Cable voltage loss
  • Maxxarcade
    • Jul 2006
    • 973
    Cable voltage loss
    I am installing a CCTV system with 4 cameras, which will be run from the computer's PSU. The siamese RG-59 cables for the cameras have 18 guage wires for the 12v dc, and I was wondering how much voltage drop I would likely have on 20-50 feet of wire if the cameras draw 400ma.
    Should I use an inline fuse for each wire run, or will the PSU shut down if a short occurs at the far end of the cable? I figured it might melt the wires and start a fire if there is enough resistance in the wire
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Cable voltage loss
    Using the wire table here, I figure your voltage drop will be ~.1V-.25V. Damage due to a short will depend on your P/S's current limit (or power limit) point. AWG #18 should handle 10A-12A without getting too hot, maybe more.
    PeteS in CA
    • MixMasta
      • Feb 2006
      • 142
      I hate to say it, but the Antec power supplies with the external 4 pin molex power connector would be nice for something like this...
      • Maxxarcade
        • Jul 2006
        • 973
        Looks like I'm good to go with the new system.
        Got the 8 channel DVR card installed, and I'm going to make a 12v dc bus on the back of the case using a 16 terminal barrier strip. This will give me enough room for 8 camera dc outputs, individually fused at 750ma or so.
        The poor old Athlon 1400 gets brought to it's knees when using all 8 inputs at anything more than 5 frames per second each I'm gonna see if I can get my hands on an Athlon XP 2100+ Palomino for the old Shuttle AK31 motherboard.
        Also thought it was crazy when I saw all the shared IRQ's on the BIOS list... The DVR card adds 16 devices Then there is the LAN, Video, USB, IDE, and a couple other things. Every single IRQ has at least 2 or 3 things on it. Thankfully Linux doesn't care too much.
        In fact, this is the third motherboard and second DVR card I've had in this system, and I haven't even had to repair or re-install the OS
        • shadow
          • Feb 2007
          • 732
          That is pretty impressive!!
          • emeskay
            Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
            by emeskay
            We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
            08-06-2024, 07:13 AM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • Fernon@Repair
            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
            by Fernon@Repair
            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
            VCCIO voltage ok
            VCCSA Voltage OK
            VCCPLL Voltage OK
            Ram Voltage ok
            RamVTT OK
            VPP 2.5 OK
            But No Core Voltage
            and i want to this vrm ic datasheet or pinout (ISL69269)
            anyone have this ic pinout voltages?...
            06-25-2025, 07:19 AM
          • electron_jj
            Panasonic TH-L42D25A checking the PSU output voltage
            by electron_jj
            Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
            I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
            08-29-2021, 08:13 AM
            ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
            3+1 Voltage Regulator for IMVP-7/VR12 CPUs
            Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
            core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
            configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
            serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
            Based on Intersil's Robust Ripple Regulator...
            11-05-2024, 03:24 PM
