Optiplex power supply dead
  • Luke Mawdesley
    • 20
    Read this thread and also check that MOSFET for short.
    https://www.badcaps.net/forum/troubl...-7010-pc-tower
    I will do more testing later on this one later. I also took apart the other optiplex and found that it does have standby power, so I tried shorting the ground and PSON pins and it started up like normal with all power rails working. So I'm assuming the problem is with the mobo or power switch sending that signal.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 7992
      Good! So you know what value the broken components are!
        • 30937
        here we go again!
        what is it with dell and these shit psu's with under-rated caps?
        • Luke Mawdesley
          • 20
          Well unfortunately no. While both of these are 790s, one is 2nd gen intel and the other is 3rd gen. I noticed that some parts like the heat sync were slightly different but the PSUs look the same and are probably even interchangeable. When I opened the other one though it was completely different with an entirely different board layout.
          • Luke Mawdesley
            • 20
            I just hooked up the PSU to the mobo and manually turned on power. The front fan spins up but no other signs of life from the power button or LEDs. Is this a mobo issue?
              • 30937
              some of the compact dell stuff is prone to bad caps on the motherboard.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 7992
                I am not sure what it is with the Dell SFF PSU’s, but they either blow to bits an sh*t, or they develop some weird faults. I got myself one of these special victims at work.
                • Luke Mawdesley
                  • 20
                  I've had more time to play around with them recently and was able to test the boards with an older optiplex psu that I had. Both boot up fine so it is an issue with the PSUs even though all power rails were working. I will probably just replace them rather than try and repair them.
                    • 30937
                    if the rails are good then look at the supervisor chip that generates the PG signal
                    it may even be just cracked soldering linking one of the vertical sub-pcb's
                    • Luke Mawdesley
                      • 20
                      Where would I find that on the board?
                        • 30937
                        trace it from the connector
                        • Luke Mawdesley
                          • 20
                          I just checked and the PG rail outputs 3.88v. Is that the normal voltage?
                            • 30937
                            https://linustechtips.com/topic/1562...-pg-value-huh/
                            it should go low initially and then jump up to 5v
                            • Luke Mawdesley
                              • 20
                              It stays at 3.88v.
                                • 30937
                                then you found the cause of the pc not starting.
                                • Luke Mawdesley
                                  • 20
                                  Should I try disconnecting the PG wire and manually applying 5v to the rail?
                                    • 30937
                                    no because it needs to pulse to ground first
                                    • Luke Mawdesley
                                      • 20
                                      OK. I will probably buy new PSUs or scrap them at this point. Thanks for all the help.
                                        • 30937
                                        follow the signal, it may just be a bad transistor
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                          03-31-2024, 02:12 PM
                                        • Andreas_de
                                          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                          by Andreas_de
                                          Hello!
                                          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                          04-12-2025, 10:38 AM
                                          07-01-2024, 06:34 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
