20v / 2A SMPS for a Battery Charger - Explanation of Blown Resistors Please..
  • reessi
    • Jan 2016
    • 327
    My friend asked me to replace the wire going from this SMPS 20v adapter to the charger for a 18v Lithium Battery for a drill.
    The cable had frayed and been touching, as a result the 5 Paralleled R200 (0.2 ohm) resistors had blown O/C, they are connecting the main -ve rail to the output wire.
    The output was jumping around 13v and dis-appeared when a load like the charger was connected, they measured 900ohms.
    I experimented by replacing at first a single 0 ohm and then a 2.2ohm in and the output was restored at 21.62v and 21.65v respectively so negligible difference.
    I know I can buy the correct ones but would like to understand what they are doing and why 0.2ohms was picked and whether I can just pop in 5 x 0 ohms or anything small like 5 x 2.2ohms in.
    There is another single resistor coming off the negative wire to the feedback circuit I believe.
    I know the test resistor in the picture is too small and would fit the correct size for the current when I replace them.
    Many thanks.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    probably current limiting, and rather psu blow than battery blow...
    Use the correct resistance.
    • reessi
      • Jan 2016
      • 327
      Fair enough. I was thinking if it wasn't for a battery charger I would just fit what I had on hand.
      Interestingly it is noted that although the adapter states 20v it outputs 21.65v. But for the 18v lithium battery to be charged correctly you would need 5 x 4.2v = 21v anyway. So I am assuming that voltage output is correct.
      I have also just noted that in the charger end there is another bank of 5 x R300 resistors on the same rail with similar looking feedback.​
      To be fair I was thinking it was for the voltage feedback but the current makes more sense.
      • reessi
        • Jan 2016
        • 327
        So another thing that doesn't make sense is that the block states 55w 2A and 21v * 2a is 42w at least. But these 5 SMD resistors cannot be at least 10W each!!!
        So how can this be... When I look them up to buy, a lot are rated at 1 or 2 w.. they are labelled as specifically current sense resistors,
        • reessi
          • Jan 2016
          • 327
          So I looked up some more datasheets and some are saying 20a constant current but only 2w power rating, can anyone explain this.. Cheers
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            It's a resistor, power rating is how much power the resistor dissipates, not the load. When you talk power supplies you talk about input/output power consumption/generation, not of individual components. Individual components need to handle the current required to take wattage from input or pass the wattage to the output however.
            Since it's only a fraction of an ohm, dissipation of the resistor is not very high -- unless you force the voltage across it higher...
              • 31015
              you need the correct resistance, it's not current limiting.
              there is a tap from both sides going back into the circuits.
              it's monitoring the volt-drop to determine the current being drawn and then either using it to regulate the current or to control a safety shutdown.
              • CapLeaker
                Leaking Member
                • 8146
                It has to be 0.2 ohm resistors and as stj already said, it’s for current sensing and at the same time they act as a fuse as you found already out.
                • reessi
                  • Jan 2016
                  • 327
                  Many thanks for the explanation. I have ordered some 3w ones from Aliexpress.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Isn't this the definition of current limiting?
                    • harp
                      • Jun 2022
                      • 598
                      • Planet Earth
                      Voltage you put in calculation is differential voltage from one side current sense resistor and another side. Voltage is not too high if not heavy load, so for example, if you drow 1A and got 1V voltage drop over that resistor (eg. measured 21V - 20V) he will disipating 1W.
                        • Jul 2011
                        • 6039
                        Be careful about upping the current capacity of a device the choice of components for current detection is made for a reason to protect the device from major damage from misuse or major malfunction of a component
                        Especially if it is use for battery charging or for BMS protection boards I personally would be very careful about how much more capacity you would want and still protect from major malfunctions
                        • flat-earther
                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                          by flat-earther
                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                          Windows also shows ''Plugged in'' when charger is not connected.
                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                          If I let battery run out and say it has 3% Windows will...
                          06-24-2025, 09:32 AM
                        • motormayhem
                          Lenovo T460 Only Charges on One Charger
                          by motormayhem
                          Laptop Question
                          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                          05-12-2023, 01:46 PM
                        • spleenharvester
                          Milwaukee M12-18FC fast battery charger - blown TOP268EG?
                          by spleenharvester
                          I bought 5 of these chargers as parts/not working from the same seller. Upon receipt all were dead and had blown or missing 3A fuses. Upon connecting to mains I find there is +330VDC across the filter cap and nothing past that point.
                          TOP268EG is visibly scorched on all 5 units, with the scorch mark being between drain and source pins. Is this a common fault or have these chargers all been killed simultaneously by a power surge?
                          Any ideas what else might be damaged? I am in the process of tracing a schematic for these parts
                          05-07-2025, 09:35 AM
                        • RolandVossen
                          Blu-Ray player Harman Kardon BDS 277 : SMPS IC blown
                          by RolandVossen
                          I just finished a repair of this player, the symptom was that it was completely 'dead'. I created this topic so it may benefit anyone else.
                          The root cause was that one of the SMPS ICs was blown up, which was only visible after a lid on a cooling body was removed (see attached picture).
                          The PCB type number is 40-K250HG-PWD1G.
                          A service manual for the BDS 277 EU is available online (file name: BDS-275 & 277 & 575 & 577 Rev 1.pdf)
                          I replaced the TOP257EN with a type that can handle more current:...
                          05-23-2023, 02:16 AM
                          NVDC charger configuration...
                          11-05-2024, 03:28 PM
