Corsair CX500 ATX PSU|Works under some/no load, but not in motherboard
  • parakeet
    • Jun 2023
    • 6
    • England
    Hello.
    I'm trying to fix a Corsair CX500 ATX Power supply. It works fine with no load or with a couple of devices connected but turns on for only 0.5s in the motherboard. I've tested the motherboard with a different, lower wattage rating PSU and it works fine, so I know that isn't the issue.
    3 Different ways I've tested it:
    1. Switch on with no load: All voltages good except -12v (-10.8)
    2. Switch on with CD drive and HDD connected: All voltages good, peripherals working
    3. Switch on with 24 Pin connected to motherboard: Turns on, then off after 0.5s
    In the first 2 scenarios, the supervisor IC gives the Power Good signal, but in scenario 3 no Power Good signal is given.
    Resistances of voltage rails to ground:
    12V: 350Ω
    5V: 465Ω
    3.3V: 3.3kΩ
    Output Schottky diodes test good in circuit, all SMD resistors and diodes also test good in circuit.
    Any help would be greatly appreciated.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Corsair CX500 ATX PSU|Works under some/no load, but not in motherboard
    Try to load down the 5VSB circuit in your test no 2.
    For example if it is rated for 2.5A give it a load of 2A and see if it shuts down from that?
    • parakeet
      • Jun 2023
      • 6
      • England
      Hi, thanks very much for your reply. I don't currently have anything to use as a load on the 5VSB but I'll update when I do.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8214
        Which supervisor ic is it? Sounds like the supervisor doesn’t like something and goes into shutdown. There can be many reasons for this starting from bad caps in the main filter capacitor in the primary, over to bad caps in the secondary, or a bad supervisor IC. Even if you defeat the supervisor, it still will be hard to see what the actual problem is, until you start loading the individual output rails and measure ESR on each cap, including the main filter capacitor (specifically those snap in caps). Been there and done that.
        • parakeet
          • Jun 2023
          • 6
          • England
          The supervisor ic is an ST9S429-PG14. Didn't know that even the bulk filter cap could mess things up once it's running. Once I find a suitable load, I'll test each of the rails again, especially the 5VSB then test each cap like you said.
          Thanks for the suggestion.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8214
            If you want you can read up on a PowerMan IP PSU that I repaired a while back.
            https://www.badcaps.net/forum/showthread.php?t=106011
            • parakeet
              • Jun 2023
              • 6
              • England
              Thanks for the link. I went ahead and tested the main filter capacitor which tested good. Then tested every capacitor on the output side, and all of them were good(<0.5 ESR).
              It's rated for 3A. Best I could do was to load the 5VSB with ~3 Ohms(2 Ohm resistor + crocodile clips), it continued to run fine.
              Starting to think the issue is just a bad supervisor IC, though I have no idea what the probability of that is. What are the chances this IC just fails on its own?
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8214
                Happened before that the supervisor is bad. This supervisor IC does not monitor only voltages on the different rails, but it also monitors current. The FPO pin goes high, it sensed a fault and that pin goes back to an optocoupler to the Pwm on the primary. You can force that pin low by grounding it to secondary gnd, thus disabling the safety features of this chip for testing only.
                Did you try this psu on a different motherboard? Is this psu a modular one? If so you might not have used the cable it actually came with. They look identical, but there are some wires reversed in that plug. I put the cables from a Thermaltake to an EVGA PSU and my computer was instant dead and shorted a protection diode on the hdd. Like I said, the cables looked identical, just the wiring was different. You’ve got to do some thorough testing
                • parakeet
                  • Jun 2023
                  • 6
                  • England
                  I haven't tried it in another motherboard, unfortunately. I cannibalized the only other one I have at the moment. Also, the previous owner said it was faulty, so I assume it didn't work in their motherboard either. I'll put this on the todo list though. Just in case.
                  The PSU is not modular. That being said, I'll check the cables anyway. I think I'll just have to try to test each component on the board(to a certain point) and pray. Also, disable the supervisor like you said.
                  Thanks for your help. I'll continue to crack at it, but if you or anyone else has any more suggestions I'd be grateful to hear them. I'll be sure to update if I make a breakthrough myself.
                  • anikin73
                    • Mar 2022
                    • 112
                    • singapore
                    For psu that cannot take load, u can try these 2 easy tricks,
                    1 big capacitor is bad. The biggest one . It cannot store charge. U power up and measure how fast it drain... if it drain ultra fast.. spoilt.
                    2 secondary capacitor spoilt , bloated
                    • Docus
                      Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                      by Docus
                      Hi everyone 😀,
                      I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                      To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                      Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                      1. I already own the exact same model, but its plastic chassis is badly damaged.
                      06-10-2025, 04:24 PM
                    • bimole
                      Weird behavior on 3.3V rail of a CORSAIR CX600
                      by bimole
                      A colleague gave me an apparently ill CORSAIR CX600.
                      He told me that he heard a banging noise, and smelt the magic smoke.
                      After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                      I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                      It's another story on the 3.3V rail...
                      I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                      02-13-2025, 04:49 AM
                    • Archimedes
                      HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                      by Archimedes
                      Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                      Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                      Fans are spinning. Blindly could install windows11 and got the device manager...
                      07-30-2024, 05:14 PM
                    • AJ847.63e
                      Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                      by AJ847.63e
                      Hi Folks,
                      Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                      I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                      The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                      05-06-2025, 10:37 PM
                      ASUS P5GC-MX motherboard recap
                      by momaka
                      Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                      This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                      So here is what the motherboard looked like with its original caps:
                      CPU VRM area up close…...
                      01-27-2021, 11:59 PM
