High Voltage Shocker - components blown in new machine
  • Douglasbell01
    • Oct 2013
    • 14
    Re: High Voltage Shocker - components blown in new machine
    The fuse on the board (when it originally blew) had darkened glass (scattered metal?).
    Since testing again with the step-down voltage convertor (without replacing the MOV), 2x fuses have popped. Clear glass.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      check that you got the correct rated fuses if you do it sounds like you might have a half shorted component, its the fuse the board blowing clear correct?
      Follow the white rabbit.
        Yep, that is the good old trick when look at the glass fuse, if it is blacken inside the fuse, then you have really shorted load. Just like the one shown in the post 1 when MOV blown.
        • Douglasbell01
          • Oct 2013
          • 14
          Thanks. It sounds like there's a half-shorted component in that case, because the new fuse blows clear.
          Next step ideas? From earlier posts, it sounds as if I need to work out a way to test the resistance of components around the fuse. So there may well be another 1/2/3/4/5 components to replace.
          Are you optimistic of this being reparable? I may be able to buy/borrow testing gear. But don't want to waste anyone's time.
            You mean the fuse on that power supply board is blowing? Did you do any resistance testing as suggested on post 15? Any pictures of the whole board both sides?
            • Douglasbell01
              • Oct 2013
              • 14
              #26
              Yes, the fuse in the photos is the one that blows still (before changing the MOV, but with a step-down convertor in use).
              I've not managed to do any resistance testing (but will try to get the gear to do this).
              Also, the machine is stored at a friend's house. I'll try to photograph the board (both sides) asap.
              • Douglasbell01
                • Oct 2013
                • 14
                #27
                WOW, multimeters are cheap! Just found one (new, free postage) for roughly $5 US on Ebay UK. http://tinyurl.com/ml7vgq9
                  master hoarder
                  • May 2008
                  • 12175
                  #28
                  Wait, so did you take out the blown MOV out yet? If you haven't, you will keep blowing fuses.
                  • Douglasbell01
                    • Oct 2013
                    • 14
                    #29
                    Replaced the MOV and fuse. Machine working again!
                    Then the step down transformer blew after about an hour's use. Easily replaced. Wrong values.
                    • bexy2386
                      • Dec 2013
                      douglasbell01 did you manage to fix your yudu printer? I have just done exactly the same. Any advice? Does it work fine now with a convertor plug now you have replaced the fuse? I have no idea how to go about fixing the fuse!
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5040
                        • New Zealand
                        #31
                        For that price, including shipping, that's not a multimeter, that's garbage, really.
                        -David VanHorn
                        • DjKrish
                          • Oct 2012
                          • 354
                          • SG
                          #32
                          When a fuse blows, diodes, power transistor and bridge rectifiers are the first to check followed by other components.
                          • Babbar
                            by Babbar
                            04-12-2024, 01:12 AM
                          • drscoot
                            HP X360 convertible battery blown fuse error, not charging
                            by drscoot
                            HP Modelnumber: 14-dh0061nb​
                            This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                            The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                            I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                            And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                            All these 3 batteries are charging...
                            12-15-2023, 05:54 AM
                          • beetle1303
                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                            by beetle1303
                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                            01-13-2025, 08:49 PM
                          • jesterace
                            Samsung UE46ES8000 Blown fuse but no other signs of short
                            by jesterace
                            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                            09-11-2024, 03:14 PM
                          • JupTec
                            Thermal fuse for DeLonghi coffee machine EN 167.B
                            by JupTec
                            I would like to know the "thermal value" of the thermal fuse for the coffee machine "DeLonghi EN 167.B". This value is nor longer visible on the fuse itself (maby 167°C or 192°C or somethong similar ?).
                            THANK YOU for your help!
                            JupTec
                            06-18-2024, 06:54 AM
