PSU won´t power with fan connected
  • rogfanther
    • Jul 2006
    • 458
    • Brazil
    One interesting one :
    Fot this CoolerMaster RS-460-PCAR from a friend. He said it stopped when he transferred it from one computer to another.
    We had already gutted it from its fan to improve one of his computer´s airflow, and I had it laying in the workshop. Then, yeterday I decided to try fixing it, or at least blowing it up enough to put in the trash without remorse.
    Changed the caps for the UC 3843B, and tried it without a fan connected : voltages ok.
    Got a new fan, and installed it. Measured all wires, checked and rechecked soldering , everything ok. Try to power it up, just a twitch in the fan / voltages.
    As I had revised all my soldering, the problem had to be with something I added for last, so tried disconnecting the fan.
    The results, tested a couple times, are that without the fan, the PSU seems to work. With the fan connected, not.
    I still have to rig some old hard disks to use as a load, but if there was a 12V rectifier burnt shouldn´t the psu stop working even without the fan connected ?
    Thanks for your ideas ..
  • TELVM
    • Oct 2012
    • 547
    • Spain
    Re: PSU won´t power with fan connected
    That happened to me once when I soldered the fan with the wires reversed (+ on - and - on +) . Rearranging the fan wires solved it.
    • rogfanther
      • Jul 2006
      • 458
      • Brazil
      Thanks, will take a look,
      • rogfanther
        • Jul 2006
        • 458
        • Brazil
        (Un)fortunately, the wires are in the correce position. Measure a good 12.07V from black to red. Also, with another , smaller fan, it gives just a twitch in the 12V line then shuts down. Tomorrow will try to remove the 12V rectifieres and measure them offline.l
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          How do the leads look on the bottom of the board? Once when I was working on a PSU and plugged in the fan connector, it took some force, and since the PSU originally died from overheating, it weakened the traces, so plugging the fan back in ripped the pads on the bottom off, causing a short, so the PSU wouldn't start. Might not be the case here, but it's worth checking.
          • rogfanther
            • Jul 2006
            • 458
            • Brazil
            The original fan had just the wires soldered to the board, and as the points were too far apart for a connector, I soldered two short wires with a connector , as my new fan has a connector in it. Will redo the solder, but as without the fan connected the pins in the new connector measure correctly the 12V, I would venture the solder are correct. But thanks for the insight , it is a good thing to keep im mind with these cheap plastic connectors/psus
            • rogfanther
              • Jul 2006
              • 458
              • Brazil
              Well, from the two 12V rectifiers, SBR20100CT, one gives +- 130mV drop, other gives 117. I want to believe one of these is bad. Will have to search through the scrap pile for two similar pieces to do the testing..
              Edit : Well, no dice. Swapped the two with new ones, higher in voltage drop but I belive just for testing that should be ok ? Same thing : little twitch of the small fan, but measures voltage without fan connected.
              My understanding until now has been that something is shorted/shorting , and that fan presents just enough load for the psu to "feel" shorted. Would you agree ?
              Last edited by rogfanther; 02-05-2014, 01:11 PM. Reason: soldered some new some parts
                master hoarder
                • May 2008
                • 12170
                Without good pictures, I can't say anything for sure.
                First try to put a load on all of the rails. A hard drive or a 12V incandescent/halogen light bulb on each rail would do.
                You can also straight-wire the fan to 7V (+fan wire to 12V and -fan wire to 5V) or 8.7V (+fan wire to 12V rail and -fan wire to 3.3V rail) and not have to worry about the fan controller. In fact, this might load-balance the PSU just enough for it to start if you don't have anything else to load it with.
                Personally, I think the PSU is fine. Or at the most, there is something wrong with the fan controller. Should be an easy fix, though. The RS-460-PCAR is a decent PSU.
                If the 12V rectifier was shorted, the PSU would have never started in the first place, nor would you have seen 12V. If a rectifier is shorted and a PSU fails to detect it and tries to run, the results is usually on the primary side.
                • rogfanther
                  • Jul 2006
                  • 458
                  • Brazil
                  After a long time, I got a camera to take some pics. Not the best camera ,though.
                  I´ve marked the places where I soldered the fan cable. It seems to derive it´s feed from the -12V line and the 3.3V line. The VCC to the LM 339 also comes from the -12V line. I could not get a good angle to show that transistor markings, but it is a B772.
                    master hoarder
                    • May 2008
                    • 12170
                    You can check if there is a short circuit between E, B, and C terminals on that transistor. But appart from that, I don't think this is the problem. Like I said, try loading the PSU with something more substantial. Several bulbs - one on each rail, should do.
                      Try heating up those two start up caps using hair dryer (or just replace them) with the fan still attached to see if it will spin up.
                      How are the other 2 caps?
                      • rogfanther
                        • Jul 2006
                        • 458
                        • Brazil
                        Hi Budm,
                        Those you circled in the top are for the 5VSB, I think. The chip near them is a TNY.
                        I´ve already replaced the two to the right. That chip is a UC3843B.
                        Will have to check those two near the violet wire, though.
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                          03-31-2024, 02:12 PM
                        • survivalbloke
                          Acer Predator Helios 300 - will not power up if battery is CONNECTED
                          by survivalbloke
                          This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
                          06-25-2025, 12:20 PM
                        • playit
                          psu sata power wires thinner - does it make a difference ?
                          by playit
                          hello , i have a psu 450 zebronics (yes its bad crap) which used to work before with its own sata power cable ,but today its not able to power up harddrive efficiently with its own power sata cable , but when there is a connector which have a thick wire than the psu sata power cable wires - its powering up and working smooth , no problem yet .
                          i the voltages with multimeter shows 12 ,3.3 v , no problem , but hardrives powers well only with this thick wire sata power cable connector from psu power molex .
                          any explanation on this ?? thank you ,soon i am planning to buy some branded...
                          10-12-2023, 05:25 AM
                        • reessi
                          Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
                          by reessi
                          With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
                          No corrosion any where!
                          Tried a replacement power button off ebay and the same.
                          Very occasionally it will work with the power button connected!
                          Same results with or without the battery.
                          Can it be a fault with the Audio board or the mainboard?
                          The touch Id assembly connects through the Audio board first then to the Mainboard.
                          Flex...
                          06-26-2024, 03:31 PM
