Enlight 300W
  • Spacedye69
    • Nov 2005
    • 698
    • US
    Enlight 300W
    I KILLED IT!! A hard drive power plug was loose and shorted, killing the drive and the ps. I opened it up and the fuse was blown. Of course, replacing the fuse, it blew again. Nothing is burned, smells, or looks like it fried. There are small, round blue flat caps marked yc, Y caps? 3 of them and all three read inf resistance. Is this normal for Y caps? X caps read ok, as well as the diodes on the heat sinks. I'm looking for something simple before I pull the tranistors to check them. Seems +12v to gound. Any thoughts?
  • linuxguru
    • Apr 2005
    • 1564
    Re: Enlight 300W
    Hmm, a short from either +12v or +5v to ground in the molex plug probably won't kill the drive, though a short from +12v to +5v probably can - but this is difficult, since they're on opposite sides of the connector. Are you sure the molex wasn't reversed and forced in?
    Of course, if the connector was unplugged and came into contact with the underside of the drive electronics, various failures are possible. But if the fuse blows repeatedly, it's almost certainly a primary-side short, either the switching transistors and/or MOVs and/or bridge rectifier.
    • yanz
      • Nov 2004
      • 910
      Re: Enlight 300W
      i have a cheap psu doing the same symptomp. my friend (an electrician) found out that the culprit are those switching transistors. he said that the fuse isn't for protecting the psu from outside, but to protect the outside from the psu itself. now i know.
      days are so short when you actually do something..
      • Tom41
        • Oct 2005
        • 336
        • England
        Re: Enlight 300W
        Similar thing happened to me; I was trying to power up a CD-ROM drive (old 2x speed drive) by plugging in the molex while the PSU was on. Unfortunately I was trying to insert the plug upside down, and as the pins briefly made contact 12v went into the 5v line - blowing the drive. The PSU survived, but the drive was completely dead. Probably a blown internal fuse, but it's very hard to get to on IDE CD-ROM drives.
        Have you tried more than one replacement fuse? It's possible you tried a defective or wrong rated fuse when you replaced the one in the PSU, causing it to blow again. When replacing fuses, I need at least 3 replacements to blow straight away before concluding that the equipment is faulty
        You know there's something wrong when you open your PC and it has vented Rubycons...
        • starfury1
          • May 2006
          • 1256
          Re: Enlight 300W
          As to caps....low values should read infinite ohms(or there about depending on resistance range and meter)
          The reality they charge up but too quick for any meter to catch
          Those caps would probably fall into this category
          (and probably as you said Y or X Which ever it is type caps)
          Large Electro (as you probably know) will charge up but slower so you can see the charging action.
          So at the beginning consider them a short circuit then as they charge to full they appear (ohms wise) infinite or open circuit.
          Not the voice of experience here and guesstimate on my part.
          If the psu is blowing mains fuses then it must be seeing a short circuit therefore I would follow Linuxgurus advice on it being a primary side failure and as yanz also said most likely the switching fet.
          But check (bridge) rectifier diodes etc
          Since part of the design of a switcher is to keep mains side electrically isolated from the secondary side (part of why they use HF transformer and opto-couplers)
          There is a nice term for this but can't remember what it is.
          I possibly wouldn't rule out a secondary side fault that killed the primary side because of the original short in the molex...
          so would check what you can on that side too
          If you have a fault on the secondary side it may well kill the primary side again.
          Just my thoughts on it and not the expert on these things ...still on the learning curve ok
          HTH
          Yanz ...interesting way of looking at it "fuse blows to protect mains supply from evil of short circuit in psu " I like that
          You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
          • Spacedye69
            • Nov 2005
            • 698
            • US
            Re: Enlight 300W
            Transistor 2sc2625 - 2 of them both read 0 all directions on both resistance and diode - can they both be bad? They are on first heatsink.
            • Spacedye69
              • Nov 2005
              • 698
              • US
              Re: Enlight 300W
              Bridge rectifier test fine.
              • Spacedye69
                • Nov 2005
                • 698
                • US
                Re: Enlight 300W
                Replacements from Mouser are 12A and 100W instead of 10A 80W, but almost $9 each!
                • Spacedye69
                  • Nov 2005
                  • 698
                  • US
                  Re: Enlight 300W
                  MOVs good.
                  • yanz
                    • Nov 2004
                    • 910
                    Re: Enlight 300W
                    your line is better than mine
                    but almost $9 each!
                    holy sh**!
                    • starfury1
                      • May 2006
                      • 1256
                      Re: Enlight 300W
                      both...at $9 US I'd hate to think what I would pay here in oz for them.
                      possible I suppose you could be reading a coil or winding...don't know the circuit but in all directions very much doubt it.
                      I would guess both are cactus pull one and test, then the other
                      If they read zero out of circuit (check to be sure) then they are stuffed.....
                      some what expensive to replace, check as best you can for any other problems
                      you don't want to blow them again.
                      someone here with better experience on this will hopefully post.
                      I would hate to see the new ones get fried
                      Yanz .... thankx U get my PM about pole fuse ?
                      • Spacedye69
                        • Nov 2005
                        • 698
                        • US
                        Re: Enlight 300W
                        They were tested out of circuit. They are FRIED!!! I will be looking around to see if I can get some cheaper. Also, don't the switching tansistors run in parallel? That would explain why they are both dead.
                        • PeteS in CA
                          • Aug 2005
                          • 3580
                          • USA, Unsure of Planet
                          Re: Enlight 300W
                          If the PWM is a TL494 or clone thereof, it's probably a half bridge inverter, which means that they take turns conducting. That said, if one transistor gets zorched without blowing the fuse, the other will quickly get zorched.
                          PeteS in CA
                          • linuxguru
                            • Apr 2005
                            • 1564
                            Re: Enlight 300W
                            Usually when one transistor shorts in a half-bridge, the other will also get fried within a few milliseconds.
                            I just replaced a couple of 2SC2625 primary switchers with a pair of 2SD2498 horizontal-deflection transistors. The specs are slightly different, but it's fine for PSU use up to about 300W - 400W, half-bridge forward, with no modifications to the base-drive circuitry. The D2498 is widely available locally at very reasonable prices - I'd estimate median retail of $2 or lower, for the Toshiba OEM part.
                            The specs of the C2625 are 10A, Vceo 400 V. The replacement D2498 is 6A, Vceo 800 V - I believe it will be more durable in a half-bridge application, even with the lower current rating - Vcbo on the D2498 is 1500 V, which is quite a useful margin for turn-off spikes. hFE(min) seems to be 10 in both cases. The package is slightly different - the D2498 is fully plastic encapsulated and has a lower power dissipation rating of 50W, but that's perfectly fine for this switching application. It's also slightly taller and the position of the leads is offset by about a millimetre wrt to the C2625, so I had to bend the leads and do some mounting adjustments on the heatsink, but it worked out OK for me.
                            I'll doing an in-system test shortly, but I expect no problems. It's running cool as a cucumber with an external dummy load. The PSU is a generic 'PSA 12-300C', which is slightly better than a typical Deer '300 W' unit - this one looks like it's OK for 200W - 250W.
                            • Spacedye69
                              • Nov 2005
                              • 698
                              • US
                              Re: Enlight 300W
                              Thanks for the info. My wife should be having a baby any minute now. After that I can pick up where I left off.
                              • PeteS in CA
                                • Aug 2005
                                • 3580
                                Re: Enlight 300W
                                Another little Elmo? That's great! Congratulations.
                                PeteS in CA
                                • PedroDaGr8
                                  • Oct 2006
                                  • 130
                                  Re: Enlight 300W
                                  His wife is having a baby and he is on here checking about his power supply AHHHHAHAHA
                                  • PeteS in CA
                                    • Aug 2005
                                    • 3580
                                    Re: Enlight 300W
                                    When it comes time for delivery, she will kill him if he does within 10 feet (3 meters) of that computer, .
                                    PeteS in CA
                                    • corrize
                                      A funny fuse story – Lumix LX100 II
                                      by corrize
                                      Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                      I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                      The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                      There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                      And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                      10-19-2023, 09:58 AM
                                    • jesterace
                                      Samsung UE46ES8000 Blown fuse but no other signs of short
                                      by jesterace
                                      Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                      09-11-2024, 03:14 PM
                                    • jshhh
                                      Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                      by jshhh
                                      Hi guys,
                                      I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                      How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                      Anybody know how to remove this type of fuse?
                                      (The fuse is toward the bottom of the image labeled F2)...
                                      06-17-2025, 01:35 AM
                                    • Babbar
                                      by Babbar
                                      04-12-2024, 01:12 AM
                                    • drykid
                                      Matsui 175S microwave fuse replacement
                                      by drykid
                                      I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
                                      Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
                                      12-21-2020, 01:15 PM
