin of the main cap
        • Did you check or change the optoisolator?
          • No, this would be PC902?
          • I have one and could try to swap it out.
        • I found this near the bottom of the datasheet, everything else calls out stopping the gate driver:
          • Open/Short fault Protection
            Some crucial protections are integrated in the LD7913J to
            prevent the power supply from damage in open/short fault
            condition. The LD7913J will shut down to protect the power
            circuit under following open or short conditions:
            1. COMP pin short to ground
            2. S pin floats
        • Also, can we get photos of your board, both sides, and showing the worked areas?
          • Attached, I tried to make them useful. If you need to see something else I can grab move.
        Resistance to Hot Ground / Pin 3:
        • S: 2.5Ω
        • BNO: 156KΩ
        • GND: 0Ω
        • COMP: OL - 20MΩ​ I could only catch it for a split second
        • DRAIN: 33kΩ​-200KΩ maybe more I didn't wait for it to stop charging.
        • VCC: 1.76K​Ω
        • Agent24
          I see dead caps
          • Oct 2007
          • 5081
          • New Zealand
          I find it interesting you have 1.76k to ground on Vcc Pin.
          I see that there is a 2k SMD resistor (R903A) that goes in series to ground with ZD907.
          I guess this is to clamp the Vcc voltage.
          I wonder if ZD907 is okay? If it were shorted, that may cause the problem.
          It looks like the Vcc supply of IC901 also feeds a pin on IC902. Can you confirm this?
          If it does, then it's possible a fault with IC902 or its associated circuit could be pulling the Vcc pin low.
          -David VanHorn
          • Agent24
            I see dead caps
            • Oct 2007
            • 5081
            • New Zealand
            Also I would definitely recommend cleaning the flux around IC901 given it runs from the high voltage supply.
            Sometimes flux can breakdown with high voltage and cause leakage or even arcing.
            -David VanHorn
            • TJM2005
              • Aug 2013
              • 31
              • ZD907 / .74 no shorts
              • The blue line should be the connection from the comp pin to PC902
                • It is the only pin on the hot side with continuity to the comp pin, amongst PC901 - PC903.
              • I pulled PC902 from the board and powered it on, I am still getting 1.6V at VCC.
                • It doesn't seem to be bad, I posted a couple of pictures of the old one vs a new one.
              • I gave the flux a good cleaning, I forgot to clean it after I swapped the chip this afternoon.
              OLD Octo:
              New LTV-816 https://www.mouser.com/ProductDetail/859-LTV-816
Name:	NEW LTV-816.jpg
              • Agent24
                I see dead caps
                • Oct 2007
                • 5081
                • New Zealand
                #27
                Hmm. I really thought ZD907 might have been it.
                Well, the next thing which might be a problem I can think of, is IC902, since it seems also connected to the Vcc pin of IC901.
                It probably receives power from the same place.
                Can you identify IC902? Or post a clear photo of the markings?
                -David VanHorn
                • R_J
                  • 9607
                  The ic should be able to charge the vcc capacitor before anything else would be detected, it should be able to charge the cap with about 1ma of current. If you can isolate the vcc pin from the rest of the circuit and only connect a 10~47µf cap from H-ground to only that pin and see if the ic can charge the cap, or try removing one end of ZD907 (it may be zenering at 1 volt?) and try to isolate ic902 vcc pin if you can (careful not to break pin) I would also remove one end of D902B in case it is leaky and loading down the vcc line.
                  It is possible the ic is defective
                  IC902 is likely a ST9S101-t6G or IN1M101 (marked S101)
                  • TJM2005
                    • Aug 2013
                    • 31
                    • Can you identify IC902? Or post a clear photo of the markings?
                      • Sorry I thought you was talking about the PC902, I now see IC902 on the bottom side.
                      • looks like an S101 /408A
                      • Click image for larger version
                    • If you can isolate the vcc pin from the rest of the circuit and only connect a 10~47µf cap from H-ground to only that pin and see if the ic can charge the cap.
                      • I have extras 22uf 50v caps
                    • Or try removing one end of ZD907 (it may be zenering at 1 volt?) and try to isolate IC902 VCC pin if you can (careful not to break pin)
                      • Is this the correct pinout? VCC would be under the letter A of 408A on the chip?
                    • I would also remove one end of D902B in case it is leaky and loading down the VCC line.
                    • It is possible the IC is defective
                      • I swapped it this afternoon, both are doing the same thing, although nothing to say that both are no good haha.​
                    What are your thoughts on best next steps? Lift the IC901 VCC pin and install the spare cap between it and hot ground to verify the IC is good?
                    If this test good then try lifting ZD907 and D902B along with IC902 VCC, see if the voltage increases then add a leg back one by one?
                    Thanks again for all of the help, I am trying to learn as I go, but all of this complex circuitry working together is hard to wrap my head around.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5081
                      • New Zealand
                      #30
                      Looks like it to me. You should get continuity between that pin, and Pin 5 (Vcc) of IC901.
                      That does sound like a way to check it with everything else disconnected.
                      You could desolder the chip, lift Pin 5, resolder it, then attach the cap on the top side of the IC between pins 5 and 3.
                      Of course, if this does work, the IC may start up and begin oscillating, then shutdown again when the capacitor runs out of charge. So you won't see a stable voltage on Vcc, but probably a kind of sawtooth wave, but it should be higher than 1.x volts that you have now.
                      -David VanHorn
                      • TJM2005
                        • Aug 2013
                        • 31
                        I attached a cap between IC901 VCC and hot ground.
                        With my meter connected it bounces between 10 and 15 volts.
                        Is there anything else I should check while I have it hooked up like this?
                        • R_J
                          • 9607
                          So, you isolated the vcc pin from the rest of the circuit? well now we know ic901 is working to produce startup vcc, this where the transformer would start to supply the run vcc, so I suspect something is dragging down the vcc line. possibly ic902?
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5081
                            • New Zealand
                            #33
                            It can be a bit confusing but think of it like this:
                            IC901 trickle-charges the C904B capacitor on Pin 5 from the high voltage present on Pins 7,8
                            This continues until C904B has 16v on it
                            So now we have C904B providing 16v Vcc back to IC901 (which will now go into startup mode)
                            But also
                            There is ZD907 and its resistor, across C904B, which clamps the voltage to whatever value ZD907 happens to be.
                            And, there is IC902, the IN1M101, which also gets Vcc from the power supplied by IC901/C904B.
                            ZD907 is going to be rated something less than 30v, since the maximum voltage allowed on IC901's Vcc Pin is 30v.
                            The IN1M101 has a maximum Vcc rating of 32v
                            So the Zener is probably something like 24-26v or so, but you can read the part number off the zener and check it.
                            Since you get the proper Vcc voltage when IC901 has Pin 5 is isolated from ZD907 and IC902, it's quite possible one or both of these are faulty.
                            There is also an SMD ceramic capacitor, C904A, which appears to go between Pin 5 and ground. This could be partially shorted/leaky.
                            So your suspects at this point are C904A, IC902, ZD907 and D902B.
                            The diodes might have tested OK on your meter, but could still be leaky/breaking down under higher voltage.
                            Your meter will only output about 3v maximum, but these parts are seeing 16v or more in circuit.
                            If you have a bench power supply you can test these out of circuit. Make sure to put a resistor in series to limit current, especially for the zener, like 5k ohms
                            For the C904A you would have to desolder it,
                            And for IC902 you could maybe lift the Vcc pin (carefully!) or desolder the IC.
                            But the diodes are easier to test.
                            You could also just lift a leg on each diode, put IC901 back in circuit, and see if you still have the problem.
                            -David VanHorn
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5081
                              • New Zealand
                              #34
                              Although it would be safer to test/replace ZD907 rather than run the circuit with it disconnected, of course.
                              -David VanHorn
                              • TJM2005
                                • Aug 2013
                                • 31
                                Ok, I played around some tonight.
                                • First I removed just IC902 and tested, I am now getting 13.6V VCC.
                                  • The corner of the IC chipped off as I was trying to remove it and I slightly damaged one of the small pads, although I should be able to jump it back to the trace.
                                  • Is this something I can source from Mouser?
                                • C904A
                                  • That would be this one correct? Any Idea what it should be, I can't see any markings on it, I can hardly pick the darn thing up haha.
                                • ​ZD907
                                  • Looks like markings: 24B NZ
                                • D902B
                                  • Looks like markings: LT423 UG1004
                                • I haven't had a chance to get the power supply out and test these, but if I could source new ones I wouldn't be opposed to swapping them out, along with C904A and IC902
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 5081
                                  • New Zealand
                                  #36
                                  Sounds like IC902 is likely bad and pulling the Vcc supply down, probably it was damaged from a voltage spike when IC901 etc blew.
                                  ZD907 was probably protected by the resistor in series.
                                  No idea. You can search the model number on Mouser and see if it turns up.
                                  Otherwise it may be something you'll have to get from eBay/AliExpress
                                  C904A
                                  No idea, without a schematic or a known good one to measure. (well you could measure this one in case you ever do need to replace it)
                                  I would guess it's 100nF, or 10nF is possible, but it might even be 1uF. I don't know.
                                  ZD907 Looks like markings: 24B NZ
                                  Probably a 24v zener, which sounds about right to me for this circuit.
                                  -David VanHorn
                                  • R_J
                                    • 9607
                                    ZD907 (likely ok) is NZX24B 24v zener diode
                                    D902B (likely ok) UG1004 or UF1004-T
                                    C904B (likely ok) 1nF 50v
                                    Seems like IC902 was the problem, ST9S101-t6G or IN1M101 not available from mouser or digikey etc. China, aliExpress, $bay
                                    With IC902 removed and all other parts in place, It is likely you will get the standby voltage and the tv may even turn on. IC902 is more for brownout protection, and the board should work for a test to see if anything else is wrong.
                                    • TJM2005
                                      • Aug 2013
                                      • 31
                                      Wanted to give an update:
                                      • I bench tested both ZD907 and D902B at 16V and a 5KΩ resistor and they both tested OK.
                                      • I tried to solder leads onto C904B and the wire was too stiff causing the solder pad to pull off.
                                        • I got a replacement today and put it back on.
                                        • I tried to test it using T/R = C and my function generator with a 10KΩ​ resistor. If I did the math right I got 1.8nf.
                                      • ​VCC is now study at 13.64V
                                      • ​I get 168V on the drain pins during standby
                                      • ​388V when I power it on.
                                        • The backlights and white power lights all came on.
                                      • I have another IC902 on order and it should be here in a day or so, and I will put it back on. Hopefully that wraps everything up.
                                      Thanks again for all the assistance.​
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 5081
                                        • New Zealand
                                        #39
                                        Looking good!
                                        -David VanHorn
                                        • reessi
                                          Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                          by reessi
                                          Hello:
                                          I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                          I started on the ACER:
                                          Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                          All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                          I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                          10-29-2024, 11:31 AM
                                        • Yanleb
                                          Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                                          by Yanleb
                                          Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                                          I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                                          D608, good
                                          D618 RF101L4S, good (See warning 1 below)
                                          D619 RF101L4S, good (See warning 1 below)
                                          D865 RF101L4S, shorted (See warning 1 below)
                                          IC464 Inverter HA MC74HC1G14, shorted...
                                          03-09-2020, 12:00 AM
                                        • modtool
                                          HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                                          by modtool
                                          Hi to all,
                                          the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                                          I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                                          I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                                          04-01-2025, 08:22 AM
                                        • BalkanBoy
                                          Dead Razer Blade 14 2022, shorted CPU?
                                          by BalkanBoy
                                          today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                                          Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                                          I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                                          Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                                          I removed coil and injected 0.7V, it draw around...
                                          09-27-2024, 12:44 PM
                                        • barry101
                                          Apple 820-3662 VCore shorted to ground.
                                          by barry101
                                          Hi, Would appreciate some help.
                                          I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                                          Get charger light but no fan spin or chime. No liquid damage.
                                          Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                                          Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                                          With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                                          Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                                          06-24-2025, 07:34 AM
