Dead Dell All-In-One PS
  • GoneGault
    • Sep 2013
    • 105
    I have a Dell All-In-One with no signs of life. I have 120ac coming into the power supply, with no dc volts coming out. It has a proprietary 18pin atx connection, and a replacement ps costs more than the computer is worth. I see no obvious bloated caps or burn spots on the power supply board. Space is tight and power supply appears to be harder than average to work on. Output voltages are marked on the power supply board.
    Question: as long as I match up the voltages and jerry-rig a connector, can I use a regular atx power supply to test the computer?
    2nd Question: I have repaired a decent number of power supplies, lcd tv's and monitors. Should I attempt to repair the power supply?
    Re: Dead Dell All-In-One PS
    Are you getting 120VAC on the two inner pins of the bridge rectifier?
      • 31246
      under the chip in the upper left corner, someone has made a mess of the soldering.
      an atx supply should be o.k. - compare the pinout - you may be able to just plug it in with the side of the connector overhanging.
      check the pinout first though.
      other than that, get datasheets for the chips - look for startup capacitors and change them.
      and see what's hiding under the heatsink.
      • GoneGault
        • Sep 2013
        • 105
        Budm, if the bridge rectifier is in red in this picture, the two inside pins have 0 voltage.
          Sounds like you have blown main fuse.
          At the AC inlet, the center pin is Ground, the other 2 pins when you use Ohm meter between one of the inner pins of the bridge and one of the pin of the AC inlet, it should show <1 Ohm, do the same test on the other pin of the inlet, it should also show <1 Ohm. Basically each of the AC inlet pins (Hot and Neutral) should have continuity to the two inner pins (AC1, AC2) of the bridge.
          The fuse may be cover with black shrink tubing.
          • GoneGault
            • Sep 2013
            • 105
            Budm, you are right...the main fuse is blown. I have order replacements and will report results when they arrive.
            • GoneGault
              • Sep 2013
              • 105
              I replaced the main fuse; it immediately blew again. I then used a fuse with a higher amperage and it also blew.
              • c_hegge
                • Sep 2009
                • 5219
                That always happens. Fuses never blow without something else causing it to blow. Sounds like you might have a shorted PFC transistor and/or coil.
                • Andreas_de
                  Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                  by Andreas_de
                  Hello!
                  i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                  Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                  Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                  04-12-2025, 10:38 AM
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                • Info13
                  Dell H235P-00 Power Supply Failure
                  by Info13
                  A H235P-00 power supply unit from a Dell Optiplex 760 PC is faulty.
                  After removing it from the computer, I placed a paper clip between the green and black wires, then connected it unloaded to the mains through a series lamp.
                  ➡️ First test:
                  The PSU partially works: the green indicator LED lights up, and the fan starts for one second, then stops.
                  A click can be heard at the moment it stops. The series lamp lights up when the power supply starts, then turns off when it shuts down.
                  I then followed the advice from the forum and replaced...
                  10-22-2025, 01:52 PM
                • gugutm
                  Dell Latitude 5410 dead help please.
                  by gugutm
                  hi everyone,
                  need some advice i am not professional just junior , but maybe someone could help me please
                  i have
                  Device : Laptop
                  Brand : DELL
                  Model : LATITUDE 5410
                  Board Number: FDZ41 LA-J371P Rev:1.0
                  i am attaching schematics and board view. [MOD EDIT] Link to schematic - https://www.badcaps.net/forum/troubl...14#post3484414
                  my problem is its not turning...
                  08-28-2025, 02:24 PM
