siemens sitop 24 vdc Smps outputs higher voltage 33 vdc
  • CapLeaker
    Leaking Member
    • 8351
    Originally posted by PedroGG90
    This power supply is a hell to disassemble.
    Ill try my best.
    Yes, I know... some of them are a real pain to work on. But in this case I really do think there is a regulation problem as non regulating at all on the feedback and it also does make sense for the voltage to go to the upper limit. The squealing probably comes from the switcher not switching to the designed frequency of the transformer, loaded or not.
    • PedroGG90
      بدر الدين
      • Feb 2023
      • 30
      • Morocco
      After visual inspection , I can't see any optocoupler or tl431 . Or any feedback loop.
      Only 2 optocouplers are driving signal from control board.
      • CapLeaker
        Leaking Member
        • 8351
        Something has to tell the primary to how much power is needed,
        • PedroGG90
          بدر الدين
          • Feb 2023
          • 30
          • Morocco
          I need to search more.
          • PedroGG90
            بدر الدين
            • Feb 2023
            • 30
            • Morocco
            Hi again , i found two optocouplers , one of them seems to be the feedback one , it gets activated from 2 zener diodes coming from output rail capacitor
            The other optocoupler gets activated from small control board but dont know where it goes after it.
            • CapLeaker
              Leaking Member
              • 8351
              Maybe post some pictures…
              • rewease
                Replacement for the Siemens Bakelite caps in an early 1980s SMPS
                by rewease
                There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
                Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
                Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
                09-17-2023, 12:53 AM
              • dkneyle
                Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                by dkneyle
                This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                02-01-2022, 02:08 AM
              • shamsudeen
                Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                by shamsudeen
                Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                i know that in linear power supply the noise will be very low comparing to SMPS supply....
                07-19-2025, 07:14 AM
              • Taurus12
                Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                by Taurus12
                Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                Any recommendation on what I have to do next? Thanks in advance
                06-10-2025, 05:05 PM
              • thinkcentre
                Dell Optiplex 3060 Micro USFF (IPCFL-CG Motherboard) - No LED / Short Circuit
                by thinkcentre
                this is my first post at Badcaps and in general i am new to fixing electronics. I am looking forward to learn a bit more about diagnosing and repairing :-)
                What I have around is a DELL OPTIPLEX 3060 Micro (USFF), which is not powering on, even not showing any signs of life (No amber / white LED).
                I got a original 65W DELL PSU / Power brick (PA-12 / 074VT4) which hopefull should be the correct one. I could get another DELL PSU with the Partnumber 0G6J41 with the same 4.9mm DC Jack connector as the one I already have, but I dont think that would help (maybe...
                11-09-2025, 12:39 PM
