hi..
receive this psu from friend ..he said that the psu start to on and then off immediately
being opened befere by him, i open up the case, upon inspection found that one of the component is burnt/cracked (red square marking in picture) ..after searcing, the burnt/crack component is INFINEON 6R190C6 switching transistors.
thru physical inspection to whole component i didn't find any cracked/burned component. just the mosfet above
= are this psu is still able to repair ?
= what makes the mosfet burnt ? spike/lightning/other ?
= where can i find the replacement component ?
= are the mosfet can be substitute with other type ? which one ?
= if i must measure voltage, where ?
i live in indonesia ..so hard to find quality electronic component here
[img=http://s27.postimg.org/sk5ft77kf/image.jpg]
[img=http://s29.postimg.org/nz0doe0wz/image.jpg]
[img=http://s7.postimg.org/py1uc0vxz/image.jpg]
[img=http://s29.postimg.org/ybmoagug3/image.jpg]
already had, actualy not to replace, just for testing purpose
As far as i can figure, any half-decently designed PSU should be stable (enough) with no load - that's what the minimum load resistors inside should be taking care of.
