Macintosh G4 M5183 PSU dead
  • SteveNielsen
    Retired Tech
    • 2327
    Someone gave me this thing and it actually worked for a couple of days just fine and I was actually a bit impressed. A bad neutral connection in the local ac mains ckt in the apartment (which has since been repaired) was causing intermittent problems and I suspect contributed to the death of the PSU, with the ac mains cutting in and out several times. Even with the computer off there are active standby things alive (or rather, WERE alive) and it obviously didn't live through the ordeal, but perhaps was gonna blow anyway. Whatever. Doesn't matter at this point, it is dead now.
    Mains fuse (10A/250V) is open. It's on a small board where what looks like a dual rectifier is, as well as two toroid coils and a few small caps and resistors, perhaps an MOV in there as well (there is so much damn glue all over things that are crammed into sardine can conditions that it's hard to tell). I checked the primary e-caps (820uF/200VDC/105c) and they seem fine but there is a dead short across the solder points/traces for one of the big caps with the cap removed. I traced it back up to the dual rectifier which appears to be a dead short on one side. I have been unable to find a schematic for the PSU. I have not removed the dual rectifier yet or checked any other components and I don't know the pinout on the rectifier.
    I must say I really don't care for how Macs are put together. They have got to be the most difficult computer types I have ever worked on, and I have worked on literally TONS of computers as a tech for 30ish years. I'm retired and have forgotten more than I've learned. I am not a Mac hater though, a working computer is a working computer to me and if it is useful and/or fun it's fine by me. It was incredibly stupid to have to remove everything from inside the top half of the case just to get the PSU out though, and getting the boards out of the PSU was even more "fun". I swear that Apple purposefully made their stuff to be difficult to repair.
    BTW, I need the 28Vdc output to power up the Studio Display that came with it. Also the onboard USB ports are physically broken so I need to use the USB ports on the Studio Display, so using a standard ATX PSU re-pinned is not going to cut it with this one.
    Okay, lay the advice on me folks. Should I be looking at additional suspect parts or could it be just a case of a primary rectifier shorting out under dirty/intermittent power main conditions?
    Apologies for the crappy pics. My wife keeps taking the camera from me before I can figure out how to get a good shot. LOL!
  • cheapie
    null
    • Jul 2010
    • 849
    Re: Macintosh G4 M5183 PSU dead
    If there was a power surge when the power came back on after being off, it could have made one of the MOVs become shorted, which would blow the fuse. Try removing the MOVs and see if the short goes away. If it's still there, I would check the rectifier, followed by the mains filter caps (X-caps and Y-caps), then finally the switching transistors.
    • SteveNielsen
      Retired Tech
      • 2327
      That makes good sense and confirms my thinking. I'll do as you suggest. Thanks. My old brain appreciates the help
      (I'm not really that old, I just have a lot of miles on me)
      • SteveNielsen
        Retired Tech
        • 2327
        MOVs are ok, short is still there. Correction in order; the rectifier is indeed a 4-lead bridge that is proving to be a bitch to get out.
          • 31165
          after you get it running,
          you need a modern linux install for ppc processor.
          the original "aimed at mac" one was yellow-dog.
          http://www.fixstars.com/en/technolog...what/overview/
          • SteveNielsen
            Retired Tech
            • 2327
            I remember Yellow Dog from long ago. I have fairly recent Ubuntu for PPC. The machine has OS X on it now which I don't mind and I'll probably keep that on the drive and use a different drive for Linux if I decide to go that route. I was honestly impressed with how fast OS X runs on it even with only 128MB RAM.
            • SteveNielsen
              Retired Tech
              • 2327
              I need a better solder sucker. I finally got the bridge rectifier out and it is a dead short between the - and adjacent ~ leads. It's a KBU805G, 8A, 600v. Now to find one and a 10A 250V fuse. Anything else I should check while I'm in here that may have blown? I see some heat discoloration near one side of the large heatsink on the big board but none of the components there are discolored or appear visually damaged.
                • 31165
                solder suckers work much better if you put a bit of hellerman-sleeve on the end to improve the seal.
                the one you want is "H30X25"
                • SteveNielsen
                  Retired Tech
                  • 2327
                  Thanks for the tip. It's just a hand operated spring type and I'm going to build myself a small electric sucker one of these days. Either that or duct tape the cylinder from another (broken) hand operated spring loaded sucker to my vacuum cleaner.
                  The bridge rectifier is kind of hard to find. The closest thing I can find so far is:
                  http://www.amazon.com/FAIRCHILD-SEMI...ctifier+bridge
                    • 31165
                    it's the handheld piston type pumps you put the sleeving on.
                    • SteveNielsen
                      Retired Tech
                      • 2327
                      Thanks again stj. Noted.
                      The bridge rect and fuse replacement did the trick and the Mac G4 is up and running now. I probably oughta see about repairing the on board USB jacks. OS X 10.2.8 is running and seems ok but I've got another pata drive I can put in it and install linux and see how that does. The thing came with only 128MB SDRAM but I've got it up to 512MB with some old memory I had. I am surprised how quick this old box is. Last time I saw one was about 4 years ago in a high school lab when I worked for the school district here.
                      The monitor works great but is missing the stand so I'll have to figure something out to correct that.
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        I tried installing a handful of various Linux distros (Ubuntu 12.04 for PPC, Ubuntu 12.04 Alt for PPC, Kubuntu 12.04 for PPC, Kubuntu 12.04 Alt for PPC, Kubuntu 10.04 Alt for PPC, and Lubuntu 13.04 for PPC). All of them failed to complete the install save Lubuntu but it was incredibly slow compared to OS X 10.2.8 (which is Unix in a Mac GUI). OS X works fine on this machine and I'll leave it for now. My only potential concern is the inability to reinstall OS X since I don't have and will not pay for an OS X disc from Apple. The best I could do at this point is to image the entire disk in the event of needing a re-install, unless someone has magic to create OS X install disc from an active installation or some other solution.
                          • 31165
                          you can install 10.5.6 from what i can see.
                          the iso is available on the mule.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5022
                            • New Zealand
                            Make sure you don't forget to clean it out from time to time. I find that mine becomes slow and stops sucking well when it gets dirty. When I clean it out I also spray some WD40 up into it. Works great and the difference is very noticeable.
                            -David VanHorn
                              • 31165
                              yea, i do something like that, but use better thicker oil.
                              only problem is it slams up so fast that i shattered 2 e-clips and had to pick the plunger up from the other side of the room.
                              if you intend to lube the pump, it's a good idea to put a rubber washer/o-ring onto the plunger shaft just before the e-clip to absorb the impact as it slams to a stop.
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5022
                                • New Zealand
                                I don't think mine goes fast enough to do that. It's one of these: http://jaycar.co.nz/productView.asp?...SUBCATID=953#1 (Well, not exactly. Mine was from Dick Smith and is a brass colour)
                                Can't see any way to remove the plunger and I don't see clips of any kind on it anyway.
                                -David VanHorn
                                  • 31165
                                  sometimes the plastic pulls off the top of the plunger.
                                  if you pull the section out behind the spring, like when you clean it,
                                  then take the top off the plunger and let it drop through.
                                  hold the button in when you do or a spring will throw the button on the floor.
                                  btw,
                                  mine's an Antex pro unit.
                                  http://www.ekt2.com/products/product...4-6994fa9f1305
                                  it has a wider body & bigger spring and the piston has 2 o-rings instead of the usual 1
                                  • SteveNielsen
                                    Retired Tech
                                    • 2327
                                    What is "the mule"?
                                    I clean the solder sucker out frequently and lube it using petroleum jelly on the big o-ring. It works fine for what it is but it's a smaller type, the cylinder is only about 3" deep. For some things I would rather use an electric pump type, not to get more suction but to get longer duration of it.
                                      • 31165
                                      http://emulemorph.sourceforge.net/
                                      http://www.emule-project.net/home/perl/general.cgi?l=1
                                      • SteveNielsen
                                        Retired Tech
                                        • 2327
                                        Ok, thanks. I don't do peer-peer file sharing though.
                                        • _AcE_
                                          JBL Soundbar 2.1 Deep Bass PSU No DC Power Output (Detailed, w/ Schematics)
                                          by _AcE_
                                          I have two of these soundbars, both with the exact same issue. The soundbars were hit by lightning and no longer power on. The PSU does not output any voltage on the DC side. When plugged into mains, the DC output is a stone-cold 0.0 volts. The AC side of the PSU seems to be functioning correctly (as far as I can tell). When checking the plugged-in PSU with my thermal camera, the OB5269CP PWM controller (U1) and the two resistors (R12 and R13) pulse on and off. These run to the positive DC side of the bridge rectifier (among other components along the way).
                                          There's no physical damage...
                                          08-10-2025, 09:27 AM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • sicilianul
                                          Palit RTX2080 Super TU104-450-A1 DEAD or Alive ?
                                          by sicilianul
                                          I have this VGA from a customer. He said that the card worked for ~3 months, it was brand new at that time. In one day were some current intreruption from main powerline and the gpu stopped to work. He put the video card back in box but never send'it to warranty. And after 3 years here it is.
                                          After some measurements - see photo - and both bios reflashed, the video card still not working. The GPU is getting hot very quickly, all voltages are normal, except one coil - L4L5 - which has 0V and strange 10M ohms. Also no visual damages or liquids present. One...
                                          07-10-2023, 07:34 AM
                                        • nicktasios
                                          Macintosh Quadra 840AV PSU
                                          by nicktasios
                                          I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
                                          12-22-2024, 05:07 AM
                                        • markuss!
                                          Asus X555LJ somewhat alive/dead
                                          by markuss!
                                          Hello!
                                          This laptop has had a rough time by it's owner (my cousin ), I was told that it was spilled with coke several times, but how it continued to work is a mystery. Last year I was told that the laptop turned off under load and I confirmed the same thing. I had stuff to do and I left it in a corner. Months later I tried turning it on, but nothing was powering on. I took out my multi meter and I found out that the dedicated Nvidia GPU has a short to ground by putting positive multi meter probe on the GPU power coils and negative probe on the ground screw. I removed the GPU power coils,...
                                          12-15-2022, 01:29 PM
