Help HX620 Corsair
    Help HX620 Corsair
    Hello guys!
    I need some help in identifying this encircled component.
    Mine got toasted and I need to replace this so I could try reviving this psu.
    Thanks in advance guys.
    This pic is not mine btw (credits to original owner)
    Re: Help HX620 Corsair
    I think it's an NTC thermistor for inrush current protection, like these:
      That is correct, as you can see one side is connected to the + of the filter cap, so it is burnt due to shorts in the circuit some where, or just failed due to under rated.
        thanks for the replies guys, i really appreciate it. gonna check for the part now.
          double post
            Just as with fuses, i wouldn't jump straight to replacing it, before checking for damages "downstream". If something went wrong and toasted the NTC, if you just solder in a new one and turn the PSU on again, there's a certain chance that, whatever the initial issue was, it might cause further damage.
            Just advising caution, that's all
            Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
              Hi I have the same problem what is the reference of the part to change?
