can someone tell me why this happened? i tried the hairdryer trick on the main cap it wasn't close to the board and it wasn't on the cap that long but 2 surface mount resistors .47ohms in parallel from the positive of the main cap to the drain of the transistor caught fire and burnt up also taking out the transistor next to the rectifier on the heat sink. anyone else ever have this happen? did it heat up the cap too much and raise the capacitance and blew the transistor? or am i just an idiot and did something wrong?
tv power supply caught fire! why?
Tags: None
Re: tv power supply caught fire! why?
Bad design, those should be Flame proof (MOX -Metal Oxide type), they are being used as fuse (Fusible resistor) in case the MOSFET
shorted out. May be the SMPS IC that drives the Gate has output stuck high to fully turn on the MOSFET in stead of switching ON and OFF.Last edited by budm; 03-01-2014, 10:42 AM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
What happened is that by heating up the board the circuitry started needing higher current than usual.
And those resistors acted as fuses.Comment
what could i replace those 2 resistors with? i don't have any .47ohm surface mount resistors can i swap them out with something else i have on another board? and if so how close do they have to be?Comment
Depends what they are for, but in general no, you will need to get new 0.47 ohm resistors. I'm sure you could buy them easy, eBay should have them if you can't find them anywhere else."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
would you mind to explained more specific why the current need higher when hot? thanks. i have never hear that and i want to learn. The ESR of caps could decreased to low as I know when i test it on failed caps with hairdryer."There is no shortcut to be successful. No pain, no gain."
Best Regards
Rudi
Thank You
When components heat up, their parameters can change. An extreme example of this is an incandescent light bulb. When the filiament is cold, it has a very low resistance. As it heats up, the resistance increases to a higher value (For tungsten, about 15 times higher) and the current draw drops to a lower level. This is why lightbulbs often blow when you just switch them on, rather than during use. (high inrush current when cold)
Different components are affected in different ways. Some semiconductors have a lower resistance as they get hotter. If there is no feedback\compensation for this, they can go into a thermal runaway and blow up. I think Kiriakos GR is saying this may have been the case here."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
So it means the electronic circuit have a thermal dependent factor? that is always happened or just in case the components is faulty?"There is no shortcut to be successful. No pain, no gain."
Best Regards
Rudi
Thank You
Any circuit will change operation slightly with variances in temperature, but not usually to the point they would blow up.. that would either be bad design, faulty components, or some abnormally large temperature change.
That said, I am not an expert... Perhaps for philliesfan30m he did overheat and over-stressed an already faulty or marginal component. Or maybe it was just coincidence. I don't know.Last edited by Agent24; 03-11-2014, 06:15 PM."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
Almost every component is thermally dependent. For example diodes typically change forward voltage by about -2.1mV per degree Celsius. That means a diode running 50°C hotter will have a forward voltage 0.105V lower than normal. (The normal measurement is made at 25°C, or room temperature, typically.)
Resistors have a temperature coefficient of around 1ppm/°C to 1,000ppm/°C. 1ppm is 0.0001%. A typical resistor might be 50ppm/°C. This means a resistor running 50°C hotter will measure ±0.25% from normal measurement. This may be negligible in most circuits but can cause issues in high precision stuff such as multimeters, voltage references, oscilloscopes, etc.
Heating components up can also lead to thermal runaway, causing failure.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Thank you !! since Im still learn deeper about electronics this would make easier learn further. So sorry for other topic that I made, back to the thread !!
Last edited by senz_90; 03-11-2014, 06:52 PM."There is no shortcut to be successful. No pain, no gain."
Best Regards
Rudi
Thank You
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... -
by Jean4634Hi guys,
Trying to repair a pcb from a power supply's pool's robot ( KWADOO v.2), i can't identify the burned transistor Q3.
Could you help me ?
Thks a lot
Jean... - Loading...
