Powerman has lost its power
  • everell
    • Jan 2009
    • 1514
    Got this Powerman IP-P350AJ2-0 350 watt power supply as dead freebie. Opened it up and found a huge black spot around the switching transistor. Alcohol, a brush, and lots of scrubbing took off the blackness and revealed a bad transistor and capacitor. Plenty of pictures to show what the power supply looks like, so thought I would include only the pictures showing the carnage!
    The switching transistor is a hefty 12N90 good for 12 amps at 900 volts. Lost one of its legs and lots of burn damage at bottom of FET. A 1KV capacitor had lots of burn damage at its bottom. Damage also included the pwm chip, a UC3843, several resistors between the pwm chip and the FET, and one shorted diode between the pwm chip and the FET.
    Just another power supply that flamed out. Lots of black smoke soot, and the usual switcher, pwm chip, and a few other components "failing".
    After repairs voltages are:
    12.13v
    5.12v
    3.34v
    4.98v 5vsb
    The only bummer was that hefty 12N90 FET cost five bucks!
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Powerman has lost its power
    900+ V rating don't even make sense for a computer PSU, LOL.
    900+ V sounds more like a strobe or a CRT.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Wester547
      • Nov 2011
      • 1269
      • USA.
      ^ A single 900V or 800V FET is very commonplace as the main switcher in single switch forward topology. Sometimes there will be two of them in parallel as a "modified" version of single switch forward. I wonder what caused the W12NK90Z to fail, unless something driving it did (if that bad capacitor was).
      • everell
        • Jan 2009
        • 1514
        In my "opinion" the capacitor was the first to go, then the FET and the resistor between source and ground. Once the resistor between source and ground opens, the high voltage has no where to go except thru the pwm chip. Like a domino effect! I wonder if it made a big bang when it failed.
        • c_hegge
          • Sep 2009
          • 5219
          With the damage you saw to the cap and FET, I'm sure it would have been a nice fireworks display
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            I have seen a few of these come in to work from catching on fire due to shorts from conductive glue. Was yours covered in that brown glue?
            • everell
              • Jan 2009
              • 1514
              No, but a large area was covered in black soot!
              • magneh
                Behringer Eurolive B205D repair - help identifying transistor
                by magneh
                Hello
                Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                Still, I need to replace this transistor....
                06-18-2025, 02:34 AM
              • elsomer
                help to identify transistor msi ms-15ck1
                by elsomer
                hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
                02-17-2025, 05:30 PM
              • rddube
                Help with blowing transistor NAD T752 receiver
                by rddube
                I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
                Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
                I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
                09-01-2022, 05:19 AM
              • amigo744
                xbox series x u82 5 pin transistor voltages ?
                by amigo744
                hello there,
                xbox series x hdmi u82 transistor 5 pin,
                can anybody tell me voltages of this transistor in standby and power on mode ???
                on which pin of this transistor are the voltages ?
                regards
                08-16-2023, 08:05 AM
                AO4601 AO4601L Transistor (Applications Laptops) Datasheet
                Complementary Enhancement Mode Field Effect Transistor
                The AO4601 and AO4601L use advanced trench technology MOSFETs to provide excellent RDS(ON) and low gate charge. The complementary MOSFETs may be used to form a level shifted high side switch, and for a host of other applications. Standard Product AO4601 is Pb-free (meets ROHS & Sony 259 specifications). AO4601L is a Green Product ordering option. AO4601 and AO4601L...
                11-05-2024, 08:21 AM
