What's the cap for?
  • Behemot
    • 4845
    • CZ
    What's the cap for?
    I am not sure what the red foil cap is in this PSU for.
    It is connected between phase and neutral in front of the bridge rectifier so it behaves like filtration cap continuously (like it's not part of the voltage doubler or something). So it should be safety X, shouldn't it?
    Re: What's the cap for?
    If it is connected across, then yes, it should be safety cap type. There is no X/Y printing on the body of the cap? What is the brand of this power supply, if it has CE then it is faked CE, no way it could have pass CE compliance, all the safety components have to be on the construction listing.
    • SIDMX
      • Nov 2010
      • 165
      • Mexico
      Yeah it should be an X cap, seems to be 1uF maybe these diped film caps are cheaper than the X ones but im not sure I've never bought diped film caps or maybe they run out of X caps and just put whatever they had on hand, at least it seems to be sitting after the fuse so in the rare event that the cap shorts the fuse must blow. There is a thread on this topic somehow you missed that part
      • c_hegge
        • Sep 2009
        • 5219
        What PSU is that? It looks like a Delta, but surely, Delta would know better than that?!
          They do make X cap in that type:
          [Class%20X2].pdf
          • Behemot
            • 4845
            • CZ
            It's Delta OEM design, GPS-400AB-C as Thermaltake Litepower 400 PP (W0161).
            Now I am looking at it, it is not between phase and neutral, it is on the phase only, in parallel with the passive PFC coil. So possibly it is to shift back the phase change the coil makes? Usually the caps is on the coil itself but not here. Than there is current at high voltage flowing through the cap, but if it fails shorted, the PFC will just not work, not supressing the harmonic distortion, that's all…
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              Yeah, I have seen this several times, a non safety cap in parallel with PPFC coil.
              I attach 4 images with the model of the psu in filename.
              • Behemot
                • 4845
                • CZ
                Seems to me Delta has very deteriorated in quality. Few years ago, it was able to survive eternity with even the worst crapacitors. But a colleague of mine has informed me (under the preview which just came out) he has the original Delta on this platform, a DPS-300AB-C. After five years, all crapxon capacitors are supposedly bloated.
                • c_hegge
                  • Sep 2009
                  • 5219
                  Or the capxon capacitors have gone down in quality over the last five years and can no longer survive even in Delta power supplies now.
                  Interestingly, I've only ever seen capxon fail twice in Delta PSUs, and one of those times was because the fan quit after getting badly rusted by the salty coastal environment. The other one only had one cap fail, and it was covered over by wires.
                  EDIT: I've never seen any other band of capacitor fail in a Delta either. Ltecs and Taicons seem to hold up well in Delta power supplies.
                  • Behemot
                    • 4845
                    • CZ
                    Yeah even those can handle and I don't put ltec above crapxon. I don't know the series used but the older ones were crappier than the newer ones…
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4958
                      • New Zealand
                      CapXon are just crap, simple answer!
                      -David VanHorn
                      • Behemot
                        • 4845
                        • CZ
                        So is ltec and taicon…
                        • c_hegge
                          • Sep 2009
                          • 5219
                          They aren't great, but capxon is easily worse than either of those two.
                          btw, Taicon aren't that bad these days, Nichicon's influence over them seems to have helped them to get their act together.
                          • Behemot
                            • 4845
                            • CZ
                            I will consider them good as soon as they got to the level of Nichicon, until than it's just another average crap.
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4958
                              • New Zealand
                              Well, I have not come across a blown Taicon so far, and I have seen LCD monitors where the CapXon are all blown and the Taicons tested fine for ESR, so I figure they must be better quality.
                              I still replaced the lot though, just in case, but keep the Taicon for testing etc
                              -David VanHorn
                              • Wester547
                                • Nov 2011
                                • 1268
                                • USA.
                                If you're referencing LTEC, their general purpose series (TK, TH, ST) seem to do much worse than their low ESR series (LZx for an example, though their very low ESR series don't seem to hold up well). I think there are threads here that show a 100uF TH often to be the culprit in those 800W SFF Deltas. They seem to dry out as fast as the 8mm Teapos do. And I think your mileage with Taicon also varies with the series. Their lower ESR series (Hx) aren't very reliable but their entry level ESR series seem to do much better (Px), have not actually come across a failed one besides ones exposed to discolorating temperatures (except one bad batch I think). As for CapXon... they are bad enough to fail on the shelf so that should give you a lucid idea of their quality. If Delta really has declined in quality, though, I'd guess that a less aggressive fan controller is the reason.
                                • Pentium4
                                  CapXon Be Gone
                                  • Sep 2011
                                  • 3741
                                  I rarely see any failed caps in Delta PSU's as well. Of course, even Delta can't save the impending doom of CapXon on the 5VSB. However, I've seen TONS of failed Ltec TK in Delta PSU's. For the record:
                                  Taicon>Ltec>CapXon
                                  • Behemot
                                    • 4845
                                    • CZ
                                    I wonder what topology is this or why there are 8A/900V transistors. It's not push-pull for sure (so no 2x Vin), there is no center-tap. It's also not a half-bridge, there are no foil capacitors. Both drains are connected together (to first transformer pin), both sources are connected together (to V-), gates are separate but I read 66 ohms between them. Second transformer pin is on V+.
                                    It's flyback isn't it.
                                    • fadi90
                                      PILZ PNOZ X4 Safety Relay
                                      by fadi90
                                      I'm working on repairing a Pilz PNOZ X4 safety relay module. When I opened it up, I found some of the connector pins detached from their pads. I replaced the connector with individual wires, but the issue remains.
                                      The module is set to dual-channel mode with manual start. In this mode:
                                      • Y36-Y37 and Y1-Y2 are bridged.
                                      • 24VDC is applied across A1-A2.
                                      • It monitors two emergency circuits (S11→S12 and S11→S52).
                                      • When both are closed (24V present on S12 and S52) and the start button is pressed (S33 connected to S34), the NO contacts (13-14, 23-24, 33-34)
                                      06-07-2025, 01:21 AM
                                    • Cappy Oligan
                                      Newbie about to dive in with the leads. Safety advice please.
                                      by Cappy Oligan
                                      I'm new to electronic repair. Trying to troubleshoot a Dell monitor that only has an AC port for power. I'm concerned about safety and not getting shocked. Should I order an isolation transformer and plug in the monitor into that and proceed with testing the board inside? Or should I get a DC power supply and limit the amps and connect the voltage to a pin somewhere inside where 19V DC is first expected? Or both? Thanks.
                                      08-30-2024, 05:40 PM
                                    • mpwdhc
                                      RIFA safety cap PME277 - x or y?
                                      by mpwdhc
                                      Hi guys, new member here, trying to fix an 80s B&O TV which suffered a failure of the 0.1uf safety cap up by the power switch/fuse. This is clearly marked as x2. The replacements are half the size, but have the same rating.
                                      Having read about RIFA failure, I also ordered replacements for the other two caps. Now that they've arrived, I'm not sure they are correct. The originals are rated 4700pf, and are marked as follows
                                      40/085/21 GPF
                                      PME277 MB447
                                      CT5
                                      250V ~ MP
                                      LD2
                                      VDE reg nr 5201.212222
                                      Is this an X or Y cap?...
                                      11-14-2022, 12:50 AM
                                    • Cornboats
                                      Garage door opener-safety cutout faulty
                                      by Cornboats
                                      I have vintage Slavedor garage door opener that has stopped closing the door. If I disable the up/down current control to the motor it works fine. I've attached the larger control board which is for everything and the smaller current control board.
                                      Normally the current control is set slightly above the maximum current normally used. If the door exceeds this it should stop and reverse when closing or just stop when opening. Can someone please explain how the current control board works so that I can try and repair or replace the defective parts.
                                      I see my self as an interested novice...
                                      01-19-2023, 05:25 AM
                                    • mr.Data
                                      Bypass mosfet safety
                                      by mr.Data
                                      I know that in some cases where the laptop does not boot it is possible to bypass the first mosfet to make it boot again but how safe is it and what's the worst that can happen?
                                      03-10-2022, 03:01 AM
