Asus GT531GT VCORE high side mosfet pad burnt
  • IamPritesh
    • Aug 2017
    • 356
    • India
    So I have this Asus GT531GT whose pad is burnt and it shows short to ground 0.8 even after removing all the connected mosfets and capacitors.
    Image attached . The mosfet where the pad is burnt is PQH8102
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Asus GT531GT VCORE high side mosfet pad burnt
    0.8 Ohms at Vcore is very likely normal for this board.
    • IamPritesh
      • Aug 2017
      • 356
      • India
      It's on the high side ( Connected to AC_BAT+ 19V rail though jumper) I have removed all the capacitors on this line and also all the mosfets just to rule out any leaking components and the remove the solder joints of the jumper.
      • IamPritesh
        • Aug 2017
        • 356
        • India
        Any suggestion experts ?
        • dougg3
          Intel DX58SO high side VRM MOSFET keeps failing
          by dougg3
          Hi there,
          I have an Intel DX58SO motherboard that failed last year. One of the high side VRM MOSFETs failed shorted, and it killed my i7 980 CPU. This motherboard has a 6-phase VRM. The parts used on this motherboard's VRM are:
          • 6 x High side MOSFET: NTMFS4841NH
          • 6 x Low side MOSFET: NTMFS4834N
          • 6 x Driver: ADP3121JCPZ
          It was easy to figure out where the short was, because the bad MOSFET's gate was shorted to the drain/source too. Once I removed it, all the shorts were gone on the motherboard, and I confirmed on the removed MOSFET itself that the gate/drain/source...
          10-17-2021, 07:39 PM
        • c_corr
          Asus P4C800-E VRM issues
          by c_corr
          This board had the initial fault in VRM with high side Mosfet from PWM1 (phase 1) getting very hot. It also had the VRM caps quicly heating up in 10-15 seconds after power on.
          This board uses mext ICs and Mosfets in VRM:
          - ADP3180 PWM controller - in 3 phase mode
          - ADP3418 as Modfet drivers
          - High side Mosfets STD38NH02L (from ST)
          - Low side Mosfets STD90NH02L
          Some of the symptoms were very similar with the "Dead Asus P5P800-VM" in this forum.
          I had the sawtooth voltage on Vcore too this was probably the cause of the Vcore caps...
          02-08-2025, 11:59 PM
        • zwerw3
          High side mosfet of the power supply of the RTX2060 graphic chip burned out
          by zwerw3
          Hello. They brought a personal computer for repair in which the video card was GeForce RTX ™ 2060 WINDFORCE OC 6G (rev. 1.0). Graphics core power mosfet burned out.
          Is there a chance to restore the site where the mosfet was? I started to grind the mosfet substrate with a dremel, which stuck to the board, but for now I stopped and decided to ask you for advice. I also noticed dark spots on the PCB near the video memory chips. Does this mean that the video memory is out of order? I cleaned the place where there was a burnout, a short circuit of 12 V was removed. On the coils on the power...
          12-12-2022, 12:15 AM
        • conghuyms
          MSI RX580 Vcore voltage is too high, please help me !!!
          by conghuyms
          I have an MSI Armor RX580 8GB V1.3 graphics card. Currently, all power rails are present, but the voltage supplied to the GPU Vcore, which should normally be around 0.9–1V, is measuring at 1.4–1.5V. The GPU gets very hot, and the MOSFETs supplying the Vcore phases are also extremely hot, with a noticeable whistling noise.
          I’ve already replaced the UP9505P controller IC with a new one, but the issue remains the same.
          Since the UP9505P is a new IC, could it require firmware programming like some high-end graphics cards such as the RX5700XT?
          What should I do...
          08-02-2025, 11:38 PM
        • questore
          HP OMEN 15-ce012nh give error code 5long 3 short after CPU LOW SIDE MOSFET BURN
          by questore
          Hello everyone.
          Someone brought this poor hp in.
          All power rails had normal resistances so i turned it on. Instant power cutoff...
          First mosfet was shorted so replaced it...
          After that I have tryed to start since no short was on the main power rail. the CPU middle dual mosfet heated up and protection shut down the laptop.
          After investigating i have found that when the mosftet turning on then the mostfet got instantly hot (not the CPU)
          Removed the faulty mosfet. -> now laptop turns on CPU mildly gets hot but laptop gives the common 5 long 3 short LED...
          08-25-2025, 10:09 AM
