Lian Li Power Supply
  • toastygoodness
    • Jul 2005
    • 813
    I was browsing for a case today when I noticed that Lian Li carried a power supply: HPC-500. I was wondering what OEM made it and whether it has good caps or not. The back does not have an exhaust fan, but looking throught the pics, the PSU seems really well stuffed (i mean, look at the size of the huge heatsink!). So, does anybody have any information on the OEM and the quality? I'm really interested in this PSU.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Lian Li Power Supply
    i think it is made by high power like the chieftecs.
    http://www.highpowersupply.com/
    its passive pfc though yawn
    • Galvanized
      • Mar 2006
      • 468
      The Lian Li PSUs are built by Sirtec and can be considered better than most other PSUs that come bundled with cases. Lian Li is not bundeling these at this time...Are they?
      I would buy a Silverstone Element 500W over this Sirtec.
      • toastygoodness
        • Jul 2005
        • 813
        would the cooling work though? they're selling these bundled with Lian-Li cases really cheap at a local store here.
        • Galvanized
          • Mar 2006
          • 468
          I'm not sure what you mean by, "would the cooling work though?"
          Even without active PFC it is still a decent PSU but there are better 500W units in the $60~$80 range with aPFC, if you were buying this Sirtec outright.
          If the deal is good for you, go for it.
          • toastygoodness
            • Jul 2005
            • 813
            Well, the back doesn't have an exhaust fan, so I was wondering if the caps would die.
            • Galvanized
              • Mar 2006
              • 468
              Hey toasty! It has a 120mm fan blowing into the unit, it does not need an 80mm exhaust. Typically a PSU with an 80mm fan will have it speced at 40~55cfm @ 12V, with a 120mm fan as an intake the spec is about 70~85cfm. This is because the sinks must be reduced in height, which reduces area, inorder to fit the 120.
              Most often PSUs that use a 120 are quieter than units that use an 80mm..Lower dBA.
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                lower dBA but higher cfm I am yet to be disappointed with a 120mm fan psu. nice cold air and not much noise. turbulence is actually good for cooling and that is what they provide. most important though is to have a design which is not too toasty in the first place though. 2x80mm no i think i wont buy another one of those....
                • toastygoodness
                  • Jul 2005
                  • 813
                  nice... thanks for all the info! I'll be buying this one by the time you read this.
                  • bgavin
                    • Jan 2007
                    • 1355
                    PC Power & Cooling downplays the 120mm fans. They use the reasoning of shortened heat sinks, and claim an 80mm rear exhaust is more efficient.
                    I would think an air flow analysis of the rear fan would show a definite pattern of eddies where air flow is low or non-existent. As noted above, the larger fan is more quiet, and the added turbulence blowing down on all the components probably eliminates hot spots.
                    I bought two more Sparkle units with 120mm fans for stock. Both will be recapped before going into service.
                    • 999999999
                      • Sep 2006
                      • 774
                      PC Power & Cooling recognizes that there is only so much room in a PSU. 120mm fan is fine if it leaves enough room for the other parts, but past about 400W (if it's a decent, honestly rated unit) it starts getting cramped inside, something has to give.
                      It's really a matter of construction budget. Does the chopper use old BJTs or mosfets? Does the rectification use fast diodes or schottkys, or even two or more parallel schottys. It makes a lot of difference in what heatsink they can get away with using, and if there isn't such a height limitation such that they can shift all parts over some, it makes more room for bigger caps and inductors.
                      Nothing is without tradeoffs but if you get a well designed PSU it can run fine with only a rear 80mm fan. How many PC Power & Cooling PSU do you hear about failing from overheating anyway?
                      Choosing a 120mm fan based model is generally the cheaper way to get a low noise unit, and that is good too.
