Viper22A 5VSB circuit
This topic has been answered.
  • прямо
    • Sep 2022
    • 261
    • Indonesia
    So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
    In the process of poking around, I also lost a zener diode that stabilize the voltage coming from pin 4 of the 5VSB opto isolator, and this voltage happens to be a part of the main signal PWM switching circuit based on TL3845P. I have no idea what zener it was.
    I stopped working on it. The board sat on my shelf for 12 years, lol.
    Anyway, what I want to understand is, without the Viper22A PWM chip, I get -165V DC on its feedback and supply pins. Is this correct? Shouldn't I be getting like 15V DC, or is this only happening when the chip is installed?
    Here are some close up photos of the circuit.
    I understand that I can just bypass the entire circuit by de-populating it, and use a 5V 3A charger module tapping directly into the high voltage instead to get 5VSB.
  • Answer selected by прямо at 01-17-2024, 07:00 PM.
    temyth
    • Jan 2024
    • 45
    • Brazil
    without the zener the voltage can't be controlled so it goes too high. most part of zeners in the primary are 1N4148, try putting one and see if it changes.
    • temyth
      • Jan 2024
      • 45
      • Brazil
      • прямо
        • Sep 2022
        • 261
        • Indonesia
        Cool! I did what you suggested, and 5VSB returns.
        Click image for larger version  Name:	1000015809.jpg Views:	0 Size:	63.6 KB ID:	3178223
        Thank you!
        • прямо
          • Sep 2022
          • 261
          • Indonesia
          A side note,
          I have been repairing SMPS with a single primary cap for too long that I subconciously treating these ATX PSUs with two primary caps like it only has one cap. I did the most stupid thing: I put my negative probe at the junction of the caps!
          which is why I got a false reading of -165V DC when in fact, without the missing zener installed, it already has the correct voltage for the PWM chip, albeit not stabilized.
          But when I edited the photo, I knew exactly where the correct hot ground is, ahahahaha.
          • прямо
            • Sep 2022
            • 261
            • Indonesia
            Had to disable the fault protection to find out why it can't start.
            12V @ 16.7V
            5V @ 7.2V
            3.3V @ 3.3V
            I guess I have to check the feedback now, but at least the PSU is working again, just out of specs.
            EDIT:
            Above is with the light bulb current limiter.
            Without it, I get:
            12V @ 37V
            5V @ 15V
            3.3V @ 4.2V
            • temyth
              • Jan 2024
              • 45
              • Brazil
              It happens to everyone XD. Sometimes, I'm repairing computers and I forget to plug in the power cable, and so on, hahaha. Could you send a photo of the entire PSU for me to see the complete circuit topology? Regarding the unstable voltage on the output, try testing the comparators on the secondary—they often go shorted and activate the protection in the PSU. They are mostly TL431.
              • CapLeaker
                Leaking Member
                • 8167
                12V @ 16.7V
                5V @ 7.2V
                3.3V @ 3.3V
                EDIT:
                Without it, I get:
                12V @ 37V
                5V @ 15V
                3.3V @ 4.2V
                Waaah!? You get 37V out of the 12V rail? Either your DMM is fubar or measured on the wrong point. You probably couldn’t get the PSU that high if you would wanted to by disabling the feedback and let it go full bore without regulation. I’ve seen many things, but tripling the output voltage from what it is supposed to be. You should have been wearing the caps as they are not rated for that voltage. This doesn’t make any sense whatsoever.
                • temyth
                  • Jan 2024
                  • 45
                  • Brazil
                  thats a good quote, getting 37v on the 12v rail would be hard and it would blow the caps because they're commonly rated to 16v
                  • прямо
                    • Sep 2022
                    • 261
                    • Indonesia
                    It did blew the caps, so I put in 50V caps for now until I can find out what is really wrong.
                    The only semiconductors that I had to change because they were toast when I got the PSU are:
                    Primary N channel mosfet FSW09N90AG to FNK09N90.
                    Primary PWM TL3845P to UC3845B.
                    I'm somewhat suspicious it maybe caused by UC3845B? maybe it has a different duty cycle?
                    If I removed the fan, I get 23V - 24V on the 12V rail, and 9V - 10V on the 5V rail.
                    DMM is ok and no I am not measuring at the wrong point.
                    Only 3.3V is using a TL431 reference. I did a quick check by removing it, and I got 4.5V on the output, putting it back I get 3.3V.
                    All measurements taken with the bulb current limiter on.
                    I'm using 40W bulb. Mains are 225V.
                    • прямо
                      • Sep 2022
                      • 261
                      • Indonesia
                      With the fan attached. Fan only runs for a minute. Probably because the sensor thermistor for the fan is missing.
                      ​​​​​​ Click image for larger version
ID:	3178720 Click image for larger version
                      • прямо
                        • Sep 2022
                        • 261
                        • Indonesia
                        Without the bulb current limiter, and without fan attached.
                        Only able to take photo of the 12V rail.
                        5V rail immediately died because a 27 ohm power resistor overheated and burnt.
                        • прямо
                          • Sep 2022
                          • 261
                          • Indonesia
                          Oh well, I guess this is a no fix. First the caps blew followed by the supervisor IC because VCC (aka 12V rail) was over the max rating, now the power resistor died, and God knows what else.
                          • прямо
                            • Sep 2022
                            • 261
                            • Indonesia
                            temyth ,
                            here are the board photos.
                            IC3, IC4, IC5 are AZ431A (TL431A)
                            IC3 = 3.3V rail FB reference.
                            IC4 = it made no difference to the 12V and 5V rails when I took it out even though cathode pin is connected directly to pin 2 of the main switching opto coupler. Cathode 1.8V, reference 2.6V
                            IC5 = 5VSB rail FB reference.
                            • прямо
                              • Sep 2022
                              • 261
                              • Indonesia
                              I have ordered TL3845P, a 10K sensor thermistor and the burnt out 27 ohm power resistor. There's another power resistor that makes up the -12V from 12V rail that got overheated as well and I lifted one of its leg for now. I will replace this too when all outputs are back to normal.
                              • temyth
                                • Jan 2024
                                • 45
                                • Brazil
                                yeah, maybe the TL3845 is driving the mosfets crazy. there is always a fix, don't worry about it. are you sure you only have 1 comparator? i see a lot of TO-92 transistors in the board, they may not be exactly TL431 but they may be acting as voltage comparators. these half bridge PSU's often get a bad voltage comparator and the voltage goes just crazy.
                                • прямо
                                  • Sep 2022
                                  • 261
                                  • Indonesia
                                  There are two opto couplers going to the main PWM chip, one is connected to the 3.3V TL431 and one is connected to the other TL431 which has 1.8V on the cathode pin and 2.6V on the reference pin. I think this TL431 IS the feedback for 12V (maybe combined with 5V), except I don't know exactly how it works and what to change to make it compatible with UC3845B instead of the blew up TL3845P that the PSU came with.
                                  Yes, there are a few transistors on board.
                                  Near the main PWM chip is KSA928A (Q2)
                                  Near the fan connector is 2SC1384 (Q6), part of the fan controller.
                                  Near the supervisor is STC945 (Q7)
                                  Near the 3.3V TL431 is STA733 (Q3)
                                  • temyth
                                    • Jan 2024
                                    • 45
                                    • Brazil
                                    try getting out the TL431 of 12v and 5v rails and test in a component tester. since all of this symptom is pretty strange i would also test the optocouplers with a multimetertry getting out the TL431 of 12v and 5v rails and test in a component tester. since all of this sympton is pretty strange i would also test the optocouplers with a multimeter
                                    • прямо
                                      • Sep 2022
                                      • 261
                                      • Indonesia
                                      Actually, I have already replaced the 12V/5V TL431 and that doesn't change anything. In fact, even without it, I still get the same voltage outputs. Which is so strange and it's also why I suspect that even though UC3845B is pin to pin compatible, maybe it is not a direct replacement for TL3845P that was originally used in this PSU. Maybe it has a much higher duty cycle that can drive the MOSFET and the transformer to put out these higher voltages. Then again, it doesn't make any sense either because the feedback circuit is supposedly to keep them in check.
                                      So I will do what you suggested.
                                      I will replace the opto coupler.
                                      • temyth
                                        • Jan 2024
                                        • 45
                                        • Brazil
                                        uuuuuh now everything makes sense. you're right! they aren't the same thing, the feedback voltage of the TL3845P can go up to 6.3v, and the UC3844 is limitted to 2.58v, the PSU is probably overvolting the feedback pin and that's why you're getting so high voltages!!
                                        • прямо
                                          • Sep 2022
                                          • 261
                                          • Indonesia
                                          I'm using UC3845B not UC3844.
                                          I replaced the opto coupler, and..... et voila! 12V is now 12.5V and 5V is 5V!!! but now 3.3V has dropped to 1.68V
                                          • hobostove
                                            Corsair RM1000e - Help identify 5VSB Zener diode
                                            by hobostove
                                            Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                                            Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                                            There's a 22ohm resistor that's melted and open, but it still has the bands.
                                            The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                                            It looks like the diode connects the source and drain of a TNY284...
                                            03-27-2025, 02:25 PM
                                          • Alimash
                                            op amp circuit function?
                                            by Alimash
                                            I am repairing a ups which doesn't turn on ,it has the following ICs:
                                            SG3525 used to drive inverter mosfets.
                                            couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                                            A LM358 and TL074 for control mechanism and of course the uController.
                                            The SG3525 is shutting down every time the ups is turned on.
                                            I want your help to know the function of LM358 and TL074 in the system.
                                            I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                                            07-31-2025, 07:45 AM
                                          • caspian
                                            What Zener Diodes on a Linear Power Supply
                                            by caspian
                                            Dear members,
                                            I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                            In addition, I discovered that its zener diodes are defective.
                                            I can replace the burned transistors.
                                            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                            Therefore, I cannot replace the zener diodes.
                                            I do not want to test the zener diodes in a test circuit to discover their model or value.
                                            no schematics are available...
                                            05-26-2025, 12:38 PM
                                          • Astonished
                                            Fixing the Charge Circuit of the Batteries of the DC Motor
                                            by Astonished
                                            Hi friends of electronics
                                            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                            Please help me fix this circuit.
                                            (the datasheet of the IC: https://pdf.datasheet.live/28...
                                            01-28-2025, 06:24 AM
                                          • rddube
                                            Lenovo L490 Ram voltage circuit malfunction
                                            by rddube
                                            Hello friends,
                                            Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                                            I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                                            07-15-2025, 04:41 PM
