I have a quite new Sumvision PXPRO800 ATX PSU. I apparently over-loaded it, even though my calculations said it should be fine, which resulted a bang, a flash and some smoke.
It took a little while to find anything obviously burned-out but hidden under the hot-side heat-sink was a burned out resistor (R7). The middle band was almost completely gone but my best guess was it was 2K7 so I replaced it and it (optimistically tried powering up) - it promptly burned-out again.
Some further inspection revealed that R4 appeared to be cracked and although it was marked as 1-ohm it was actually O/C.
While I had the power transistors off-board I tested those, the Q2 (marked FQPF2N60C) seemed to be ok (MOSFET DMM test only) but Q01 and Q02 (both marked as 3DD13009) had both gone S/C B to C.
Replaced Q01 and Q02 with MJE13009's, replaced R7 (again) and R4.
Now, the +5SB line comes up but that's all, it won't otherwise turn-on. Very similar to another thread I've just looked at - this PSU also uses a 339 chip and a 7005 chip for control.
I removed the output ferrites L1 and L2 to get at the cold-side heatsink, then the 4 pairs of Schottky diodes - they all tested ok.
(Edit to add - PCB is marked ATX-1000 and SH10022 by Xinhuida Electronics Co. Ltd.)
This is my first attempt at an ATX PSU, and I'm a little out of practise in general, so any suggestions as to where to go next would be very much appreciated.
Regards,
- jarsudsco
Regards,
- jarsudsco
