power good 0v
  • placidocd
    • Aug 2013
    • 5
    • Indonesia
    power good 0v
    Hello I'm newbie here and sorry for my bad English.
    I have a problem with some ATX PSU. All voltage are normal, only grey wire (power_good) detect 0v. From where do I start for repair it?
    Last edited by kc8adu; 10-06-2013, 11:40 AM. Reason: new thread and posted symptom
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: repair and troubleshoot atx power supply 435 W
    moved to a new thread.
    as usual we need brand,model,and good pics.
    • Escort Eagle
      • Jul 2012
      • 110
      Re: power good 0v
      How many ICs in controller Section ? And what is the number of that IC's ?
      • placidocd
        • Aug 2013
        • 5
        • Indonesia
        Re: power good 0v
        Thx, sorry for my retard post.
        There are 3 PSU which same trouble with 0v 'Power Good'
        1. FSP SAGA II 400
        5v normal voltage
        12v normal voltage
        Power Good (grey) abnormal voltage
        Inside
        Weltrend WT7527
        Test by shorten green and black wire, 0v Power Good also happen when plugged in to mainboard.
        • domas
          News Hater
          • May 2013
          • 323
          • Denmark
          Re: power good 0v
          what about +3,3V, did you forget to test it?
          also please check voltage on weltend pins 1 and 16
          and 9th pin on weltrened, should be less than 1.2
          take some time to analyze the internal circuit of the chip to see what can cause PGO (pin 16) to be low
          • Escort Eagle
            • Jul 2012
            • 110
            Re: power good 0v
            Change This 320μF/400V Primary Capacitor (Shown in the Image) with a new one . Your Power supply will be OK .
            • cheapie
              null
              • Jul 2010
              • 849
              Re: power good 0v
              What makes you think that's the problem? It's running, so most likely that cap is good (or good enough, at least). I think the problem is on the secondary side.
              • Escort Eagle
                • Jul 2012
                • 110
                Re: power good 0v
                Boss, I do not know - why have I told that . He wanted a solution . Just I have tried to give him a solution of his problem .
                • senz_90
                  • Aug 2013
                  • 328
                  • Indonesia
                  Re: power good 0v
                  how to check voltage on ic pins, is this means we check when connecting to the mains? is that possible with analog VOM at off conditions, i guess it is possible with DMM? i have same symptom with my PSU, it has a 2005Z IC
                  i didn't get a "power good" signal on gray colour rail. sorry for hijacking this thread just because have a same symptom.
                  "There is no shortcut to be successful. No pain, no gain."
                  Best Regards
                  Rudi
                  Thank You
                  • placidocd
                    • Aug 2013
                    • 5
                    • Indonesia
                    Re: power good 0v
                    I've read that in "Jestine Yong's handbook" and I replaced the cap with other, same capasity and bigger capasity I tried, but the problem not fixed.
                    Sometimes a little error on primary side can effect some voltage on the secondary side. CMIIW.
                    Hi bro, nice to share here . I have another PSU with ATX2005Z PWM Controller which no voltage on Power Good.
                    All voltage except Power Good are absolutely normal. Ok I try to analyzed the Weltrend IC. Thx for the link.
                    • Escort Eagle
                      • Jul 2012
                      • 110
                      Re: power good 0v
                      If Primary Power signal is good then IC must drain the Power good signal . Primary power signal is good and still IC is not delivering power good signal, then IC must have problem . Normally PG problem occurs due to primary side's malfunction, not for secondary side . I have repaired several PSU with PG problem by replacing Primary Caps . Just for one case - I found defect on controller section in secondary side . Just a Resistor was visibly burnt there and the controller section was built with two ICs "TL494" and "LM339" . Otherwise every PG problem was solved by replacing caps .
                      I think - it may be a common problem of "WT7527" like as common problem of "TL494" is PWM problem .
                      • senz_90
                        • Aug 2013
                        • 328
                        • Indonesia
                        Re: power good 0v
                        hmm.. IMO i just think the IC has a problem. but the experienced one's can give you a better solution. btw please tell me how to check the ic voltage? i didn't get a datasheet for 2005Z ic around googling..where is Vcc and Vdd? and where is the pins that i should checking around...?
                        this is a good forum bro. you can improve your skill just searching the thread.. i am make a fast progress to understand SMPS design and how are they working after read many troubleshooting thread.
                        Best Regards
                        Rudi
                        Thank You
                        • everell
                          • Jan 2009
                          • 1514
                          Re: power good 0v
                          Here is a drawing of the 2003/2005 chip
                          Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                          • Escort Eagle
                            • Jul 2012
                            • 110
                            Re: power good 0v
                            Here is the Datasheet of ATX2005 .....
                            • senz_90
                              • Aug 2013
                              • 328
                              • Indonesia
                              Re: power good 0v
                              Thank you. btw AT 2005B didn't same with my ic configuration. the same one is by everell uploaded. My GND at pin 12, PG OUT pin 9, REF TL431 pin 10 11. btw what voltage that i have to expect? i have to search the datasheet internally configuration..
                              Best Regards
                              Rudi
                              Thank You
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8706
                                Re: power good 0v
                                I had a deer PSU end up like that - produced volts but powergood was always 0V or around there.
                                In my case, a small ceramic filter capacitor (0.01uF) shorted near the powergood op amp. Replacing it restored operation.
                                I don't know how typical this is but it turned out to be the problem.
                                • senz_90
                                  • Aug 2013
                                  • 328
                                  • Indonesia
                                  Re: power good 0v
                                  okay... i get this voltage each rails at pin:
                                  1 = 7V
                                  2 = 250mV
                                  3 = 3.3V
                                  4 = 4.8
                                  6 = 350mV
                                  9 = 130mV
                                  is that normal?? i think pin 3 and 4 normal by the IC pict given by everell. but pin 2,6 and 9 has very low voltage.. any advise?
                                  Best Regards
                                  Rudi
                                  Thank You
                                  • domas
                                    News Hater
                                    • May 2013
                                    • 323
                                    • Denmark
                                    Re: power good 0v
                                    9 should be low, it's okay.
                                    pin 2 is GND, it is supposed to have no voltage. There should not be any voltage between GND and that pin. Maybe there is a leak somewhere, i am not sure if 250mV is not normal, while it is only 0,25V.
                                    I am not such an expert in open drain outputs, but pin 3 FPOB "Fault protection output pin, open drain output" should not have voltage if there is no fault, but i am an amateur in this.
                                    check for dead diodes, resistors and caps around the chip
                                    • senz_90
                                      • Aug 2013
                                      • 328
                                      • Indonesia
                                      Re: power good 0v
                                      hm. i have check diode, resistor nearly, but it didn't show any leakage. maybe the caps or ceramic caps nearly.. i know the ceramic caps very seldom to broken but i have to check it i guess.. btw pin 6 should be 12V I think refer to IC pict?
                                      Best Regards
                                      Rudi
                                      Thank You
                                      • cheapie
                                        null
                                        • Jul 2010
                                        • 849
                                        Re: power good 0v
                                        (Looks like senz beat me to this...)
                                        Isn't pin 6 supposed to be connected to +12V, according to the drawing?
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                          09-06-2024, 05:59 AM
