ATX CoolMax CX 400B Blown Capacitor
  • SevillianSTS
    • Nov 2013
    • 31
    I have a CoolMax Model: CX 400B ATX Power Supply
    It has a blown capacitor. I am assuming it is filtering the raw power coming into the unit.
    Trying to figure out what to replace the capacitor with; it is totaly burnt so I can not read the side of it. Is there a general size you would recommend, or does anyone have access to a schematic ?
    The circuit board says LYP004A and Rev 1.6
  • cheapie
    null
    • Jul 2010
    • 849
    Re: ATX CoolMax CX 400B Blown Capacitor
    That's an NTC thermistor (note the "TH1" marking), but I don't know about any replacement suggestions. Something may have been shorted on the primary side causing that to blow.
    • PeteS in CA
      • Aug 2005
      • 3581
      • USA, Unsure of Planet
      Like fuses, inrush limiting thermistors don't usually blow without reason. Chances are one or both of the switch devices has shorted. The heatsinks look pretty substantial, adequate for 400W. Maybe with re-capping the output caps (I assume they are not the best quality), replacing the thermistor and switch devices might yield a very decent P/S. Check the fan(s) to see if it (they) is/are healthy.
      PeteS in CA
      • Agent24
        I see dead caps
        • Oct 2007
        • 4961
        • New Zealand
        Couldn't the thermistor be taken out by a surge etc too?
        -David VanHorn
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Decent PSU, I'd recap it. A better rated NTC thermistor wouldn't hurt. Did the fuse blow too?
          • SevillianSTS
            • Nov 2013
            • 31
            Fuse is good.
            • SevillianSTS
              • Nov 2013
              • 31
              When you says "switch devices" are you referring to the mosfets under the heat sinks ?
              I can get a new one of these for $34; is this still worth the work ?
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                Yes. Although they are most likely Bipolar transistors, probably 13009's. It's worth fixing if you want to learn
                • PeteS in CA
                  • Aug 2005
                  • 3581
                  Some P/Ss use MOSFETs, some use bipolar junction transistors (BJTs). So I cover both possibilities by saying "switch devices". Judging by the core material used for the O/P inductors and what I know of common design practice, that P/S probably has BJTs, probably switches at ~25-30KHz, and is probably controlled by a TL494 or TL494 clone. P4 probably recognized what I did, and I agree with his last sentence. If $$ is your only criterion, buying a new P/S would be cheaper in $$ plus your time. But at that price you'll probably be getting a P/S not capable of its full rated power and a decent lifetime, and some/all of the O/P caps will be @#$% with limited life even at 40%-60% of rated power.
                  Fixing the P/S would probably be more expensive, and cost several hours of your time. Is learning more about P/Ss of value to you? If your answer is, "No," that doesn't make you an idiot, just some one won't be earning part or all of your living in electronics repair (or who does specialized repair). Power electronics has been my career for over 3 decades; OTOH, most of what the computer geekasoids here on BC talk about is Urdu to me.
                  PeteS in CA
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    You can see the controller in the first pic, it's a SG6105D which is a TL494 + two TL431 + some protection circuitry in the same package. And yes, it's gonna have 13009 switching BJTs most likely. Be aware they also like to take some of the driving circuitry with them when they blow. The 1N4148 (glass package) diodes and small capacitors next to them should also be checked if you find one of the power transistors short.
                    A working TV? How boring!
                    • larrymoencurly
                      • Oct 2004
                      • 960
                      Datasheet for the SG6105 controller chip and application note with example schematic:
                      • senz_90
                        • Aug 2013
                        • 328
                        • Indonesia
                        Hey, that's a good PSU with decent heatsink.
                        I think your problem didn't too complicated, sure it is worth to fix it and learn about it.
                        Ship to me if you don't really want to learn it and wanna throwing it on garbage
                        "There is no shortcut to be successful. No pain, no gain."
                        Best Regards
                        Rudi
                        Thank You
                        • PeteS in CA
                          • Aug 2005
                          • 3581
                          Yeah, when a BJT shorts C-B that applies 150V-300V to the B-E and to base drive components designed for 10V-30V circuit voltages. And if a high current pulse from something shorting goes through the base drive transformer, that can get fed back to the PWM. All in all, not pleasant.
                          When I was at Delta products 13 years ago they had a couple of ASICs: one integrated one or more references and several comparators to do supervisory functions; another combined a 3854-style PFC controller and 384x-style PWM into one package. Delta used 384x type PWMs, which operate on the primary side, while TL494-type PWMs are typically used on the secondary side. So Delta didn't combine PWM and supervisory functions the way the SG6105 does.
                          PeteS in CA
                          • LLLlllou
                            • May 2011
                            • 201
                            What a coincidence, I just replaced the Urdu in my laptop!
                            • TELVM
                              • Oct 2012
                              • 547
                              • Spain
                              I've observed that some PSUs have the inrush NTC thermistor jacketed with heat-shrink tubing:
                              Apart from limiting shrapnel proliferation if the thermistor blows up, does the jacket have any other advantages/drawbacks for thermistors?
                              • SevillianSTS
                                • Nov 2013
                                • 31
                                This power supply came out of a Core2Duo computer that I may be turning into a server.
                                I read that this power supply is 70% efficient. I found a newer 80% efficiency power supply for $35
                                Being the server would be pretty much running all the time, would you recommend going with the newer 80% or just stick to this one.
                                Also, what are your thoughts on whether or not this power supply took out the motherboard with it ?
                                If I am going to fix this one, what would be the first line of attach ?
                                Remove the heatsinks and test the BJT's What is the procedure to test the BJT's
                                Thanks again. =)
                                • Pentium4
                                  CapXon Be Gone
                                  • Sep 2011
                                  • 3741
                                  Usually when they say "70% efficient" that normally means worst case scenario. Realistically, it will probably be in the 74-78% range, especially with the lower loads.
                                  Can you post a link of the $35 PSU you are looking at? Some cheap PSU's have fake 80+ ratings.
                                  I think your motherboard will be okay as it looks like all the damage was done to the primary side of the PSU and not the secondary.
                                  Yes, you will get better results testing them out of circuit. Do you have a multimeter? Do the following and post your results:
                                  Set your multimeter to diode check mode:
                                  Red probe on pin 1, black probe on pin 2
                                  Red probe on pin 1, black probe on pin 3
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4961
                                    • New Zealand
                                    In addition, you may find this useful, which describes the process in more detail: http://www.allaboutcircuits.com/vol_3/chpt_4/3.html
                                    -David VanHorn
                                    • SevillianSTS
                                      • Nov 2013
                                      • 31
                                      http://www.newegg.com/Product/Produc...82E16817256060
                                      so it's on sale for 39
                                      and yes I have a MM and pretty competent with a soldering iron, just new to some of these components.
                                      • SevillianSTS
                                        • Nov 2013
                                        • 31
                                        any thoughts on that power supply in my previous post ?
                                        • MeetingIncapable
                                          Blown capacitor repair on MSI Radeon RX 5700 XT MECH OC
                                          by MeetingIncapable
                                          I am new to repairing computer electronics, so excuse any mistakes I make.
                                          A friend of mine had a broken graphics card (MSI Radeon RX 5700 XT MECH OC) and gave it to me. It does not power on or show any signs of life.
                                          I identified what looks like the remains of a blown capacitor at the bottom of the board (see picture).
                                          I wanted to replace the capacitor, but I have two questions:
                                          • Does this repair have a chance of working? or is a blown capacitor a sign something else is wrong?
                                          • How do I determine the rating/value of this capacitor? or something
                                          05-04-2024, 09:56 AM
                                        • NuclearSpartan
                                          Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
                                          by NuclearSpartan
                                          I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
                                          The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
                                          I don't see any other visible damage anywhere else on the board....
                                          11-14-2024, 02:32 PM
                                        • nmbb
                                          Can not find Model/Value of Thermistor.
                                          by nmbb
                                          Machine: Autoclave.
                                          Brand/Model: SANYO MLS-3780
                                          Manual: (Sorry search option not working on this PDF)
                                          Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
                                          06-02-2022, 05:55 PM
                                        • chth96
                                          If I replace with inferior capacitor, Is it No harm to other IC components at all?
                                          by chth96
                                          I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                                          Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                                          It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                                          So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                                          I know that these capacitor will not last as long as nichicon capacitor...
                                          12-22-2023, 04:34 AM
                                        • chth96
                                          How can I test non-polarized capacitor?
                                          by chth96
                                          I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                                          I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                                          And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                                          I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                                          06-02-2024, 07:31 PM
