Corsair RM1000e - Help identify 5VSB Zener diode
  • прямо
    • Sep 2022
    • 261
    • Indonesia
    Also worth to check the 5VSB feed back as well just to make sure nothing is wrong with it. Next to its output caps there should be a TL431 and a voltage divider resistor network that set its 2.5V reference voltage, which then get feed back to the TNY chip through an optocoupler.
    ​​​If one of that voltage divider resistor network fails (very rarely happens), or if the TL431 itself fails, or the optocoupler fails (happens quite often), then the TNY chip will not be able to regulate 5VSB to the correct 5V voltage.
    • hobostove
      • May 2023
      • 79
      I found a shorted transistor on the hot side with a thermal cam. Replaced it and 5VSB started up. Now I can see that I'm missing 12v1, and 12v2 is at 11V. 3.3V is fine. Time for more troubleshooting!
      • hobostove
        • May 2023
        • 79
        Nvm, I have 12v1 and 12v2, tester connector was a little loose. However, they're only 10.8V. And after 10-15 seconds I can hear a relay click and the supply shuts down.
        • hobostove
          • May 2023
          • 79
          Adding some photos here
ID:	3612206 Click image for larger version
          • прямо
            • Sep 2022
            • 261
            • Indonesia
            That's the protection mode kicking in, because 10.8V for 12V rails is an under voltage condition.
            • Per Hansson
              • Jul 2005
              • 5897
              • Sweden
              #26
              It might not work without a load: connect something you don't care about, some old hard drives for example or a couple 12v car light bulbs to 12v and 5v outputs.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8754
                Would be the slowest acting “protection mode” in the world. I haven't seen any protection mode that is that slow. I wonder what kind of voltages the op gets on the main filter cap?
                I think the supervisor is a WT7527rt. It shuts the PSU down less than a half of a second.
                • прямо
                  • Sep 2022
                  • 261
                  • Indonesia
                  #28
                  Don't need to be sarcastic. Just tell me that I'm wrong, I can accept. I'm an adult, not a 5 year old kid.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8754
                    Not sarcastic at all. Just didn't make any sense! All you needed to do is to look for a detailed review of this PSU.
                    Here (page 3 is where the goodies are): https://hwbusters.com/psus/corsair-r...-psu-review/3/
                    Pull the data sheet of the Supervisor IC: https://www.badcaps.net/download/?id=11116788
                    Read it, and it gives you all kinds of information on how it works and how to disable it. Now all major chips are listed in that review and thus you can pull up all the data sheets too! Carry on! 😉
                    • hobostove
                      • May 2023
                      • 79
                      I attached a load (3 old 3.5" drives), and now it's shutting down immediately and staying dead until it's left unplugged for a few minutes.
                      So definitely seems like protection mode kicking in. Maybe without a load 10.8V was just near the threshold of an undervolt condition, and with the load it droops into a definite protect.
                      Datasheet seems to agree.
                      I'm seeing 167V on the main cap. 120V mains here.
                      So 12V is low and it's shutting down. Where to go from here?
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8754
                        Does your PFC work? At 167VDC at the main filter cap doesn’t seem to be the case.
                        If you want to know if the supervisor IC WT7527 is shutting things down, measure the FPOB pin. If it latches high, the protection is on.
                        • hobostove
                          • May 2023
                          • 79
                          10.2V then it shuts down
                          12V
                          5V
                          3.3V
                          • hobostove
                            • May 2023
                            • 79
                            FPOB is high @ 5V. Datasheet says it's an open drain. Shouldn't it go low if the protection is tripped?
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8754
                              From what I see, I would expect the supervisor to shut the primary down.
                              Follow the trace from the FPOB pin. You’ll end up on an optoisolator. Measure each of the 2 pins on the optoisolator on the secondary side against secondary GND. If both pins are at 5V the little led built inside the opto cannot light up, shutting the primary side down.
                              You can however disable that supervisor IC and force the PSU to stay on by grounding out the FPOB pin.
                              What’s the VDC on the main filter capacitor when you plug the PSU in and turn it on? If you get only 167VDC your Power Factor Correction circuit isn’t working in the primary. You should have something around to 380VDC. If you don’t get that voltage on the main filter capacitor, no wonder the supervisor IC is shutting things down. No PFC means there will be no high power on the secondary.
                              • hobostove
                                • May 2023
                                • 79
                                Both led pins of that optocoupler are indeed high. I think I follow now. If the supervisor IC is happy, it'll open a ground path for that led. If it's unhappy, it'll disconnect itself and the gnd side of the LED is normally pulled up somewhere.
                                I get 167V on the main cap, so next step is try to work out what's wrong with the PFC I suppose.
                                Going back a bit, before I got 5VSB to come up, I had to solve a short. Looking at it now, it was a transistor headed into the little PFC daughterboard. Probably more than coincidence. I'm looking at that area now.
                                • hobostove
                                  • May 2023
                                  • 79
                                  The transistor that was shorted was Q3 on this typical application schematic for the PFC IC (CM6500UN). I replaced it last week and the short is gone. Maybe the PFC chip is dead?
                                  Worth noting the schematic here shows one mosfet, this psu has two. Also, I'm missing the 10ohm resistor and diode between the transistors and the mosfet gate. I do have the 10ohm leading back to PFC OUT though.
                                  https://www.badcaps.net/download/?id=d3451906
                                  • hobostove
                                    • May 2023
                                    • 79
                                    PFC OUT signal looks like this on the scope, pretty much nothing
                                    Click image for larger version  Name:	image.png Views:	0 Size:	303.1 KB ID:	3615946
                                    • CapLeaker
                                      Leaking Member
                                      • Dec 2014
                                      • 8754
                                      Yeah… no. Your PFC isn't working. You need to fix that first. When the MOSFET shorted all 3 pins, it dumped full power to the gate drive circuit all the way back to the PFC IC. You have to inspect ever single part. Obviously your PFC IC doesn't do anything… depending where you got your parts from could be fake or fluke DOA. Look at the data sheet of the PFC control IC and compare your measurements on all pins. Could be the PFC IC is in under voltage lock out or VCC is missing, a component near by open, a busted trace or something. But if it’s the original PFC IC replace it.
                                      • hobostove
                                        • May 2023
                                        • 79
                                        Found an open resistor near the PFC IC, has a hole in it. Replaced it and now 5VSB is shorted again. Getting there!
                                        • CapLeaker
                                          Leaking Member
                                          • Dec 2014
                                          • 8754
                                          Hmm… how can a resistor change kill the 5VSB?
                                          • unimatrix93
                                            TV backlight zener diode
                                            by unimatrix93
                                            Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                                            So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                                            Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                                            The led strips has 9 6V leds.
                                            02-10-2025, 12:13 PM
                                            NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                            I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                            I bought this from an eBay seller but unfortunately they only had one
                                            I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                            I bought three of from them to also make battery packs with this output power limit in mind
                                            I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                            04-23-2025, 05:50 AM
                                          • nev1001
                                            What zener diode might fix the sound on Maestro Mayhem gaming chair?
                                            by nev1001
                                            Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                                            The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                                            It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                                            I think an issue could be a zener diode (or capacitor) which has shorted out.
                                            The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                                            04-17-2025, 05:09 PM
                                          • Vincenzo2
                                            Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
                                            by Vincenzo2
                                            My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
                                            Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
                                            I put some pictures here to show that it is labeled "M7"....
                                            09-07-2023, 07:43 PM
                                          • krsta
                                            Help identify the PS4 psu N14-240P1A DIODE
                                            by krsta
                                            I have a PS4 psu model: N14-240P1A with a blown diode D6 that connects to 8.th pin of the FAN6961 IC(the ic was also dead so i replaced it).
                                            The half of the diode is gone, but on the other half is written number 2 and beneath number 8.
                                            Does anybody know what diode it is, or can confirm what i found out :
                                            By measurements it should be gull wing SOD-123 package.
                                            And chatGPT says that it should be A2 (1N4148W) a part of the bootstrap circuit for FAN6961 IC....
                                            01-27-2026, 05:18 AM
