Weird behavior on 3.3V rail of a CORSAIR CX600
  • bimole
    • Feb 2025
    • 3
    • France
    A colleague gave me an apparently ill CORSAIR CX600.
    He told me that he heard a banging noise, and smelt the magic smoke.
    After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
    I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
    It's another story on the 3.3V rail...
    I have some devices to test deeply PSUs (scope, AC source, electronic load) so I can diagnose a bit.
    The schematic is very close to this one https://sector.biz.ua/docs/power_sup...T-500A-12S.jpg
    This is a basic structure : 2 switchs forward converter, one regulation point on 12V and the 3.3V derived from the 5V with a mag amp.
    Here is the problem :
    I tried to power up an old motherboard (without CPU nor RAM nor GPU) and 1sec after powering it up, it shuts down. Some measurements showed that the 3.3V is falling when loaded, the power good signal trips and it shuts down the PSU.
    I have tested almost every single components of the mag amp (resistors, capacitors, the PNP transistor, the TL431 and even the saturable reactor with an impedance meter). Everything looks fine.
    But if I load more than 200mA, the 3.3V rail falls, sign of bad regulation. There is no load on other voltage outputs.
    In these conditions, the duty cycle of the forward converter is very low and erratic.
    I noticed that if I load the 12V rail with a 22R power resistor, the switching signal is now very clean and the duty cycle of the converter is greater than without load.
    In these conditions, I'm now able to load the 3.3V with several amps without regulation problem. It's a solid 3.3V
    I think when there is no load on 12V rail, the duty cycle is not great enough to give the sufficient room to the mag amp to regulate efficiently, so the voltage falls quickly when the current rises on the 3.3V rail.
    My question is : is this normal or is there still something wrong with this power supply ?
    Many thanks for your comments in advance!
    JB
    • 31259
    if it went bang and smoked then you missed something.
    look for burned or cracked parts again.
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Yes, this can be pretty normal behavior for some PSUs, especially forward-converter topologies (resonant LLC, maybe not so much.)
      By the looks of it, your PSU is working normally, at least from what I can tell from these tests.
      Also, I don't suggest to anyone to use a motherboard without CPU and RAM as a "load" to test PSUs. Part of the problem with doing this is that when there's no CPU and/or RAM, the motherboard disabled most of the chips and power rails, so many will typically draw very little current... especially from the 12V rail, which is what's actually needed the most when it comes to testing more modern / newer PSUs that expect a bigger chunk of their load from the 12V rail.
      If nothing looks burned on the PSU and it's powering on normally... then it's probably OK.
      If so, maybe buy your colleague a beer for giving you a free working PSU.
      Agreed.
      More so, I don't see how something could have burned and banged, then have the PSU work fine again without issues. I suspect something else went wrong in your colleague's PC, like a video card going short-circuit or similar, causing the bang and smoke... and the PSU simply shut down. As to how he concluded it's the PSU and not something else, that you may have to ask him/her. I personally always try to verify the information being given when I receive something broken from someone for repair.
      • bimole
        • Feb 2025
        • 3
        • France
        Thank you so much for your answers.
        I didn't fiddled more on this PSU since last week.
        I was wondering, maybe this could be a bad snubber/damper on the secondary winding...
        With no load at all, the duty cycle is at his minimum value. If the snubber resistor/capacitor is broken, some overshoots on pulses could appear and "mislead" the regulation, reducing again the duty cycle to maintain 12V at the output.
        Maybe I will check that...
        Otherwise, nothing wrong with an IR camera, no hot spots.
        JB
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Well, a lot of PSU manuals and labels don't note this anymore (and I'd be surprised if someone even keeps these things for reference), but most ATX PSUs do require a minimum load to work properly. For the old-days ATX PSUs that were 5V-heavy, typically 0.5 to 1 Amp was the minimum required from the 5V rail, and often times between 0.1-0.5 Amps from the 12V rail - as stated by the manufacturer in order for the PSU to output voltages in spec. When 12V-heavy(er) PCs became the norm, this minimum load was more so shifted towards the 12V rail.
          In any case, running the PSU without some load and performing measurement tests will likely lead you onto a ghost problem chase.
          So put a load and then perform these tests.
          Though I doubt any secondary-side snubbers would be bad here, as these typically comprise of low-value resistor(s) in series with a ceramic or film cap. There's not enough high voltage to make these go bad so quickly as to make a popping noise... and a lot of times when they go, either the cap turns dark (overheat) or the resistors does... or in rare cases, both. But you would have spotted that with your visual inspection.
          Anyways, keep up posted what you find, as I'd be interested to see if there was actually any problem or not. To me, it makes no sense that something can go wrong so dramatically... and then the PSU can continue to work OK afterwards. But I could be wrong, so let's see just in case.
          • bimole
            • Feb 2025
            • 3
            • France
            Hi!
            I finally tested the PSU on the same motherboard as before BUT now with CPU, GPU and RAM. Works like a charm !
            Seemingly, all ATX PSU doesn't behave the same way depending on the output conditions.
            I compared with another PSU, a Seasonic FOCUS+ Gold which is LLC based and has several buck post converters after the main one. On this one, the naked motherboard (without CPU, GPU, RAM) could be powered without any problem.
            Anyway, I consider this PSU as OK and it will be used for testing various old motherboards. Output caps are still in good shape and voltage is very clean. So, that's it!
            Thank you again for your usefull pieces of advice 😉
            Cheers,
            JB
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Yes, different topologies and designs have different behavior when it comes to how they run at no or low load conditions.
              Generally, most LLC topologies tend to be a lot more stable with low loads, since they don't have an output inductor. What they do instead is, the primary side utilizes pulse-skipping / "hick up mode" when underloaded, which allows the PSU to stay operating even at nearly zero load. Meanwhile, the more "classic" PWM continuous topology designs have an output inductor (toroid), and these cannot run without any load whatsoever, since the output inductor always needs to have some minimum current flowing through it for the regulation to work. This minimum current will also vary by the design particulars (i.e. size of the output inductor, size of the main transformer, minimum allowable pulse width, size of output capacitors, and etc.)
              Anyways, glad to hear you got yourself a working PSU.
              • Nagy Daniel
                Lowest possible resistance on laptop motherboard rail - Guide Table request
                by Nagy Daniel
                Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                So, I generated a table with AI so I can...
                03-04-2025, 08:24 AM
              • Novgorod
                Corsair SF450 PSU: can faulty -12V rail be removed?
                by Novgorod
                I have a Corsair SF450 SFX power supply with slight water damage. 5VSB is present and it turns on via the ATX PS_ON pin, but immediately goes into protection mode (relais clicks on and off). During the brief moment before protection kicks in, all power rails are present except the -12V rail, which also went low resistance (24 ohm). I don't know if protection mode is triggered by over current on -12V due to the low resistance (the current limit is only 0.36A on that rail according to spec) or simply because the voltage is not present. I removed the IC generating the -12V (54231 buck converter)...
                08-21-2024, 06:38 PM
              • parakeet
                Corsair CX500 ATX PSU|Works under some/no load, but not in motherboard
                by parakeet
                Hello.
                I'm trying to fix a Corsair CX500 ATX Power supply. It works fine with no load or with a couple of devices connected but turns on for only 0.5s in the motherboard. I've tested the motherboard with a different, lower wattage rating PSU and it works fine, so I know that isn't the issue.
                3 Different ways I've tested it:
                1. Switch on with no load: All voltages good except -12v (-10.8)
                2. Switch on with CD drive and HDD connected: All voltages good, peripherals working
                3. Switch on with 24 Pin connected to motherboard: Turns on, then off after...
                06-11-2023, 11:26 AM
              • h0m3w0rk
                Random Shutdowns/Startup Failure with Corsair SFX 450
                by h0m3w0rk
                I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
                For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
                02-09-2025, 03:19 AM
              • Victor Moreira Silva
                Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                by Victor Moreira Silva
                I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                Well, my decice specs are the following:
                Model: Acer Nitro 5 AN517-54-55T5
                CPU: Intel Core i5-11400H
                GPU: NVIDIA GeForce GTX 1650
                Motherboard: GH51G LA-L181P Rev:1c
                The symptom:
                When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                05-26-2025, 10:49 AM
