Welder not turning on - Learning
  • Olles4
    • Apr 2022
    • 63
    • Slovakia
    #41
    oh shit but i have 2.6V on curent sense pin3
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8047
      Hmm… that’s not good.
      • Olles4
        • Apr 2022
        • 63
        • Slovakia
        #43
        Hmm… that's not good.
        i used 1001 (1KOHM) Resistor for R209, should i try higher resistance ?
        BTW im measuring on Gate or Surce of the mosfet only 2.4V
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8047
          Looking at the circuits I got here, they all used 1k Ohm. You should have more voltage than that on the mosfet. So there is still something wrong somewhere.
          • Olles4
            • Apr 2022
            • 63
            • Slovakia
            #45
            okay but how should i deal with the over Voltage on Isense ?
            • Olles4
              • Apr 2022
              • 63
              • Slovakia
              #46
              im using a K9J90E mosfet the old one was K3878
              C201 is 103 2KV (10nF)
              D201 new UF4007-E3/54 old BYV26E
              R201 98.8kOhm
              R205 and R206 should be 1Ohm am i right ?
              • Olles4
                • Apr 2022
                • 63
                • Slovakia
                #47
                I found something R205 and R206 are open
                C204 15nF is a good value?
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8047
                  I can’t tell what R205 and R206 are in the schematic, they aren’t ther. Don’t change these capacitors, specifically capacitance values.
                  • Olles4
                    • Apr 2022
                    • 63
                    • Slovakia
                    #49
                    R205 and R206
                    oh I see, it’s R1 and R2 on the schematic.
                    by colour code it should be 1ohm +/-5% 2W(by size)
                    What do you think ?
                    The problem is i took down cap204 to measure it and unfortunately I broke it.. but on board I measured and it gave mi something between 15-18nF
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8047
                      These two resistors would have to be very low ohm readings. I read brown, black, silver and red = 0.1 ohm, 2% to me and are 5w carbon film resistors.
                      i think c204 is the same as c208.
                      • Olles4
                        • Apr 2022
                        • 63
                        • Slovakia
                        #51
                        its brown, black, gold, red it hard to see on the photo
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8047
                          If the third band is gold, it 1 ohm. To me it looked like silver to me. But 1 ohm is plausible too and much easier to get.
                          • Olles4
                            • Apr 2022
                            • 63
                            • Slovakia
                            #53
                            Okay tomorrow I will change it and it will run I’m pretty sure!
                            Just one thing is bothering me, c204 is a for current waveform spike suppression if I’m right, what is changing if you changes the capacitor value ?
                            • Olles4
                              • Apr 2022
                              • 63
                              • Slovakia
                              #54
                              Why do you think it's same?
                              I mean I totally trusts you 😄 just want to know
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8047
                                The size of the SMD cap is the same. Knowing that and part of the circuit, you can figure out a “range” on what voltage / capacitance the SMD capacitor was. Just download a SMD cap spec sheet from a good manufacturer and you will notice that besides the length and width, the height will change due to rating. So check the thickness of the bad SMD cap with the other one. On the pic they look the same.
                                Dont trust me too much, as I only can see whatever pictures you provide or info you give. Changing these 1 Ohm resistors for 0.1 Ohm won’t make a difference.
                                C204 is a part of a “rc filter” that suppresses transients (spikes). It is a small value cap something like 0.0001uF (that is 1000pF). Could be even a bit lower at 100pf…
                                Like I said, this cap function is only there to suppress “transients or noise” on the sense pin. Does it have to be there? Yes, but at the same time it isn’t extremely critical either.
                                  • Jul 2011
                                  • 6029
                                  This information is good to know about SMD capacitors and how to figure there value
                                  • Olles4
                                    • Apr 2022
                                    • 63
                                    • Slovakia
                                    #57
                                    Thank you thats a valuable lesson!
                                    I measured C208 and it’s 9.42nF so my guess is 10nF for both C208 and C204
                                    • Olles4
                                      • Apr 2022
                                      • 63
                                      • Slovakia
                                      #58
                                      Update:
                                      I bought 1Ohm 1W +/-5% resistors and its not working it looks like the resistance is too big, if i short the resistor to GND screw-hole it runs. Any thoughts?
                                      Btw from my perspective C204 looks like C205 by the size. C208 is way thinner.
                                      C205 is 97nF (measuring de-soldered) what do you think ?
                                      • CapLeaker
                                        Leaking Member
                                        • Dec 2014
                                        • 8047
                                        The resistors are fine. Not sure right now what to think on why it isn't triggering as it supposed to. I do know that there are a few caps where we are guessing, since the size gives usually a choice of 3 or 4 capacitance values assuming they are 50V rated. Close, but yet so far…
                                        Sometimes on these Chinese welders and plasma cutters there is a part of one circuit on one board and the other part on a different board. That happened to me on a plasma cutter I repaired a while back.
                                        • Olles4
                                          • Apr 2022
                                          • 63
                                          • Slovakia
                                          #60
                                          Alright i used 10nF capacitor and bought new resistors and it's running.
                                          What kind of thermal paste should I use between components and heatsinks ?
                                          • spleenharvester
                                            Reverse engineering of DoCreate DHJ567 handheld spot welder
                                            by spleenharvester
                                            Hello everyone
                                            I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
                                            Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting...
                                            05-08-2025, 02:52 PM
                                          • Olles4
                                            Sencor SLE 40F82M4 - not turning on - Learning
                                            by Olles4
                                            Hello people. I trying to repair my Sencor TV. No standby light, not tuning on what i found there is 6V where 12V should be and 8V where 16V should be. Any suggestion?
                                            05-18-2024, 01:40 PM
                                          • tibimakai
                                            Lincoln Electric LE31MP welder not turning on
                                            by tibimakai
                                            This is my own welder, that blew up while welding. There is no warranty on it. Purchased it a year ago, sealed box from Craigslist.
                                            It worked great until now, about a year.
                                            What I have found is a blown trace next to the main capacitors, it seems like also got damaged the SMPS IC, output MOSFET and a 1 Ohm resistor to the ground from the MOSFET.
                                            After replacing these components, the relay, fans turn on and it sounds like it's working, but there is no output voltage for the welder, LEDs do not turn on.
                                            So there are more components that are damaged.
                                            I'm having a hard...
                                            10-14-2023, 07:40 PM
                                          • nicktasios
                                            Macintosh Quadra 840AV PSU
                                            by nicktasios
                                            I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
                                            12-22-2024, 05:07 AM
                                          • drscoot
                                            HP X360 convertible battery blown fuse error, not charging
                                            by drscoot
                                            HP Modelnumber: 14-dh0061nb​
                                            This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                                            The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                                            I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                                            And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                                            All these 3 batteries are charging...
                                            12-15-2023, 05:54 AM
