Vestel 17PW25-4 repair - resistor value?
  • tn245
    • Oct 2013
    • 530
    I bought a repair kit for this TV power supply. Shorted diodes, FET and several tiny surface mount components to replace. On starting the repair I noticed someone had had a try before me and even helpfully ripped up some of the PCB pads. In spite of that I think I've managed to get everything in place and connected up correctly.
    My question. The schematic for this power supply (attached) lists SMD resistor R923 (off pin 4 of FAN7529) as 15R, but the repair kit supplied 100R and the one I removed from the board was also 100R (bearing in mind someone had repaired it before - maybe with same kit?). I wrote to the kit supplier to ask about it and he hasn't replied.
    As I don't have the electronics knowledge to know what that resistor value should be, do you think there's any reason a 100R might be supplied instead? If I go ahead and use 100R might there be any consequences?
    Thanks!
  • Klockaren
    • Oct 2014
    • 10
    • Sweden
    Re: Vestel 17PW25-4 repair - resistor value?
    Thanks!
    I have the same problem regarding R923. I havent got any schematics with the right value for this resistor.
    Then R980 are broken and I can't see the numbers on it. Schematics says 15R for this also, but I don't trust on this.
    Do you got any correct schematics for this board?
    /Gunnar
    • steviewonder
      • Dec 2013
      • 183
      • england
      bit of a old thread,but just had the same problem.
      R923 is indeed 100 ohm,the schematic is incorrect.
        15 Ohms or 100 Ohms is not going to make any difference, the there is 40K internal resistor/Capacitor filter feeding the input of comparator circuit inside for that Current Sensing (CS) pin. if you look at the app note circuit, you do not need the resistor.
        • jinu_j
          by jinu_j
          Hi
          05-03-2025, 10:51 PM
        • youpla
          PowerColor rx 5700xt dual fan : current sense resistor
          by youpla
          I’m repairing a PowerColor RX 5700 XT Dual Fan (not the Red Devil or Red Dragon model) with a burnt pin 5 on its 6-pin PCIe connector.
          The previous owner had it repaired by a shop. They soldered an enameled wire to reconnect pin 5 to the current sense resistor (shunt).
          The card wasn’t displaying anything after this fix.
          When I inspected their work, I found that the sense resistor had fallen off after reheating the solder joint (likely due to damaged pads from resistor).
          I tried to resolder it with a hot air station, but the resistor wouldn’t...
          12-01-2025, 07:52 AM
        • mikey5791
          by mikey5791
          Hi to all forum members,
          12-26-2024, 04:55 AM
        • MidnightRoller
          Can a resistor lose resistance after hot air?
          by MidnightRoller
          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
          02-02-2022, 11:46 PM
        • artvandalai
          What resistor ohm will work better to repair this waterpik?
          by artvandalai
          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
          01-05-2025, 04:10 PM
