Corsair RM1000e - Help identify 5VSB Zener diode
  • hobostove
    • May 2023
    • 73
    Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
    Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
    There's a 22ohm resistor that's melted and open, but it still has the bands.
    The other part is a zener diode and it's top went to jesus, so I can't read the marking.
    It looks like the diode connects the source and drain of a TNY284 through a couple of 2M resistors and a transformer winding.
    Does anyone know what a good value for this zener would be, and what it might be doing?
    Any help much appreciated!
    TNY284 Datasheet: https://www.mouser.com/datasheet/2/3...et-1511375.pdf
  • прямо
    • Sep 2022
    • 261
    • Indonesia
    It's most likely 1N4148W.
    • hobostove
      • May 2023
      • 73
      1n4148 is a regular diode. Isn't ZD83 supposed to be a zener?
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Have you ruled out that it isn't TVS diode P6KE150A (VR1) or Zener diode 1N5254 (VR2) from the example schematic you posted? (By studying the actual circuit closer/drawing it up more it should be "easy" to see).
        • c1q3
          • Nov 2024
          • 7
          • belarus
          I don't know will it help or not.
          This is from CM6502UHH PFC controller typical application circuit and it has TNY227P.
          Resistor is 2M (r45 + r46). On your photo something is behind.
          My wild guess it is sort of hz15-2. Enable pin should be connected to optocoupler.
          • c1q3
            • Nov 2024
            • 7
            • belarus
            don't take me serious. I'm just studying.
            • hobostove
              • May 2023
              • 73
              This is a big help. I'm away from it until Monday, but I'll answer the questions I can remember.
              To optoc? Yes
              20 oh? Bands on resistor are red-red-gold-gold-white. Which I think means 2.2ohm. (see picture)
              Source to gnd? I don't think so. I checked for shorts, and I think source wasn't connected to ground.
              • c1q3
                • Nov 2024
                • 7
                • belarus
                I made a mistake on pic above. Its not 200M its 2M. But overall it fits.
                btw I cant find what is red-red-gold-gold-white. We need some1 to explain.
                Click image for larger version  Name:	image.png Views:	0 Size:	8.79 MB ID:	3604037
                • c1q3
                  • Nov 2024
                  • 7
                  • belarus
                  changed 200m to 2m.​
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    I think the resistor is a 2.2Ω fusible resistor, it looks like it did it's job and is no longer a resistor
                    https://www.engr.siu.edu/staff/spezi...standscode.pdf
                    • c1q3
                      • Nov 2024
                      • 7
                      • belarus
                      so the third golden ring is like blank space in numeral. Interesting.
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        I could be wrong of course, these "special" resistor bands take a bit of guessing: the best way is to have more of the schematic available.
                        Right now I can't see where it connects to so I have no way to make a better educated guess.
                        But if it is before or after the source or drain for example then it is acting as a protection if the MOSFET in the TNY284 gets stuck on...
                        (And if you look at the top-side photo above it seems the PCB around the drain leg is discolored so I'd say this is what has happened).
                        And welcome to Badcaps btw and good job so far with the circuit
                        • hobostove
                          • May 2023
                          • 73
                          Incredible work c1q3, thank you very much. Thanks to you too Per Hansson. I will gather more info and confirm the drawings above when I'm in front of it tomorrow morning
                          • hobostove
                            • May 2023
                            • 73
                            It looks like the resistor is a 2.2ohm fusible. I couldn't find the exact one, but this is close: https://www.digikey.com/en/products/...52-2R2/2167125
                            That resistor is connected between 380V and Drain, so yup, it looks like it went pop as intended.
                            Source is connected to GND, and ZD5 connections match, so I think you found it! This looks like an OK replacement: https://www.digikey.com/en/products/...C15-7-F/755469
                            I can't find any shorts, so I'm going to order the diode, the resistor and a new TNY284 and hope for the best. Will report back in a week or so.
                            Thank you both!
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              Measure the optocoupler in diode test mode with your multimeter: since the failed ZD5 zener is parallell to it (talking about the example schematic that c1q3 posted here).
                              • hobostove
                                • May 2023
                                • 73
                                Parts came in today, and I replaced the 2.2o resistor, the zener, the flyback IC, and the optocoupler. Still no life so I suspect something is open up stream. Going to poke around a bit more
                                • hobostove
                                  • May 2023
                                  • 73
                                  Just found main cap voltage is only 167V when powered up. Shouldn't it be 300V+? I'm on 120AC here, so maybe ~170V is normal?
                                  • прямо
                                    • Sep 2022
                                    • 261
                                    • Indonesia
                                    That is normal. 120V AC / 0.707 = 169V DC.
                                    It will be boosted by the PFC controller chip when the PSU is starting such as when you jumper PS_ON to ground.
                                    If the boosting doesn't happen, check the supply voltage of the PFC controller chip. I don't know what chip it is, but the usual voltage is around 15V DC. Also, when you check this voltage, because the PFC controller chip is located at the primary side, the black lead of your multimeter should be at the negative pin of the bridge rectifier.
                                    Be very careful though when poking around the high voltage side.
                                    If the PFC controller chip supply voltage is present and around 15V DC, then the next logical step is to check the supervisor chip fault protection (FPO) pin. Consult the chip datasheet to see if it's an active high or an active low logic signal. If the FPO status is telling you that PSU is in protect mode, this explains why no pimary voltage boosting is happening and why the PSU won't start. Therefore, you have to disable the protection in order to force the PSU to start and proceed with diagnosing what is triggering the protection, usually it is because of an under voltage or an over voltage on one or some of the output rails.
                                    But more importantly, is the 5VSB present?
                                    • hobostove
                                      • May 2023
                                      • 73
                                      5VSB is behaving strangely. It's fluctuating between 3-3.5V. It's a couple seconds from peak to peak
                                      Click image for larger version  Name:	PXL_20250409_151919843.jpg Views:	0 Size:	181.8 KB ID:	3611288
                                      • прямо
                                        • Sep 2022
                                        • 261
                                        • Indonesia
                                        Replace the 5VSB output caps.
                                        • unimatrix93
                                          TV backlight zener diode
                                          by unimatrix93
                                          Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                                          So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                                          Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                                          The led strips has 9 6V leds.
                                          02-10-2025, 12:13 PM
                                          NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                          by sam_sam_sam
                                          I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                          I bought this from an eBay seller but unfortunately they only had one
                                          I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                          I bought three of from them to also make battery packs with this output power limit in mind
                                          I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                          04-23-2025, 05:50 AM
                                        • nev1001
                                          What zener diode might fix the sound on Maestro Mayhem gaming chair?
                                          by nev1001
                                          Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                                          The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                                          It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                                          I think an issue could be a zener diode (or capacitor) which has shorted out.
                                          The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                                          04-17-2025, 05:09 PM
                                        • Vincenzo2
                                          Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
                                          by Vincenzo2
                                          My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
                                          Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
                                          I put some pictures here to show that it is labeled "M7"....
                                          09-07-2023, 07:43 PM
                                        • debidoobs
                                          Yamaha delay D1500, zener diode broken with no marking
                                          by debidoobs
                                          im actually trying to save a d1500 delay from yamaha. I found the service manual but schematic is missing and BOM list is a bit unclear as components listed have no reference linked to the pcbs... In my case, one zener diode was broken (114 code on the pcb in attached file) and couldn't be repaired : it was a zener type package. In the BOM list i found 3 reference on this board : 1S555 (can be replaced by 1N4148), RD4.7EB2 (approx 5v rectifier), RD7.5EB3 (approx 7v rectifier)...
                                          Actually the cathode goes to VCC of sram M5M5118P, without this diode missing, i have...
                                          04-24-2024, 09:01 AM
