+12V on Macron MPT-301
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Here I have a classic Macron MPT-301 (Rebranded as EVER)
    I recapped it a while ago, and back then I glanced ( ) at the alignment of the rectifiers and *thought* it used the 30A rectifier for the 12V but I looked at the traces and it actually uses just a 10A ultra fast recovery diode... What I should have done was just look at the location of the filtering capacitors. The 3.3V trace crosses over the 12V trace via the PI coil for the 3.3V rail. And I *think* the 12V rail uses a PI coil that is strangely over by the -12V wire.
    Thing is, I'm surprised it ran as long as it did. It was powering a Pentium 4 650 Prescott, 4 RAM modules, single hard drive, 915 motherboard, and a Radeon X1050 for months. When that P4 was installing updates, the PSU was kicking out an insane amount of heat, especially since it has a conservative fan controller, it doesn't spin very fast. Although I did cut out the original punched grille and replaced it with a nice wired one That rectifier might have been getting close to its max, but even at full load the voltage never dropped below 11.89V which to me means it's doing okay.
    Okay enough rambling and get to the point...Since this thing has no discoloration whatsoever, should I worry about that rectifier? Since I've been having horrible luck replacing 12V rectifiers on half bridge PSU's lately (Usually don't start up) I really don't want to keep soldering and desoldering the secondary heatsink because it pisses me off doing it more than once
    What I have are some usual MBR schottkys, some Vishay VF30100S rectifiers (which I have bad luck with) and I have a 30A ultra fast, which might be the best option, It's a BYV42E-200. What do you guys think? And sorry for the long post, here are some pics
    Overhead shot before recap:
  • Wester547
    • Nov 2011
    • 1268
    • USA.
    Re: +12V on Macron MPT-301
    In half-bridge topology, a great deal of the time, Schottkys with a 45V reverse voltage or less are not enough (60V should be minimum as a rule of thumb) - goodpsusearch shorted an ESAD83-004 in a gutless PSU (a half-bridge unit) he was rebuilding sometime ago by putting it on the +12V rail. You can get away with it in forward topology (as far as the the reverse voltage goes, the voltage it has to block when it isn't conducting is much higher) because the pulses from the transformer are usually lower in voltage in single and double forward than half bridge. Usually speaking, the rectifier with the highest reverse voltage rating is on the +12V (or -12V) rails and the ones with lower reverse voltage ratings on the other outputs (+5V, +3.3V, -5V if present, +5VSB), but yes, the underside always tells the truth. You are correct to observe that an ultrafast would work better than a schottky in a number of gutless power supplies but it wouldn't hurt to try with this one. If it doesn't work, you would probably need to replace the main transformer with another compatible one for it to work with schottky on the +12V rail. Either way, I'm sure the heat output will be improved greatly when you replace the 10A ultrafast with a 30A part.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Originally posted by Wester547
      In half-bridge topology, a great deal of the time, Schottkys with a 45V reverse voltage or less are not enough - goodpsusearch shorted an ESAD83-004 in a gutless PSU (a half-bridge unit) he was rebuilding sometime ago by putting it on the +12V rail. You can get away with it in forward topology (as far as the the reverse voltage goes, the voltage it has to block when it isn't conducting is much higher) because the pulses from the transformer are usually lower in voltage in single and double forward than half bridge. Usually speaking, the rectifier with the highest reverse voltage rating is on the +12V (or -12V) rails and the ones with lower reverse voltage ratings on the other outputs (+5V, +3.3V, -5V if present, +5VSB), but yes, the underside always tells the truth. You are correct to observe that an ultrafast would work better than a schottky in a number of gutless power supplies but it wouldn't hurt to try with this one. If it doesn't work, you would probably need to replace the main transformer with another compatible one for it to work with schottky on the +12V rail. Either way, I'm sure the heat output will be improved greatly when you replace the 10A ultrafast with a 30A part.
      Even using schottkys with 100 reverse voltage I have horrible luck, they usually don't start up. Is there something not suitable with the VF30100S? And okay I'm kind of stupid/blind From the angle I could see the rectifier while installed in the PSU, it looked like a 10 but after I desoldered the heatsink and wiped off the dust, it's actually a STPR1620CT. But still, to power a Prescott P4 system, I still don't like the idea of a 16A ultra fast there. I want to get it back in commission so I may just add the 30A ultra fast. Since the VF is lower, I assume it'll still increase the efficiency.
      • Wester547
        • Nov 2011
        • 1268
        • USA.
        It should make a tangible difference. It is baffling that the heat output was that great, though - I believe Momaka has the same power supply (with a 16A ultrafast or fast recovery on the +12V output), and with an AMD 95W TDP CPU he couldn't get it to kick out any noticeable heat even in hot weather, even at full load. Perhaps the heat is partially coming from that toasty Prescott? (or the fan in his revision of the power supply spins faster by way of a more aggressive fan controller, maybe, or his CPU fan spins faster)
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Possibly. The top of the heatsink of the Prescott is about 1 inch below the bottom of the Macron PSU. The P4 idles around 57C, and under load gets to 70C. Too hot, but it has a copper heatsink and I don't want to invest in a higher end cooler, I even reapplied thermal paste and dusted the heatsink. I know the P4 can handle the heat (it doesn't even throttle down when hitting 73C on rare occasion), and there's Chemi-Con polymers on the VRM. The 92mm exhaust fan spins very slow as well unless the P4 hits 69C, so you may be right.
          *EDIT* Worth noting: the 12V rectifier was fairly loose on the heatsink. I'm going to try an MBR20100CT
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Success! It liked the MBR20100CT and the voltage is reading a little stronger at 12.02V
            • TELVM
              • Oct 2012
              • 547
              • Spain
              Originally posted by Pentium4
              ... The P4 idles around 57C, and under load gets to 70C ... ... The 92mm exhaust fan spins very slow as well unless the P4 hits 69C ...
              I'd work on improving case ventilation, all the heat from the Preshott flamethrower is cooking the PSU.
              We need to let Preshotts know, in no uncertain terms , that we're serious about cooling for them to behave.
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                I think I may just need to adjust the fan settings in the BIOS to be more aggressive. As it is, the motherboard is pretty stupid. Until the P4 gets to that scorching temperature, the case fans are only running at 400RPM. It has a 80mm intake, and 92mm exhaust. When it gets to 69C or hotter, they rev up from 400RPM to 3,000RPM I'll also check the thermal paste.
                Oh, and......NICE HEATSINK!
                Edit: With the same amount of load, the thing kicks out noticeably less heat. I measured before and after and the exhaust temp is about 4C cooler. I'll take that as a success. When idling, the 12V sits at 12.20V, at 100% load it drops to 12.02V. I thought that was bad but I guess that's just typical group regulation. When the CPU usage is jumping up and down a lot, the 12V does bounce around quite a bit...not sure if I should worry about that or not. There is another slot on the other side of the heatsink to put another rectifier in parallel with the main one. It's being partially blocked by one of the 3.3V rails magamp coils so I'd have to extend the leads on that so the rectifier could fit.
                • goodpsusearch
                  • Oct 2009
                  • 2848
                  • Greece
                  My Macron psus:
                  https://www.badcaps.net/forum/showthread.php?t=12348
                  https://www.badcaps.net/forum/showpo...86&postcount=3 (before recap)
                  https://www.badcaps.net/forum/showpo...5&postcount=48 (my first recap )
                  https://www.badcaps.net/forum/showthread.php?t=22916
                  As you can see on the last link my treatment was to add a F16C20C in paraller with the original F16C20C my Macron had at 12V.
                  Recently I've done the same to the other Macron I own. I replaced the original F16C20C with 2 x U1620G. Both psus run perfectly fine
                  I forgot to mention that I did those improvements without removing the secondary heatsink. I avoid removing heatsinks in psus unless I have to.
                  • rogfanther
                    • Jul 2006
                    • 458
                    • Brazil
                    Little bit of curiosity : if a psu has the place for another rectifier in parallel with the already installed one, is there some other thing to take care of , or could one just add another rectifier in paralle, provided it is the same part ? I´m thinking in the lines of making a psu more stable as each diode has to work less....
                    • goodpsusearch
                      • Oct 2009
                      • 2848
                      • Greece
                      You double the contact area of the rectifiers with heatsink and double the total rectifying amperage. But the parts have to be identical. Every minor difference in the voltage drop or the internal resistance of the rectifying diodes would result in losses. I hope someone can explain it better than me
                      • domas
                        News Hater
                        • May 2013
                        • 323
                        • Denmark
                        let me ask.. how many fans have you got in there? i have honestly lost the count
                        • TELVM
                          • Oct 2012
                          • 547
                          • Spain
                          Just seven (there's also a 92 at lower front blowing on the HDD) because the ancient GPU doesn't draw much juice.
                          We need a critical mass of fans if we want hot systems to run cool & quietly:
                          Forumer Pentium4's Preshott idles @ 57C. Mine idles @ 37C, and burns @ 45C. The fans never go above 78% rpm and thus make little noise (I hate noisy comps ).
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8663
                            I don't use my PresHot anymore, I only have a cheap aluminum hs/f and IIRC is stayed around 60C... though I should check again.
                            No overtemperature problems at least. The video card, however...
                            • TELVM
                              • Oct 2012
                              • 547
                              • Spain
                              Originally posted by goodpsusearch
                              You double the contact area of the rectifiers with heatsink and double the total rectifying amperage ...
                              I know nothing but, from what I read elsewhere, assuming that two 16A in parallel will automatically grant us the full 32A total might be a bit in practice ...
                              • goodpsusearch
                                • Oct 2009
                                • 2848
                                • Greece
                                You never get the full ampere rating of those rectifiers regardless of being single or in parallel anyway.
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  Yeah.
                                  Running them in parallel is a bit dangerous, BUT, as long as they have good thermal contact to each other, they shouldn't be too much of an issue.
                                  What happens is one diode gets hotter for whatever reason, and it's resistance goes DOWN, making more current take the path through this diode, and increasing the heat even more.... thermal runaway!
                                  Muh-soggy-knee
                                  • Wester547
                                    • Nov 2011
                                    • 1268
                                    • USA.
                                    ^ That's if you parallel them without a heatsink. If they're in parallel on a good heatsink (if they're on opposite ends of the same heatsink and have adequate thermal pads), they probably won't be more than a couple of degrees apart in temperature (celsius), so it shouldn't be a problem. The reason why you won't get the full ratings is because the rest of the PSU has to be capable of it too, and often the greatest limiting factor of the PSU is how much power it can output as a whole (without the main switcher[s] exploding or the toroidal coils burning). That depends on a number of other things - how well it's ventilated and cooled, the width of the PCB traces, the ability of the main transformer, the bulk capacitance, the main switching transistor(s) and how well they're driven, the switching frequency, keeping input and output ripple and voltage regulation in spec, keeping efficiency above 70%, the core losses of a toroid in a magamp circuit, etc... all of those things translate into a lower ambient temperature if done well.
                                    More than anything, when I see a really overspec'd secondary, I think high output power rather than "there's 60A on the +5V rail!" (which isn't really true, especially if you consider how power is distributed in +12V heavy PSUs especially, as well as OCP). Really overspec'd and low VF rectifiers means the voltage drop (as a whole) on the secondary side is much lower (higher overall efficiency and less heat output), which means the main switcher(s) have to handle less load, which means more a greater maximum power output. And when I see a really anemic secondary side in terms of rectifiers, I think low output power (which is probably true, especially on lesser heatsinks). The contact area of the heatsink is important, that's also why TO-247 parts are theoretically capable of more current than equivalent TO-220 parts on the same heatsink (their thermal resistance is better, because they cover more surface area so it's easier for the heat from the rectifiers to reach the top).
                                    More on topic on my part, I think paralleling rectifiers if done properly isn't a bad idea, especially in a Macron PSU where the original rectifier was a 16A ultrafast or fast recovery.
                                    • TELVM
                                      • Oct 2012
                                      • 547
                                      • Spain
                                      http://www.techpowerup.com/reviews/F...R3_800W/4.html
                                      ^ Two 15A bridge rectifiers inside a 800W PSU, both on the same side on the heatsink . Wouldn't the external one get much hotter?
                                      • goodpsusearch
                                        • Oct 2009
                                        • 2848
                                        • Greece
                                        The bridge rectifier rarely gets even warm. I don't really get why they put heatsinks on them to be honest....
