Cable voltage loss
  • Maxxarcade
    • Jul 2006
    • 973
    Cable voltage loss
    I am installing a CCTV system with 4 cameras, which will be run from the computer's PSU. The siamese RG-59 cables for the cameras have 18 guage wires for the 12v dc, and I was wondering how much voltage drop I would likely have on 20-50 feet of wire if the cameras draw 400ma.
    Should I use an inline fuse for each wire run, or will the PSU shut down if a short occurs at the far end of the cable? I figured it might melt the wires and start a fire if there is enough resistance in the wire
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Cable voltage loss
    Using the wire table here, I figure your voltage drop will be ~.1V-.25V. Damage due to a short will depend on your P/S's current limit (or power limit) point. AWG #18 should handle 10A-12A without getting too hot, maybe more.
    PeteS in CA
    • MixMasta
      • Feb 2006
      • 142
      I hate to say it, but the Antec power supplies with the external 4 pin molex power connector would be nice for something like this...
      • Maxxarcade
        • Jul 2006
        • 973
        Looks like I'm good to go with the new system.
        Got the 8 channel DVR card installed, and I'm going to make a 12v dc bus on the back of the case using a 16 terminal barrier strip. This will give me enough room for 8 camera dc outputs, individually fused at 750ma or so.
        The poor old Athlon 1400 gets brought to it's knees when using all 8 inputs at anything more than 5 frames per second each I'm gonna see if I can get my hands on an Athlon XP 2100+ Palomino for the old Shuttle AK31 motherboard.
        Also thought it was crazy when I saw all the shared IRQ's on the BIOS list... The DVR card adds 16 devices Then there is the LAN, Video, USB, IDE, and a couple other things. Every single IRQ has at least 2 or 3 things on it. Thankfully Linux doesn't care too much.
        In fact, this is the third motherboard and second DVR card I've had in this system, and I haven't even had to repair or re-install the OS
        • shadow
          • Feb 2007
          • 732
          That is pretty impressive!!
          • emeskay
            Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
            by emeskay
            We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
            08-06-2024, 07:13 AM
          • Fernon@Repair
            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
            by Fernon@Repair
            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
            VCCIO voltage ok
            VCCSA Voltage OK
            VCCPLL Voltage OK
            Ram Voltage ok
            RamVTT OK
            VPP 2.5 OK
            But No Core Voltage
            and i want to this vrm ic datasheet or pinout (ISL69269)
            anyone have this ic pinout voltages?...
            06-25-2025, 07:19 AM
          • electron_jj
            Panasonic TH-L42D25A checking the PSU output voltage
            by electron_jj
            Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
            I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
            08-29-2021, 08:13 AM
          • mon2
            A1466 Macbook Air (Liquid damage repair)
            by mon2
            Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
            Macbook AIR Model A1466 Diagnostic 09-01-2021
            Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
            Problems & Resolutions
            1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
            09-01-2021, 09:31 AM
