what determines power rating?
  • bruceyang
    • Apr 2014
    • usa
    I am trying to down tune the output voltage of a 90w 4.5amp 20v lenovo power supply.
    If I down adjust it to 12v, what would be the power rating? I am hoping it stays at 90w and the output current can reach 6amp.
  • dmill89
    • Dec 2011
    • 2534
    Re: what determines power rating?
    The switching transistors and output rectifiers are rated in amps so the maximum amperage is can output is not going to increase with the same components in place (it is possible that the components are over-spec'ed and it can do more than 4.5A but what ever the true max amperage is will stay the same regardless of output voltage). 4.5A at 12V is approximately 55w.
      If you try to draw 6A through the output rectifier diodes, since the Vf of the diode is basically constant, lets say 0.9V (you need to look at the spec) so at 4.5A it will dissipate about 4W, but if you draw 6A, then the power dissipation will be 5.4W, so the heatsink, the diode , the transformer winding, the capacitance of the output filter caps must be design to handle more current through the device. The primary will not be affected because it is designed to be able to supply 90W at the output side.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • _AcE_
        JBL Soundbar 2.1 Deep Bass PSU No DC Power Output (Detailed, w/ Schematics)
        by _AcE_
        I have two of these soundbars, both with the exact same issue. The soundbars were hit by lightning and no longer power on. The PSU does not output any voltage on the DC side. When plugged into mains, the DC output is a stone-cold 0.0 volts. The AC side of the PSU seems to be functioning correctly (as far as I can tell). When checking the plugged-in PSU with my thermal camera, the OB5269CP PWM controller (U1) and the two resistors (R12 and R13) pulse on and off. These run to the positive DC side of the bridge rectifier (among other components along the way).
        There's no physical damage...
        08-10-2025, 09:27 AM
      • bauto601
        KDM 480W PSU upgrade succes! (opinions?)
        by bauto601
        Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
        A "nice" YoungYear unit? - Badcaps
        The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
        12-26-2023, 03:05 PM
