Jestine Yong's Diode Removal Test
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    Just reading through Yong's book on SMPS repair again to try to get ideas for a particularly awkward SMPS I'm working on... He says that if you are having problems with an SMPS power cycling and want to narrow the problem down, then you can remove ONE of the secondary Schottky diodes, power on and see if the problem persists... This also comes with the warning NOT to remove all of the secondary diodes as it will "blow up"..
    Anybody tried this method.. I was gonna give it a shot
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Jestine Yong's Diode Removal Test
    just dont remove the one on the line the feedback comes from...
    • JonathanAnon
      • Jul 2012
      • 457
      • Ireland
      Hi kc8adu, that's what would make most sense but Yong never made specific reference to not taking out the diode for the B+ voltage, just not to take ALL of the diodes out at the same time.. I'm a bit confused as to why he wouldnt just say "dont take out the B+ diode".. His English is not great, so maybe that's what he meant to say?
      If you take the example of the SMPS I'm currently working on, I've only two secondary dual schottky diodes, one for the 12V and one for the 5V... So by what is written (literally) in Yong's book, I could take out either and test but just not both.. But there doesnt seem any way that the feedback system wouldnt just shut it down immediately..
        The power supply uses negative feedback system, if the output tries to go up, the feed back (usually through Opto-isolator) will turn the LED in side the Opto (Depends on Current transfer Ratio of the Opto) on more or less which then will turn on the Phototransistor (more or less) to clamp down the drive in the primary side. So if you remove the neagtive feedback the power supply can run away without any regulation, just think of the steam engine with Governor control, without governor, you will have run away train.
        • JonathanAnon
          • Jul 2012
          • 457
          • Ireland
          okay, now that's interesting Bud.. Yong doesnt go hugely in to how the feedback system works. But I assumed that if there was NO feedback at all, that this would be seen as a fault, and the PWM IC would shut down. I guess probably the safest way to verify this would be to remove the feedback resistor and see if it still works.. ?
          You see, Jestine Yong suggests that if you suspect there are problems with the feedback circuit, that you should check the feedback resistors, directly replace the Optocoupler and TL431 etc etc... I'm just wondering why he would suggest going to all this effort if the feedback circuit could simply be temporarily removed from the circuit in the manner we are suggesting..
            I have to say, Jestine is wrong on a lot of things... and this is one thing.
            Feedback is almost always negative in an SMPS... that is, a HIGH signal from the opto tells the power supply the output is too high, and it needs to drop the output. Let's imagine if it were positive... that is a LOW signal from the opto told the SMPS to turn the power supply outputs down. How will the supply start up with no current for the opto? The only way would be an "ignore feedback for N milliseconds" circuit, which has the risk of being wrong under low loads, or insufficient under high loads.
            If you remove the schottky which is used for feedback rail, then the SMPS will go to its maximum output, which will likely lead to damage to the output capacitors and possibly the primary side MOSFET (especially if it is a flyback, as the reflected voltage is proportional to the output voltage.)
            Most SMPS uses more than one rail for feedback, so one diode removal may not be enough to cause it to run out of control.
            If you remove all of them, then of course you have no load to damage the output capacitors, but the SMPS now has an unloaded transformer. What will this do...? Probably very little... I don't anticipate any kind of damage to the drive electronics or the transformer. The Vcc will probably not rise quick enough due to the low load.
            I don't see what removing the diodes does. If you do this, the SMPS will have no function... how will you test it? You can test the diodes out of circuit. If they are shorted, they are bad. If not, they are more than likely fine. I really wouldn't recommend removing a diode and running the supply without it.
            • JonathanAnon
              • Jul 2012
              • 457
              • Ireland
              There's a lot of good information in his books, but I cant understand why he didnt get a fluent English speaker to proofread them!! Loads of grammatical errors in sentences that NEED to be right..
              The idea behind this was that if you suspected that the secondary diodes were failing / leaky under load that this would help to identify the issue.
                Diodes go BANG and they are dead shorted. Leaky is possible but really only with small SMD diodes. The diodes would not fail under load, except to permanently short.
                His English may not be perfect. That is not the issue. I actually mean his tests and so on are not the correct ways to do things, and may mislead you into making the wrong conclusion.
                • smason
                  • 1652
                  Originally posted by JonathanAnon
                  Hi kc8adu, that's what would make most sense but Yong never made specific reference to not taking out the diode for the B+ voltage, just not to take ALL of the diodes out at the same time.. I'm a bit confused as to why he wouldnt just say "dont take out the B+ diode".. His English is not great, so maybe that's what he meant to say?.
                  You should ask him. From what I've read he's pretty responsive to his readers.
                  How's the book? It's one I've considered buying, just never pulled the trigger....
                    B+? Is this for CRTs? Or his name for the PFC/bridge rectifier voltage?
                    • JonathanAnon
                      • Jul 2012
                      • 457
                      • Ireland
                      That's the reason I'm questioning this method in particular, Tom.. Most of the rest of the methods that he suggested make sense... But I thought this just didnt really make sense... I will just NOT use this diode removal method for troubleshooting SMPS.
                      Just looked back through the book and it seems that he is referring to B+ when referring to CRTs.. The term B+ is not actually defined in the book. This is the first reference to the term B+:
                      Each of these AC voltage produced by the secondary windings is then rectified, filtered, and regulated to produce a clean DC voltage. One of the main DC output voltages is the B+ voltage. The output from the B+ voltage supply is then connected, through a sampling error detection circuit and “feedback” loop back to the PWM IC. When the voltage from the B+ supply rises or drop a bit, the PWM IC will act to correct the output.
                      He seems to be referring to CRTs when he does this, so maybe I should stop using this term..
                      • JonathanAnon
                        • Jul 2012
                        • 457
                        • Ireland
                        Originally posted by smason
                        You should ask him. From what I've read he's pretty responsive to his readers. How's the book? It's one I've considered buying, just never pulled the trigger....
                        Yeah I mailed him my own "invention".
                        I couldnt understand why he was removing the main circuit fuse and soldering in a bulb.. instead of using a bulb tested like the one above .. I thought my suggestion was safer and more practical.. He responded with a positive and encouraging email..
                        The book is very easy to read... "accessible" I think is the word they use.. It's well worth a read.. Bit expensive for a download though..
                        • cheapie
                          null
                          • Jul 2010
                          • 849
                          What happens if I yank out the optoisolator, output caps, and rectifiers (bridge them), and turn the transformer around backwards?
                            B+: Usually 100~200V (?) rail in CRT TVs used by the FBT, deflection circuits, and the tube. There is no real equivalent to B+ in modern electronics... maybe 24V on LCD power supply, as it is the most loaded power supply? And Vs on a plasma? Though most modern plasma power supplies split the Vs/Va and logic power.
                            If my calculations are correct, when this baby hits 88 miles per hour... you're gonna see some serious shit.
                            • JonathanAnon
                              • Jul 2012
                              • 457
                              • Ireland
                              I see now that I completely misread Bud's post... I took him to mean that if I disconnected the feedback then the PSU would continue to work fairly normally, much like a plane when the autopilot disengages it would continue to "fly along the same path" .. I have reread the thread and see that this is not the case..
                              • PeteS in CA
                                • Aug 2005
                                • 3583
                                • USA, Unsure of Planet
                                This can be done with circuit branches that don't mess up regulation. You can safely remove -12V and -5V rectifiers. If the +3.3V isn't part of the main regulator loop, its rectifier can safely be removed. In the ATX supplies I worked with ca. 2000, both the +5V and the +12V were sampled for the main regulator loop, so those could not be removed. And having a resistor load rather than a mother board as a load would be advisable (to avoid risk of damage to the mother board).
                                PeteS in CA
                                  Well, technically, it would. For a couple of milliseconds. Its PWM output would then slowly drift upwards, causing the output voltage to skyrocket.
                                  • PeteS in CA
                                    • Aug 2005
                                    • 3583
                                    In principle, running open-loop could end up being benign:
                                    * If you have a resistive load rather than a motherboard;
                                    * If the +3.3V O/P has 6.3V or higher O/P caps;
                                    * If the +5V O/P has 10V or higher O/P caps;
                                    * If the +/-12V O/Ps have 25V or higher O/P caps;
                                    * If the gate/base drive and O/P transformer and O/P inductor cores don't go into saturation at full pulse width.
                                    OTOH, a 4V, 10V or 16V O/P cap on the +3.3V, +5V, or +/-12V O/Ps, respectively, might make an unpleasant noise and emit an unpleasant smell.
                                    If the problem has to do with the regulator circuit not working right - a bad reference, bad divider resistors or bad compensation components - running open-loop won't detect that.
                                    PeteS in CA
                                    • dj8452000
                                      How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                      by dj8452000
                                      I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                      02-18-2025, 08:28 AM
                                    • MalodicOne
                                      macbook pro 820-02100 5v 0 amp
                                      by MalodicOne
                                      Unit came to me and customer said they spilled liquid on it. Opened unit and inspected board and saw no signs on liquid reaching the board. Plugged in amp meter and it pulled 20v and booted normally, i connected to internet and ran update on the OS. Came in the next day to test again to make sure unit was functional, now its stuck at 5v and 0 amps no power, no shorts found on so far.
                                      Tested all CD3217 and RAA489900:
                                      UF400
                                      PP3v3_UPC0_LDO- 3.48v, .473 Diode
                                      PP1v5_UPC0_LDO_CORE- 1.59v, .504 Diode
                                      USBC0_CC1- 0v, .455 Diode
                                      USBC0_CC2- 1.66v, .454 Diode...
                                      07-25-2025, 10:49 AM
                                    • tvguy12012012120
                                      by tvguy12012012120
                                      02-07-2025, 05:13 PM
                                    • asr
                                      Finding replacement diode iPad Pro 3rd gen A1701
                                      by asr
                                      Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                                      Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                                      07-09-2024, 06:24 PM
                                    • chth96
                                      How Can I test PWM DM0365R?
                                      by chth96
                                      Hello
                                      I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                      So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                      I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                      I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                      06-18-2025, 04:14 PM
