Got this thing for $15...the dude said "it won't supply enough juice to the motherboard"
What a steal! It gave 5VSB but wouldn't power on. Maybe those leaking CapXon had something to do with it?
Well I recapped it and it fired right up. I'll admit it was pretty hard getting some of the caps out, especially the ones where the negative lead was directly adjacent to that HUGE ground wire, my iron barely had enough oomph to heat it up.
So this thing uses a 25A bridge rectifier with a heatsink, and 1000uF 200V TK caps. How does it use APFC with two 200V caps? Does it act like a voltage doubler?
For the APFC transistors it uses two of these: https://cdn.badcaps-static.com/pdfs/...ebf159ba50.pdf
PFC Diodes: http://datasheetz.com/data/Discrete%...atasheetz.html
Switchers (4 of them): https://cdn.badcaps-static.com/pdfs/...45d354599a.pdf
It's got two of those huge transformers. It actually has six 12V rails! And they share 4 of these rectifiers: https://cdn.badcaps-static.com/pdfs/...3178bc3d3b.pdf
5V and 3.3V use two of these each: https://cdn.badcaps-static.com/pdfs/...6d9e8256e1.pdf
It's also the only 80 Plus approved ePower PSU, which means it can actually do 1,200W http://www.plugloadsolutions.com/80P...x?id=33&type=2
Uses a nice fan too.
Some are 14AWG too. it shows that Topower knows what they're doing when they try!
Half of the computer problems is caused by bad contacts
