HP PSU 901760-002 identify diode
This topic has been answered.
  • kokos
    azlabgr
    • Sep 2014
    • 17
    • Greece
    Hi to all of yoy!
    I have a damaged HP PSU p/n: 901760-002 with blow up 6.3 Slow blow Fuse & an smd shorted diode with LT6B36 printed on it!
    I cannot find any info on this part.
    Any suggestions?
    May I substitude with any similar one?
  • Answer selected by kokos at 02-27-2024, 11:01 PM.
    lotas
    • Jan 2016
    • 4618
    • Russia
    This is what it is, produced by different manufacturing companies, with different logos.
    In the second datasheet it is your diode.
    • lotas
      • Jan 2016
      • 4618
      • Russia
      U3J - MURS360T3G (600v, 3A)
      • kokos
        azlabgr
        • Sep 2014
        • 17
        • Greece
        Really thank you my friend lotas.
        I was thinking that U3J is not part of identity...
        LT6B36U3J is similar to U3J - MURS360T3G ?
        • lotas
          • Jan 2016
          • 4618
          • Russia
          • kokos
            azlabgr
            • Sep 2014
            • 17
            • Greece
            You are the BEST i tried everywhere for any info without luck. Thanks again my friend!
            • hobostove
              Corsair RM1000e - Help identify 5VSB Zener diode
              by hobostove
              Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
              Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
              There's a 22ohm resistor that's melted and open, but it still has the bands.
              The other part is a zener diode and it's top went to jesus, so I can't read the marking.
              It looks like the diode connects the source and drain of a TNY284...
              03-27-2025, 02:25 PM
            • jjne
              AUO M270QAN01 - identify diode?
              by jjne
              I have a small number of monitors based on the above panel and am working through them. I have at least two with a single, burned-out diode. From what I can see it's something like DI428 or DII428 or DH428. Here's a picture of a working one.
              Can anyone identify this please? Based on the number 428 it may be a shottky or a Zener according to Google. The device in question is D105.
              ETA I can confirm that the number is definitely 428 (I took a video which revealed a better image), the DII appears to be a maker's mark. There's also a code 1G. Looking around...
              01-24-2024, 08:39 PM
            • gurj1979
              Ubiquitiu 24 port POE. Help Identify Diode 3pin)
              by gurj1979
              Hi again guys.
              Ive got a Ubiquiti 24 port POE Switch which has failed to work. Fans turn on, but no lights.
              I've ripped the board out, flipped it upside down and noticed a blown 3pin SMD Diode (at location D53). Marking is ESSP (as with all the other Diodes in the same row).
              Anyone help me identify the model of this Diode ?...
              08-23-2023, 08:39 AM
            • rddube
              Asus C423N motherboard - trying to identify diode
              by rddube
              Can anyone point me in the right direction as I am trying to identify which diode this is as in the red square.
              Many thanks!
              Ray...
              06-24-2023, 08:08 PM
            • digitalblade
              help for identify an smd diode
              by digitalblade
              I need to identify the diode on attached image. is an SMD diode on damaged board.
              As more wide question... there is a way to identify any smd component in a more or less simple way?
              Every time that i need to identify some components with no schematics is a nightmare for me!
              Thank you for any kind of support!...
              07-18-2021, 10:13 AM
