CyberPower UPS
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    CyberPower UPS
    I have a CyberPower UPS from Costco. Works fine, but every time my refrigerator (some cheap shit from Target, doesn't use a lot of power) turns on at least one of my three Samsung monitors turns off and on again. The computer never crashes it has a bigger power supply that is not affected, but it's just annoying.
    The refrigerator is not on the UPS, but the entire computer set up including the monitors is. I have looked in the CyberPower PowerPanel Personal Edition that came with it, it does not customize how senstivie the UPS is, which is annoying - APC can do this??
    Another thing I might consider is replacing the power supplies of the monitors with something better but I really don't feel like spending the money or time to do that when there is nothing wrong with these, and they are geniune OEM Samsung supplies that came with the monitors!
    Any input is appreciated.
    Thanks!
    PS: I'd rather have CLICK, BEEP, CLICK than the monitors turning on and off. I don't know why!
    Re: CyberPower UPS
    I am curious if you have just the monitors hook up to the UPS and nothing else, then simulate the lost of power by pulling the cord on the UPS and see if the monitors will still cycle on and off when it switches to batteries mode.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Re: CyberPower UPS
      I know for a fact that if I pull the plug on the UPS the monitors have no issues. It's only when the fridge goes on which is not sensitive enough to trigger the UPS which is my problem. I think it has to do with the speed at which the UPS kicks in.
        Re: CyberPower UPS
        I think when the fridge kicks on, the line voltage drops below the Voltage regulation capture range which will cause the UPS to go into battery mode. What is the model of this Cyber power? It should have transformer tap switching to try to regulate the output voltage, but when it goes beyond the capture range, it will go into battery most, most of them has 2 boosted taps, and one buck tap. If it does beep, then it is on battery mode, tap switching mode will not make the UPS to beep (my does not). May be during the tap switching is what causing the output to drops enough to black out the monitors. If you have VARIAC you can then try varying the voltage feeding the UPS and you can hear the relays clicking when it does the tap switching and then you can see if the monitor will go ON/OFF, that is one way I can think of simulating the cause of the problem.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Re: CyberPower UPS
          Taps?
            Re: CyberPower UPS
            The transformers in the UPS has multi-taps on the transformer which is how it regulated the AC out put to be at 120V (+/-5V is typical) by boosting or bucking. The spec sheet of the UPS will tell you what the capture range is for it to maintain 120V output, when it can no longer regulated when the AC input is beyond the capture range, the it goes into batteries mode. The manual should indicate if it has AVR function or not.
            http://www.cyberpowersystems.com/pro...t-lcd-ups.html
            http://www.cyberpowersystems.com/pro...mageI=#tab-box
            Automatic Voltage Regulation - AVR technology stabilizes the AC voltage and maintains a safe voltage level without switching to battery-mode. This conserves battery life, and delivers cleaner AC power to connected equipment.
            AUTOMATIC VOLTAGE REGULATOR
            The CP850AVRLCD / CP1000AVRLCD stabilizes inconsistent utility
            power. The incoming utility power may be damaging to important data
            files, but with Automatic Voltage Regulation, the computer will not
            experience damaging voltage levels. An Automatic Voltage Regulator
            automatically increases low or decreases high voltage to a consistent,
            computer safe 110v/120v. The unit’s powerful sealed lead-acid
            batteries will provide power only if the incoming voltage drops below
            90v or increases above 140v.
            See post 11, 12 https://www.badcaps.net/forum/showth...wer#post373068
            • domas
              News Hater
              • May 2013
              • 323
              • Denmark
              Re: CyberPower UPS
              make sure your monitors are not plugged in "surge only" outlet.
              whats the exact model of your ups?
                Re: CyberPower UPS
                Any follow-up on this? Is the problem solved?
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  Re: CyberPower UPS
                  Sorry I was awaiting some two prong adapters from Amazon to put the monitors on their own UPS on their own outlet. If this does not resolve it I will post here.
                  The UPS has AVR but obviously it is just false advertising or else I would not have this problem!!http://www.cyberpowersystems.com/pro...350avrlcd.html
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    Re: CyberPower UPS
                    Well, knock on wood, now that i set it up all nice, my monitors no longer have problems even when the refrigerator turns on. YAY Thanks to all who helped.
                    I have however reached out to cyberpower regarding how to increase tolerance from 90v to 100v as that would make me feel safer about the voltage dips to the connected devices. I hope this is possible, as I know that my old APC UPS can customize this setting, I don't know why a nicer new unit couldn't do that...
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      Re: CyberPower UPS
                      Guess I didn't knock on my desk hard enough - still having the problems.
                      The only thing hooked up the UPS on the battery ports, are my computer and the three monitors.
                      On the surge only ports, I've got my pair of computer speakers and a hard drive dock. That's it.
                      I'm definitely not overloading the unit. But it doesn't seem to notice the problems
                      The monitors only go out half as much as before, but it's still annoying! I kind of understand how you described the transformer taps, however I am not going to take a brand new, under warranty UPS apart to look at it, especially because there's no way I could fix it even if I did.
                      I bought three of these UPS units, I am having a problem with one of them, where it smells bad and whines while it's plugged in. When it's operating on battery it's fine. Should I bring it back to Costco?
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5016
                        • New Zealand
                        Re: CyberPower UPS
                        If you get a UPS get a decent one. The cheap ones (like almost all other damn cheap electronics) are prone to blowing up.
                        -David VanHorn
                          Re: CyberPower UPS
                          So from the screen shot, it looks like it did not detect any Power Outage/Under Voltage/Over Voltage/Boost mode at all, and yet the monitors still black out.
                          COSTCO has pretty good return policy.
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            Re: CyberPower UPS
                            If it blew up at least I could make a big fuss to CyberPower. Right now it's not that it isn't working just it's not sensitive enough!
                            • shovenose
                              Send Doge Memes
                              • Aug 2010
                              • 6575
                              Re: CyberPower UPS
                              Problem is if I exchange it for another one, I will have the same problem. And I do not want a refund because then I won't have a UPS!
                              First world problems.
                              • mariushm
                                • May 2011
                                • 3799
                                Re: CyberPower UPS
                                Refund and GET A BETTER ONE UPS.
                                • shovenose
                                  Send Doge Memes
                                  • Aug 2010
                                  • 6575
                                  Re: CyberPower UPS
                                  They don't have a better one.
                                  • cheapie
                                    null
                                    • Jul 2010
                                    • 849
                                    Re: CyberPower UPS
                                    You don't have to shop there.
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      Re: CyberPower UPS
                                      I don't want to pay more.
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 5016
                                        • New Zealand
                                        Re: CyberPower UPS
                                        Perhaps, but if it took your computer with it? I know a guy on another forum who used a cheap UPS which blew up and he lost that plus $1500 worth of computer.
                                        The real good UPS brands don't do that, and if they do, the company will pay for anything that gets damaged.
                                        We all know how bad cheap PSUs are. A Cheap UPS is not that different.
                                        -David VanHorn
                                        • iMic
                                          Vintage AT Power Supplies - Selecting Capacitors
                                          by iMic
                                          Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
                                          The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
                                          02-19-2023, 06:45 PM
                                        • Sean Devine
                                          Cyberpower 1285AVR (CP1285AVRLCD) reporting wrong battery voltage?
                                          by Sean Devine
                                          UPS turned off one night and it seemed that the 3 year old batteries gave out.
                                          Replaced with a new pair, but the UPS software claimed the battery voltage was only 18 volts and needed to charge. After 24 hours, the UPS claimed only 60% charge and 20 volts (although FWIW, my meter sees 27v).
                                          ...then I found various Cyberpower threads here with some guidance on what to check.
                                          C1 (22uF) tested at 2, so I replaced that.
                                          Put it all back together and didn't see a change on the reported battery voltage. Although, I did run the quick battery diagnostic...
                                          03-03-2025, 08:23 PM
                                          20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                                          by sam_sam_sam
                                          I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                                          At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                                          Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                                          04-09-2023, 08:04 PM
                                        • quickname
                                          Cyberpower 1500AVR UPS repair
                                          by quickname
                                          I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                          Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                                          I decided to verify that the batteries were...
                                          11-12-2023, 09:57 AM
                                        • Th3_uN1Qu3
                                          Cooling upgrade on refrigerator. If it works, it ain't stupid!
                                          by Th3_uN1Qu3
                                          I had this refrigerator at my old folks which I noticed I would put my beer or soda in and take it out warmer than I'd brought it from the store.
                                          Now, I don't know much about refrigerators or HVAC but to me it seemed like we have a problem. I threw a thermometer in... 20 deg C in the fridge. WHAT THE... Freezer worked fine with temperatures way below zero, as it should, and it has only one compressor for both sides so it got me scratching my head for a while.
                                          Only other things that seemed a bit odd was that the heatsink on the back was barely warm and the...
                                          09-03-2023, 06:29 AM
