iMac 24 PSU LITEON PA-3241-02A1 250W
  • bosscharles
    • Mar 2013
    • 83
    Hi everyone, got an aluminum 24 imac with a faulty PSU. First LED on the motherboard is on so trickle voltage is OK. When pressing the power button, 3 lights flash and then only one, 2 seconds pass then again 3 flash then back to one. I've tested motherboard with working PSU and all is well so not a motherboard issue. I can hear a clicking sound coming from the PSU each time it tries to power on. Also, when the power cable is connected, I notice one of the fans on the imac twitches. Very ocassionaly the imac will power up a bit but will eventually die again. All capacitors look absolutely fine, no bulges, leakage etc. I've had a look at the back of the PSU and I think I found the culprit. One of the mosfets looks blown. The board is darkish in that area and the solder on the front of the mosfet looks bad and its slightly lifted. I've provided photos, problem mosfet is on upper right. Thoughts? Also, does anyone now the part number for the mosfet I can't really make it out as it's heated so much, the numbers arent really legible? Would like to try soldering a new one. So if anyone know I would greatly appreciate it... Thanks
  • bosscharles
    • Mar 2013
    • 83
    Re: iMac 24 PSU LITEON PA-3241-02A1 250W
    Put a really strong light on it and figured it out....
    mosfet 060n03L
    Package: PG-TO252-3
    Cheap find on ebay...
    http://www.ebay.co.uk/itm/MOSFET-N-C...item3f265fcce0
    Schematics here:
    http://www.ic-on-line.cn/search.php?...03l&stype=part
    Thoughts of whether or not this will work? Appears to be the only rough looking area on the PSU
    • Agent24
      I see dead caps
      • Oct 2007
      • 4978
      • New Zealand
      It's cheap enough so why not? Check the MOSFET with your multimeter, it's probably shorted
      -David VanHorn
      • bosscharles
        • Mar 2013
        • 83
        Well, received the mosfet yesterday. Desoldered the presumed faulty mosfet and soldered the new one on and success! Working PSU for £1.70.
        For anyone that is interested, the faulty mosfet wasn't melted or anything but the numbers on it were very difficult to read and color was greyish black so must have gotten really cooked at some point. Hope this helps anyone with a similar issue in the future.
        Is there anything else I should look out for? Presumably, the mosfet may have gotten cooked due to another failing component on the PSU? Or it could have just failed through normal use..... I've power cycled the imac several times, had on for hours and everything is fine... Just want to make sure...
        • Agent24
          I see dead caps
          • Oct 2007
          • 4978
          • New Zealand
          I don't know about this PSU specifically, someone else might. But failing capacitors can cause overheated switching transistors (assuming that's what this one is for in your PSU). Just because the capacitors look OK doesn't mean they can't be bad.
          The MOSFET control circuitry could also be faulty, or the snubber circuit (if it has one)
          Interestingly someone else seems to have had the same problem here: https://discussions.apple.com/thread/4303781
          So that could point to some specific issue with these PSUs, not just yours, either design problem or a certain part failing over time.
          -David VanHorn
            • 31087
            could be the internal diode failed, and then the mosfet ran too hot.
            i'v noticed this on some invertors.
            when you have several fets,
            and you meter them to find the bad one, you often find that even the good ones have failing or dead internal diodes.
            i suspect in most msfet failures it's the protection diode that goes first.
            • bosscharles
              • Mar 2013
              • 83
              Thanks for the replies guys. Nice find agent24, hadn't seen that thread before. Interesting that it is the exact same mosfet I replaced. Only difference is that one was really really cooked! Hopefully it was just a dodgy mosfet and it'll be OK. I'll report back if it fails again. Thanks again.
              • bosscharles
                • Mar 2013
                • 83
                I've got my hands on another one of these with the same symptoms. PSU physically looks absolutely fine, nothing burnt, capacitors in good shape. When plugged in, trickle charge is good, #1 LED on mobo turns on.... when power button is pressed, #1,2 & 3 light up, psu makes an odd noise, #2 & #3 go off... and it cycles like this for eternity! Last time mosfet sorted it so I've ordered one and will try out.... ANything else to look at? Thanks.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4978
                  • New Zealand
                  You could check to see if that MOSFET is shorted or something. A power cycling issue can be other things too, shorted output rectifiers, bad PWM controller, bad startup circuit or run supply circuit\capacitor.
                  -David VanHorn
                  • bosscharles
                    • Mar 2013
                    • 83
                    Would I need to de-solder the mosfet to test? Or can I test while it's soldered o to the psu? Thanks.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4978
                      • New Zealand
                      You can test for shorts in-circuit, for anything else you have to desolder.
                      -David VanHorn
                      • bosscharles
                        • Mar 2013
                        • 83
                        Hi everyone. Right well I replaced the two mosfet's on the back of the board and the problem remains. The trickle charge led light works fine and turns on when plugged in. When power is pressed, LEDs 2 and 3 flash, fans spin a bit and then they go off and we are back at only led 1 on. Can anyone give me an idea of what to try out next? I actually have a supply exactly like this one that works. Anything I could compare using my multimeter to track down the problem component? I'm guessing there is some capacitor causing trouble...they all "look" fine though. I have used a working suply in this imac and everything fucntions properly so nothing wrong with GPU or logicboard. Any help would be appreciated.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4978
                          • New Zealand
                          Could be a shorted\leaky rectifier on an output somewhere. That would be the easiest thing to check first at least.
                          -David VanHorn
                          • bosscharles
                            • Mar 2013
                            • 83
                            What does it look like? Can yuo pinpoint it on the photos I'va attached? thanks,
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4978
                              • New Zealand
                              Most likely the diodes mounted on heatsinks in TO-220 packages. There may be some big single diodes too. If you follow the traces from the output power connector, you will find them easily. There will be capacitors and inductors between the output and the rectifiers. The other side of the retifiers will be the secondary windings of the main transformer.
                              There will be at least one diode (usually a pair) on each voltage rail.
                              http://www.giangrandi.ch/electronics.../smpsfix.shtml
                              http://www.repairfaq.org/sam/smpsfaq.htm
                              Might help you too
                              -David VanHorn
                              • dj_ricoh
                                • 2073
                                • uk
                                those !
                                bend over the board and desolder the legs.
                                solder pump or wick.
                                check with meter on continuity test so it Won`t touch the pad and check the FET.
                                this is a solution so you wont have to take the heat sink out.
                                good luck!
                                • bosscharles
                                  • Mar 2013
                                  • 83
                                  Thanks dj_ricoh! So you've worked with this type of PSU in the past? I tried to power it on earlier today and lo and behold it powered on! it was fine for a while... let it go into sleep and when I tried to get out of sleep it beach balled. I then tried to power on again and it starts up, 2 diagnostic leds on then the third briefly comes on... then the apple chime sound starts and it cuts out mid apple chime....diagnostic leds then go back to only first on... then second goes on... chime, 3rd led on, chime cuts..... it then loops doing this over and over again.....rest of imac is fine... I-ve got it to work with another known working PSU....... Im no expert but It's almost like there is an under voltage protection of some sort? The chime cutting out seems to be exactly when you would expect the LED panel to turn on... perhaps it's not getting enough juice? Would this point more towards a capacitor problem? Thanks for your help!!!
                                  • bosscharles
                                    • Mar 2013
                                    • 83
                                    Well today it won't even try to power on.... only led 1 on.... sometimes get 2 on.....ticking like noise coming from psu
                                    • Toasty
                                      • Jul 2007
                                      • 4171
                                      Replace the 2 small start-up caps to the right of the large transformer in Post 16. One brown sleeve, the other black.
                                      T
                                      veritas odium parit
                                      • bosscharles
                                        • Mar 2013
                                        • 83
                                        I'll give that a try Toasty. I've ordered some replacements... there is a 63v 47uf and a 50v 47uf..... I destroyed the 63v capacitor while removing it but managed to leave some nice holes on the pcb! The 50v I managed to remove intact. Checked it with my capacitor tester and it read 49uf so looks like that one is fine.... Hopefully the 63v was shot and replacing it will bring it back. All this being said, what do these start up capacitors do? Currently I do get some voltage... the #1 diagnostic led is on and the others flash when I try to power on.
                                        • mat2k
                                          iMac 2017 PSU - shorted PFC mosfet
                                          by mat2k
                                          I am trying to fix an iMac 2017 PSU, initially came with a blown fuse and shorted PFC MOSFET (6R199P). After visual inspection and some measurements I replaced the FET with a P20NM60 and tested with 100w series lamp, and it lasted 1 second before going into dead short. The PFC controller chip (NCP1605BG) and its passives appear fine (passives measure OK), but I do not know if there is a simple way of testing the NCP1605 as I wouldn't like to blind-replace it.
                                          There was some slight blackening of the solder on the PFC controller passives so I reflowed them all with some flux. I am waiting...
                                          03-13-2025, 11:31 AM
                                        • Jane
                                          How do you test MOSFET in laptops ?
                                          by Jane
                                          I tried to use this method:
                                          Testing an N-channel MOSFET:
                                          Step 1: Discharge the Gate (turn off the MOSFET)
                                          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                          Step 2: Charge the Gate (turn on the MOSFET)
                                          Now, place the red probe on the Gate (G) and the black probe on the
                                          09-27-2024, 03:31 AM
                                        • MikeCebula
                                          Apple 24" iMac A1225 Liteon PA-3241-02A1 schematic and boardview
                                          by MikeCebula
                                          Request schematic and possibly boardview for Apple 24" iMac A1225 Liteon PA-3241-02A1
                                          Thank you,
                                          Mike
                                          11-04-2023, 10:18 PM
                                        • Nooy
                                          VGA MOSfet permanently shorted and loss of MOSfet pad
                                          by Nooy
                                          Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                          I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                          02-14-2024, 02:26 AM
                                        • Siverian
                                          LITEON PA-3241-02A1 PSU iMac 2009
                                          by Siverian
                                          I've faced a problem that my iMac does not start anymore. After a short investigation, I've found that PSU does not work and does not produce any stand-by voltage.
                                          With a DMM I've found a short on 24V line and the problem was in Schottky diode D200. Another issue that I've found is a broken n-FET on a 12V line. After removing these components the short has disappeared. I replaced the diode witр a 30CTQ060 and transistor with another n-FET (I did not have exactly the same transistor). Now PPS works fine without load on the output.
                                          10-07-2021, 09:19 AM
