Seperate PSU's?
  • Logistics
    • Apr 2007
    • 721
    Seperate PSU's?
    I've often wanted to run a power supply only for hard drives and CD-ROM's as well as fans and then have a power supply dedicated soley to powering the motherboard and it's cards. Is this possible? I keep hearing stuff about a said rail dropping too low because an opposing rail has no load. Is this what will happen if I do this?
  • starfury1
    • May 2006
    • 1256
    Re: Seperate PSU's?
    it has been done and there are discussions around on it in both these forums and others
    Ideally you should only power MB from 1 and peripherals from the other.
    make sure both are grounded together, usally bolting them in the same case takes care of that
    but beware you never mix any + or - rails of them together.
    personally I think, if you think you need to use 2 psu your better of getting one big more powerful psu
    You need a way to switch them both on which is another consideration
    (easy enough done though)
    on the rail dropping its the way the supplies regulate the outputs by monitoring
    the output of 1 rail only (think, not sure its the 5 Volt)
    what you need to do then and is put some constant resistive load on that rail.
    there is a post on these forums that did discuss this
    would have to find it, when I do I'll post the link
    HTH
    Cheers
    • starfury1
      • May 2006
      • 1256
      Re: Seperate PSU's?
      here's one thread on it
      there is info on the net...but apply a little bit of grey matter to what you read too...some ideas might be just plain dangerous
      there is info out there on tiering the supply rails of each supply together too...
      be careful here cause it needs to be done correctly.
      Generally speaking
      if you are thinking of doing that..just buy a bigger PSU is my advice
      • Logistics
        • Apr 2007
        • 721
        Re: Seperate PSU's?
        I remember long ago on a different board I was talking about this with other users, but the purpose is to remove things like the HDD, CD-ROM's and fans because their mechanical features add garbage to the power lines of the PSU. I believe it was a thread about improving a PC as an audio transport.
        I've been through these threads and I still don't see what the problem is. The only oddity I can think of is that the PSU's might still see a piece of eachother due to the ground leads of the drives data cables, but they could be lifted.
        • 999999999
          • Sep 2006
          • 774
          Re: Seperate PSU's?
          Do not try to isloate the grounds you WANT them to have a common ground.
          The problem with audio is typically when it's analog output and the noise contaminates that, as it is a high (enough) frequency that it is not rejected so well by active DAC or opamps powered by it.
          You are not going to have the problem from the hard drives and fans as much as the larger current subcircuits like video card or motherboard, CPU power subcircuit. If you really want an audio solution just use an external DAC, like a USB type, with it's own (preferably linear) supply.
          Generally people use two supplies to split up current some, when one supply is underpowered for the whole system. In that case you would look at what division of hardware allows each PSU to run within it's capability sharing the loads as much as reasonable.
          Whether one rail drops low because it has a higher percentage load than the PSU's feedback network was designed to use for regulation, or not, depends on the PSU and exactly what you're powering. Most often that means the PSU regulates mostly from the 5V rail and will need a certain % load on that rail, a % of the load you are powering from the other rail(s), so that the rails you needed stay within tolerance.
          Generally speaking, unless you were going to power something with an unusually high 12V current, like peltier(s) or only certain video cards, you should be able to connect the PSU and if you find it is shutting off or the rails aren't balanced well, then you would add some load to the underloaded rail (typically 5V rail). Power resistors are a common load to use, but they do create a bit of heat and need isolated, ideally you would just shift the loads around so these resistors weren't needed.
          In other cases the PSU might detect an unused rail (like 3.3V), having no load, was floating too high and the PSU would shut off. In that case a far smaller load (higher ohm) resistor would be needed, which wastes less power & creates less heat so it seems a more reasonable thing to do.
          • Nagy Daniel
            Lowest possible resistance on laptop motherboard rail - Guide Table request
            by Nagy Daniel
            Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
            I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
            I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
            So, I generated a table with AI so I can...
            03-04-2025, 08:24 AM
          • Victor Moreira Silva
            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
            by Victor Moreira Silva
            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
            Well, my decice specs are the following:
            Model: Acer Nitro 5 AN517-54-55T5
            CPU: Intel Core i5-11400H
            GPU: NVIDIA GeForce GTX 1650
            Motherboard: GH51G LA-L181P Rev:1c
            The symptom:
            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
            05-26-2025, 10:49 AM
          • lefetylorant
            Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
            by lefetylorant
            Hello Everyone,
            Long story short, I got this unit for very cheap.
            I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
            I've performed some measurements:
            - 20V rail perfectly...
            09-14-2023, 05:05 AM
          • mkdj
            Acer TravelMate P214 - N19Q7 main power rail shorted to ground
            by mkdj
            Dear all,
            I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
            I have checked resistance across each of the 4 MOSFETS. I have the following readings:
            Both N-Channel Mosfets: nothing odd
            P-Channel MOSFET number 1:
            source - drain : 117 kOhm
            source - gate: 96 Ohm
            gate - drain: 117 kOhm
            P-Channel MOSFET...
            08-20-2025, 06:08 AM
          • joshAU
            Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
            by joshAU
            Hi all.
            This notebook was showing no signs of life.
            I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
            However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
            If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
            I tried replacing the MOSFET with a new one, but again no voltage on the...
            05-29-2024, 12:33 AM
