Dell E2016HV no power.
  • asiart
    • Jan 2023
    • 19
    • Malaysia
    Hi, I want to ask about the mosfet value of this power supply. The mosfet is blown. The psu model is ILPI-354 V.A. Need urgently. Thanks.
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    Pictures of the MOSFET and of the P/S would help with answering your question.
    PeteS in CA
    • asiart
      • Jan 2023
      • 19
      • Malaysia
      I’m sorry for not include photo yesterday. Now i’m will give you the pictures. Thank you.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        Probably something like a N-Channel TO-220 full pack 600V something or other. Match something up and stick it in its place. Forgot to mention... inspect the gate drive circuit of that mosfet too... if there is something wrong with it, it will blow the new one.
        • asiart
          asiart commented
          Editing a comment
          Oh I see, I already found the broken piece of the mosfet. It wrote JCS4N65MF. Search it online and no hope. I tell my boss, and they told me to stop repair those monitor because they want to scrap it. If I want to replace the mosfet, did I need to search for other mosfet that same with these mosfet datasheet? Thanks for the reply.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        Good you found the lid to the MOSFET! All you need to know from JCS4N65MF: The FET here is a 4N65, 4A, 650V. Now do an online search and buy a replacement 4N65 or 4n80 or a 5N80. You need to have at least same spec MOSFET in here, but you can put let’s say a size or two bigger in there. Let’s say you got a 6n80 you can jam that in. But don’t get the idea to replace a 4n60 with a 12n60. It does work as long there is no problem with the PSU. So for testing purposes it’s o.k, but I wouldn’t leave it in there.
        Again you don’t need exact the same MOSFET to replace the old one, you just need the same basic configuration…
          • 31289
          replace the ceramic cap next to it with a 2kV rated version
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • Mark01
            Dell Optiplex 7490 AIO - red power led after flash
            by Mark01
            Hi guys,
            This is my first post! 🚀
            I have no idea what I’m doing, but I’m learning by trial and error.
            I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
            07-04-2025, 12:54 PM
          • zlr8r
            Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
            by zlr8r
            hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
            Ill try and give as much info as I can.
            Dell Inspiron 17 (7786) Laptop
            Service Tag: 5J0NHT2
            Bios: 1.9.0
            When I received this , it would only flicker on the KB backlight for a second, then off and on.
            Then it started getting weirder!
            Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
            12-12-2023, 09:31 PM
          • LimesKey
            Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
            by LimesKey
            Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
            10-17-2025, 05:33 PM
