Two dead ATX SMPS's - TL494 and FSP3528 based
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Two dead ATX SMPS's - TL494 and FSP3528 based
    Originally posted by imza
    Hello domas could u give me the spec of two transistor Q1,Q2 at the psu FSP ATX-250PA.
    In post 1 he says:
    Found out that Q2 (please refer to generic schematic of HV side of SMPS here:
    http://www.geocities.ws/luizissao/im...DO_ATX-250.gif ) d304x mosfet was dead/shortened.
    • imza
      • Nov 2014
      • 5
      • malaysia
      i means, this two transistor on this pictures:
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Are yours burnt up are they labelled Q1 and Q2 on the board?
        He says
        Found out that Q2..... ........d304x mosfet was dead/shortened.
        Therefore Q2= D304x
        http://www.alldatasheet.com/view.jsp?Searchword=D304X
        It is implied further down that Q1 and Q2 are the same - If you do not understand I
        will try and explain it
        • imza
          • Nov 2014
          • 5
          • malaysia
          and the value of zinor diod 1-ZD1.
          • imza
            • Nov 2014
            • 5
            • malaysia
            ok, thanks a lot selldoor.. i can't notice it's before.. but with ur explanation i was just realizes.. but how about the value of zinor diod 1-ZD1.. do you know it value.. cause in case i have missing that components.
            • double_DD
              How can I be sure that my EC chip is dead?
              by double_DD
              As the title suggests, how can I be sure that my EC chip is really dead?
              I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
              Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
              03-12-2025, 07:47 AM
            • disorder
              ps5 edm-033 dead after hdmi/usb ports destroyed
              by disorder
              hello guys,
              i need help to repair a edm-033 ps2
              history : as always hdmi port and usb ports destroyed after unplugged
              after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
              so i changed it
              now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
              but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
              i don't see any projection of liquid metal on pcb.
              01-14-2025, 12:48 PM
            • zunasthegreat
              Chieftec GPS-450-AA with dead 20N60C3
              by zunasthegreat
              Hello everyone hope all doing well!
              I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
              09-01-2024, 07:12 PM
            • FiguringITout
              MSI Raider GE75 - Not posting, probable dead CPU
              by FiguringITout
              Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
              Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
              07-25-2024, 07:27 AM
            • Rav_tangle
              MacBook Pro 2011 turns on with keyboard light , screen dead
              by Rav_tangle
              Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
              I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
              Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
              is this...
              05-31-2024, 04:09 PM
