Help with antec trio 550w
  • jrafael
    • Jul 2007
    Hello.
    I am in need of a better psu, currently running on a 550w LOGISYS
    http://www.newegg.com/Product/Produc...82E16817170019
    That is all I could afford at that time, and being in a very tight budget to upgrade ($30) I pulled the trigger on a "defective" Antec True Power Trio TP3-550 - http://cgi.ebay.com/ws/eBayISAPI.dll...m=190128556391
    I'm good at soldering and electronic, used to work as rework specialist at jabil circuit reworking Cisco routers and Compaq laptops motherboards returns from assembly lines until the net stock crash and got laid off.
    Therefore, after reading a lot in here at Johnny's guru website and overclocker's about antec and all the "bad" rap about them I was going to be a good investment in fixing this unit than buying another pos $30 psu.
    I have not received the psu yet, once I get it, I will post pictures of all the internals and create some sort of work log for others too.
    Please excuse the bad English, my first language is Spanish
    Please stay tuned for updates.
  • Spacedye69
    • Nov 2005
    • 698
    • US
    Re: Help with antec trio 550w
    Americans must REALLY be assholes. Everyone is always apologizing for their English!
    My first language IS English and I still suck at it.
    • linuxguru
      • Apr 2005
      • 1564
      jrafael: There's nothing wrong with your English - no ambiguity, simple, clean, easily understood. You'll have no difficulty fixing up PSUs once you understand the main principles and the common failure modes. Welcome aboard, and it's good to have a rework specialist on this board.
      • starfury1
        • May 2006
        • 1256
        I'll second that...RE the English...its my only one and I am lousy at it too...
        Yours was excellent no need to apologize for it
        Welcome jrafael
        RE: PSU
        Yes from what I understand, design is ok just bad choice of caps.
        Although Ebay's description of the fault wasn't what I'd call overly informative.
        posting photos is always helpful.
        Your rework skills should serve you well with psu's and Motherboards
        Be prepared to have your brain picked in that area here thought
        Cheers hope its a simple fix for you
        • tazwegion
          • Jun 2006
          • 444
          Congrat's on your choice of PSU for a 'rework' project
          I'm quite fond of my 2 recapped Antec's
          Viva LA Retro!
          • Sparky
            High voltage
            • Jan 2007
            • 234
            I thought the trio didn't use crap caps anymore? Just the smartpower, truepower 1 and 2 lines?
            • jrafael
              • Jul 2007
              Thanks everybody for the warm welcome.
              @ starfury1: I know, they only stated that the psu didn't power on? Therefore, it may be something as simple as a blow fuse (crossfingers).
              I should have the psu by 07/12, first thing I am going to do is open the case and take pictures of all internals, then perform a visual inspection (flow fuse, buldge caps, burn marks, etc) take note of everything, depending of results of visual assessment will attempt to power on.
              I have good digicam with a nice macro, so I am going to host hi-rez pictures in imageshak and post thumbnails to keep the post clean and low-band friendly.
              • jrafael
                • Jul 2007
                Update:
                I received the psu, opened up, visual so far everything ok, fuse tested ok, I jumper the green an the black nothing happened fiddle the unit around reworked some cold looking solders and powered on, Turned of because I didn't have the fan on it, close the psu, didn't power on, check the mobo cable and only have power in the green and purple wire nothing else, connected to mobo, didn't power on.
                Main cap its Hitachi, then some teapos, otc and some "j" brand ?, will post pictures later.
                • Shroomie
                  • Apr 2006
                  • 356
                  some "j" brand
                  Did the J look like a J combined with a P? They could well be JPce TUR series. Not the best, but not bad. Enermax uses 'em, too.
                  You know there's something wrong when you open up a PSU and are glad to find Teapos.
                  Why I don't buy cheap cases!
                  • linuxguru
                    • Apr 2005
                    • 1564
                    1) Check the voltage on the +5Vsb and all rails on the secondary of the auxiliary supply.
                    2) Replace suspect caps (Fuhjyyu, etc.) on the secondary of the aux supply. This includes all caps on +5Vsb, as well as any other secondary rails coming of the aux supply.
                    3) Replace the small electrolytic cap (~22uF) on the primary side flyback winding of the aux supply if it is present.
                    4) Check all the rectifiers on the secondary rails for shorts, especially on the +12v rail (this may require desoldering the leads of the rectifier, or removing bleeder resistors).
                    5) Replace the PWM controller IC as a last resort.
                      MEDION ERAZER Specialist P10 Notebook Specification for Upgrade or Repair
                      This specification for the MEDION ERAZER Specialist P10 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Specialist P10 boardview and Specialist P10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                      09-07-2024, 06:11 AM
                    • mburke26219
                      Pc Specialist GM7TGxP Bios and EC Problem
                      by mburke26219
                      Hi All,
                      Currently struggling with this bios and EC Problem and hope someone with more knowledge might be able to help, so my laptop PC Specialist Ionico 17 ( Tongfang GM7TGxP / 11800h rtx 3070 ) had lower than normal resistance on the PCH, so before i changed the pch i attempted to flash a bios/ec from same type of laptop board ( i am not the original owner and PC Specialist would not help ) which did flash ok but no change, after that i changed the chip and all resistance readings from all rails were normal, so i turned the laptop on with the new PCH and it turned on as soon as i...
                      08-03-2025, 05:30 AM
                    • AureliaKitsune
                      Request for Boardview – RX 6900 XT MSI GAMING Z TRIO
                      by AureliaKitsune
                      Subject: Request for Boardview – RX 6900 XT MSI GAMING Z TRIO
                      I am looking to repair my MSI RX 6900 XT GAMING Z TRIO graphics card and need the boardview to perform an accurate diagnosis.
                      Would it be possible to provide it to me or let me know where I could obtain it?
                      Thank you in advance for your help.
                      Best regards,
                      Aurelia...
                      02-06-2025, 02:21 PM
                    • peter21
                      BeQuiet Dark Power Pro P10 550W PSU: Missing 5V Standby
                      by peter21
                      Hi there,
                      a friend of mine gave me a BeQuiet Dark Power Pro P10 550W PSU.
                      The problem: The PSU simply switched off during operation and never came back on.
                      My observations / measurements:
                      I opened the housing and checked for obvious damage -> negative. Visually, everything seems fine.
                      Lowcost power supply tester (China):
                      No result. The power supply does not turn on and the tester keeps off
                      Next, I measured the 5V standby line (pin 4) on the ATX connector.
                      Result: Not present (!).
                      Obviously this seems...
                      02-24-2024, 10:11 AM
                    • luckydip
                      MBPPF4NU18-FN10 Bios - PC Specialist TongFang
                      by luckydip
                      I need help with a bios for the above machine - Ryzen 7 14". I get fan spin, keyboard lights up and sometimes the screen works but is usually a black screen.
                      PC Specialist - P/N PC1-1847447
                      S/N 1847447001
                      Board number: MBPPF4NU18-FN10...
                      06-19-2025, 03:06 PM
