Glue or bad capcitors?
  • DeanCollins
    • Sep 2013
    • 12
    hmmm can I get a second opinion confirming if these are busted capacitors or if this is just glue for snap-in capacitors?
    Basically the unit was working fine, was powered down to move to another room and now wont power back on.
    I tested the batteries (52volts at the connecter and 12v on each of the battery terminals) so not faulty batteries.
    Basically the mechanical switch to turn on/off depresses halfway out just fine but no lights/fans just wont display any activity at all.
    Or does anyone have someone in New York city (I'm in Brooklyn heights) that they can recommend to check out my cyberpower PR2200LCDRTXL2U ups
    I'm comfortable pulling the board and soldering replacement capacitors but out of my league to trouble shoot a circuit.
  • domas
    News Hater
    • May 2013
    • 323
    • Denmark
    Re: Glue or bad capcitors?
    that is glue
    • DeanCollins
      • Sep 2013
      • 12
      well that sucks, thanks though Domas, now I have a bigger problem trying to work out what is wrong with this cyberpower PR2200LCDRTXL2U.
      Anyone know/want to recommend someone in NYC that can trouble shoot this at a reasonable price that means I don't have to junk it?
        Can I see the front panel of this UPS?
        • DeanCollins
          • Sep 2013
          • 12
          Sure, I also took a photo of the top and closeup on the motherboard
          Let me know if you need anything else.
            So when you plug its power cord into the AC out, do you hear the bypass relay clicks on at all? This unit looks also most like the 1500VA model.
            When you remove the front panel, is there circuit board mounted to the removable front panel?
            • DeanCollins
              • Sep 2013
              • 12
              Its a 2200VA model - Cyberpower PR2200LCDRTXL2U
              And nope....no noises, no clicks, no nothing. If someone could tell me which points to test on the switch I'd test it as almost like the mechanical on/off switch doesn't work but it mechanically stops half way etc just fine.
                If it works the same as the 1500VA model, there is a fuse on that main board for the batteries charging circuit (always running to charge the batteries the minute it receives the 120vac input). See if that fuse (long cylinder) is blown or not. If the charging circuit does not work, it not allow the UPS to turn on since it uses the voltage from the charging circuit to feed the power switch button. Disconnect the battery in case it starts working by itself.
                Also the direct outlets (the one that do not run off the UPS) on the back do not have any 120vac either, right? You can plug in the desk lamp to find out.
                The unit is tightly pack so it is hard to work on, you can remove the RS232 PORT (black box above the main board so you can easily see).
                The 1500VA version is known for having bad caps in the charger circuits.
                • DeanCollins
                  • Sep 2013
                  • 12
                  In the 2200va unit all 8 power outlets run from the battery (so different to the 1500 which is 3 and 3 I think).
                  There are 3 fuses (if you see the main heatsing top center the capacitors I thought were faulty are to the right of it then to the right again is the 3 fuses).
                  They are "blade style" eg like a car fuse. and all 3 are good.
                  Are you saying there is another fuse near the back? (eg under the Ethernet port?) I couldn't see any back there.
                    The blade types (fuses use in car) are for the batteries. The fuse F3 on the 1500 board is soldered in.
                    • DeanCollins
                      • Sep 2013
                      • 12
                      thanks BudM, the layout is different so i'll have to go and hunt around to see if there is something similar on the board (eg on your photo you seem to only have 2 blade style fuses - top left).
                      • DeanCollins
                        • Sep 2013
                        • 12
                        Nope I looked and can only see the 3 blade fuses.....would be easier with a schematic :0
                        I think i'm going to have to find someone in manhattan who has experience with troubleshooting UPS's for a repair. It could be as simple as a faulty switch but without knowing how to test the various points i'm shooting blindly here.
                        • DeanCollins
                          • Sep 2013
                          • 12
                          Still looking for someone in NY who is able to troubleshoot a UPS.
                          Basically every computer company etc I've called say they cant service cyberpower and cyberpower do zero repairs in the USA and are telling me to junk it.
                          • Jooo
                            • Oct 2011
                            • 222
                            • Finland
                            I dont think that computer company is the right place to call. Mostly they just do software repair for computers.
                            Call a electronics repair shop instead.
                            • carrzkiss
                              Cyberpower cps1500avr not charging batteries
                              by carrzkiss
                              Hello, all.
                              Cyberpower Battery Backup Unit.
                              I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                              When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                              In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                              Checking the voltage, it was down to 22v.
                              I quickly removed everything...
                              06-15-2024, 02:10 PM
                            • howardc64
                              Where do repair shops buy MB replacement batteries?
                              by howardc64
                              Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                              Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                              BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                              07-25-2024, 10:42 AM
                            • Astonished
                              Fixing the Charge Circuit of the Batteries of the DC Motor
                              by Astonished
                              Hi friends of electronics
                              What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                              The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                              Please help me fix this circuit.
                              (the datasheet of the IC: https://pdf.datasheet.live/28...
                              01-28-2025, 06:24 AM
                            • dbuergi
                              DIY: Modified smart charger for all types of batteries
                              by dbuergi
                              sometimes i'm in need of a charger / tester for very small batteries and even if my multimeter doesn't show anything there is a chance that a smart charger helps to revieve. I'm happy with my Keenstone smartcharger and i made a small mod just to use it with smaller batteries like in smartwatches or even camera batteries with special contacts.
                              Soldering wires on the charger contacts and using needles as probes. I covered both with a shrink hose with integrated solder.
                              My first work was to bring my Samsung watch battery back to life with was not recognized...
                              07-18-2025, 03:17 AM
                            • mitsu2k
                              The Real Dangers of conductive glue.
                              by mitsu2k
                              I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
                              Here is an experience I...
                              04-16-2023, 06:29 PM
