Thermal fuse for DeLonghi coffee machine EN 167.B
  • JupTec
    • Nov 2022
    • 7
    • Österreich
    I would like to know the "thermal value" of the thermal fuse for the coffee machine "DeLonghi EN 167.B". This value is nor longer visible on the fuse itself (maby 167°C or 192°C or somethong similar ?).
    THANK YOU for your help!
    JupTec
  • double_DD
    Transformer replacement for a dead coffee machine
    by double_DD
    Hi guys,
    I have a dead coffee machine, and it seems that the culprit (no 1, at least) is a dead trafo - primary coil seems to be blown open (type shown on the picture below).
    Now, I'm unable to find direct replacement anywhere on ebay or aliexpress, and all similar that I' was able to find are rated too low (<1A).
    If someone knows a shop to buy replacement (EU/CH), that would of course be my 1st option.
    My other ideas:
    - to buy 220/20Vac trafo with 30VA, and to "manually" create secondary 12V output just via resistor
    - to buy...
    06-23-2025, 05:43 AM
  • Francesc V.
    Help me to identify this Thermal fuse from my sister's mixer
    by Francesc V.
    Hi everyone:
    This is the second time I have my sister's mixer on the bench. First time I identified a blown tiristor......this time I guess it's the thermal fuse (reads open).
    My understanding is that it should be (NC) normally closed and open at 85C?????
    Could you help me to identify/get a good one? How many amps? I was about to buy a NC 10A, 85 celcius in Aliexpress. (ceramic one)......but I guess is too much.
    Wording in the back......... "limitor 16", "T160".
    Thanks in advance,
    Francesc....
    03-18-2025, 05:48 AM
  • mon2
    Saeco SG200E Coffee Machine
    by mon2
    Hello. Have a known good Saeco SG200E Coffee machine but the internal hose from the pump were disconnected. Would someone be kind enough to share a few clear pics of the inside of this machine so we can reconnect the hose plumbing again? Many thanks....
    04-25-2024, 10:24 AM
  • Gaz54uk
    AEG coffee machine no steam
    by Gaz54uk
    Hi. I have a built in AEG model PE3810-M coffee machine after about 2 years from new it had a problem were no steam would come out of the wand so i paid £80 to have it repaired after 6 months the same faulty happened again but the repairers said they only give 3 months warranty so we just left it sat there but now i'm wanting to get some use out of it, i'm 80-90% its one of the solenoids as waters still come out by the wand and the bit where it makes coffee, I've made sure all the pipes are cleared and can hear the pumps going but just not sure and don't want to start wasting money on parts unless...
    01-13-2024, 05:00 AM
  • corrize
    A funny fuse story – Lumix LX100 II
    by corrize
    Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
    I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
    The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
    There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
    And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
    10-19-2023, 09:58 AM
