Troubleshoot PSU without Main board?
  • Ashroyer05
    • Sep 2013
    • 162
    • U.S
    I read the basic troubleshooting article on computers and TVs today. I seen how a load is connected to a PSU to test output voltages for inverters. I am wondering though (maybe I just didn't take everything in) is it possible to test the PSU without having it connected to the main board. Could an adjustable power supply be used to give the PSU the correct voltage or could the PSU be jumpered to trick it into thinking it is receiving the active signal from the main board? My point is is how can we determine whether the fault is in the PSU or in the main board.
    Thanks for any input you may have.
  • cheapie
    null
    • Jul 2010
    • 849
    Re: Troubleshoot PSU without Main board?
    A computer power supply? Connect the green wire on the big connector to any black wire.
    If you're talking a TV power supply, you first have to find out which pin is PS_ON. Once you find it, you have to determine if it needs to be connected to ground or something else (like standby power).
    • Ashroyer05
      • Sep 2013
      • 162
      • U.S
      Thank you. Yes I was thinking more for tv which I forget to clarify however the info about a computer psu helps as well I'm sure at some point I'll have to fix a computer.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Yes, you can do that with most LCD TV PSUs. Some may require you to pull down a voltage on a certain wire, others may require you to pull it up to 5V. Look for a rail named PS-ON, ON, PON, PSU_ON, or something similar. It varies between different PSUs. Some don't even label it so you may have to do some tracing and guessing. But all in all, if you know some PSU basics (i.e. can identify the Standby circuit, if there is one, from the main power supply, where the outputs are, and stuff like that) it should be pretty easy to figure.
        • Ashroyer05
          • Sep 2013
          • 162
          • U.S
          I'm still learning what part the circuit does what job. Outputs are pretty easy for me to figure. Out of the 6 or 7 tvs I've had apart only one had a rail labeled.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Usually an IC or a discrete circuit. I usually don't bother to figure out what generates it. Just when I find it, I measure the voltage on it. If it is low (0V-ish), I try to pull it high to 5V with a resistor (100 Ohm to 10 kOhm should work). If it's high (around 5V normally), I pull it low to 0V.
            • Ashroyer05
              • Sep 2013
              • 162
              • U.S
              On the tv i'm working on now it has a steady 3.2 volts coming from one pin and a pin that goes to 5v when the set is first turned on. Is 3.2 okay for a standby voltage?
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                If it's labeled 5V, then most likely not.
                • Ashroyer05
                  • Sep 2013
                  • 162
                  • U.S
                  There are no labels and they are two separate voltages on two separate pins.
                    For the beginner to learn how the TV power supply works is try to find one that has diagram then we can walk you through the diagram and the board you are working on, if the board is working will be even better so you can see what happen when certain signals are applied to board and what voltage you should expect, once you get the basic understanding down then it will be easy from there. Most power supply operates in the same way, once you learn what it takes to make the power supply to function. You should also try learn how the transistor, MOSFET, Diode work.
                    • Ashroyer05
                      • Sep 2013
                      • 162
                      • U.S
                      I have the components down from schooling. Hopefully I can find a schematic for one of the power supplies I have here.
                      • ygorsan
                        by ygorsan
                        🧩 Problem Summary:
                        • I
                        07-28-2025, 08:34 AM
                      • jb_Bak
                        by jb_Bak
                        CN6401
                        Pin 01 NC
                        Pin 02 NC
                        Pin 03 "BL_ON": 0V
                        Pin 04 "N/C"
                        Pin 05 "STBY 3.3V": 3.5V
                        Pin 06 "GND": N/C
                        Pin 07 "AC_OFF"...
                        09-27-2021, 04:52 PM
                      • JDC
                        (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                        by JDC
                        ONN 100012588
                        Issue: No Power, Then Rebooting After Main Board Change
                        Short answer: replace main board and power board
                        Technical answer: replace main board and Q306 & Q307 on power board.
                        Long answer:
                        TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                        07-15-2022, 07:39 AM
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
