A colleague gave me an apparently ill CORSAIR CX600.
He told me that he heard a banging noise, and smelt the magic smoke.
After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
It's another story on the 3.3V rail...
I have some devices to test deeply PSUs (scope, AC source, electronic load) so I can diagnose a bit.
The schematic is very close to this one https://sector.biz.ua/docs/power_sup...T-500A-12S.jpg
This is a basic structure : 2 switchs forward converter, one regulation point on 12V and the 3.3V derived from the 5V with a mag amp.
Here is the problem :
I tried to power up an old motherboard (without CPU nor RAM nor GPU) and 1sec after powering it up, it shuts down. Some measurements showed that the 3.3V is falling when loaded, the power good signal trips and it shuts down the PSU.
I have tested almost every single components of the mag amp (resistors, capacitors, the PNP transistor, the TL431 and even the saturable reactor with an impedance meter). Everything looks fine.
But if I load more than 200mA, the 3.3V rail falls, sign of bad regulation. There is no load on other voltage outputs.
In these conditions, the duty cycle of the forward converter is very low and erratic.
I noticed that if I load the 12V rail with a 22R power resistor, the switching signal is now very clean and the duty cycle of the converter is greater than without load.
In these conditions, I'm now able to load the 3.3V with several amps without regulation problem. It's a solid 3.3V
I think when there is no load on 12V rail, the duty cycle is not great enough to give the sufficient room to the mag amp to regulate efficiently, so the voltage falls quickly when the current rises on the 3.3V rail.
My question is : is this normal or is there still something wrong with this power supply ?
Many thanks for your comments in advance!
JB
JB
