Power Supply/Crossover Question
  • elgato
    • Apr 2013
    • 32
    The attached pics are from a Tandberg powered speaker. The amp is a separate housing from the speaker and directly connects to the speaker via the 10 connectors along the edge.
    The speaker housing is sealed and has two Seas drivers and a tweeter.
    Any idea why they would use 10 connectors to connect the speaker to the amp?
    Can you tell if a crossover for the speaker is built into this amp?
    Thanks for your time.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Power Supply/Crossover Question
    Judging by how many connectors go to the speaker itself, I'd say the crossover is before the amplifiers. The crossover after the amplifiers, but before the speakers, is quite inefficient, and can reduce sound quality.
    Also, because there is a texas instruments DSP chip on there, that sugguests the same thing I said above.
    Muh-soggy-knee
    • elgato
      • Apr 2013
      • 32
      Thanks for the response.
      Actually only six of the connectors go into the speaker housing.
      From what you can see, is there a crossover built into this board?
      My reason for asking is that I would just like to get rid of this amp and use the speaker as passive. You would not expect to find a crossover in the speaker housing?
      Thanks again.
      • Khron
        • Sep 2006
        • 1350
        • Finland
        Two Seas drivers plus a tweeter - coincidence or not, those happen to have exactly six terminals between them. Is this an MTM arrangement (mid-tweeter-mid)?
        Seeing as there are 5 chip-amps, i'm gonna hazard a guess and say they're two pairs, each bridged for each mid-woofer, and one chip-amp for the tweeter
        So... No, the odds of you finding a passive crossover inside the speakers are rapidly approaching nil, i'm afraid.
        Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
          More likely to be tri-amp powered speaker set up, Amplifier per speaker, and it uses active electronics cross-over to separate audio frequency bands (LO, MID, HI) to feed each speaker's amplifier. model number?
          • elgato
            • Apr 2013
            • 32
            Thanks for taking the time to look at it.
            Its a Tandberg TTC1-02 Amp/Speaker combination from a video conferencing system.
            Seas are great drivers and it looked like it would make a nice center. Pretty sophisticated design for a voice range speaker. Now I see why they charge so much for this stuff. Not sure what the tweeter is.
              Tweeter is the high frequency speaker, sitting between the two speakers as you can see in the picture. Only $20?
              http://www.ebay.com/itm/Tandberg-Dig...item58a39498e0
              • elgato
                • Apr 2013
                • 32
                I meant that I don't know the brand and model of the tweeter.
                I am not surprised that they are $20. I wouldn't pay the $20 plus $38 shipping though.
                This Tandberg Conferencing stuff was crazy expensive new. They wanted $328.00 for a wheel for one of the carts.
                • Khron
                  • Sep 2006
                  • 1350
                  • Finland
                  What size woofers are those, 5"? That would make them L15RLY/P's, which are worth quite a bit more than 20$ on their own, each
                  (Madisound seem to have'em for 88$ a pop: http://www.madisoundspeakerstore.com...m-cone-woofer/ )
                  I've had a pair of those drivers in my closet for... way too many years already, "still" waiting for some "free funds" to get some proper boxes done for'em
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Is this amp just for one speaker, or is it multi-speaker (AKA, stereo, right and left channels, etc...)?
                    Muh-soggy-knee
                    • elgato
                      • Apr 2013
                      • 32
                      Old post but did you ever do anything with this? I have had one in the storage room for a while and just pulled it out again.
                      Looks like really high quality 5 1/2 drivers.
                      Not sure about the tweeter.
                      Connected an IPhone to the audio in and it sounded pretty good.
                      Some amplifier hum at idle.
                      It has a "differential in" 3 pin that looks like a balanced connector and a stereo out with the same.
                      It looks like it should be useful, just not sure how.
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
                        by sam_sam_sam
                        07-01-2024, 06:34 AM
                      • Phoenix88
                        Identifying the PWM circuit on the power supply of the Elipson W35 speaker
                        by Phoenix88
                        Hello everyone !
                        I'm trying to repair the power supply of my Elipson W35 Bluetooth speaker. The problem is that the PWM circuit has no reference "it's a smd marked U4 on the pcb. The reference has been erased at the factory. Here are some photos of the circuit; could you please help me identify the circuit? Thank you, and have a great day
                        Important point: the resistor R108 marked R100 smd mount is a replacement and I'm note sur if it's the good value, it's relay the mosfet to the ground capacitor 450v
                        the mosfet is a :SVF12N65F
                        I also search...
                        08-13-2024, 02:52 AM
                      • shamsudeen
                        Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                        by shamsudeen
                        Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                        I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                        i know that in linear power supply the noise will be very low comparing to SMPS supply....
                        07-19-2025, 07:14 AM
