FSP FSp400-60PFi tripping breakers
  • rogfanther
    • Jul 2006
    • 458
    • Brazil
    I was asked to look at said psu. Owner says it is from a industrial pc, and when powered it trips the breaker where the computer is plugged.
    From some similar symptoms in the forum, I believe it could be the pfc part. The diode seems ok, and the coil gives a low resistance. But how can I know if it is the right resistance, or is shorted ? It measures about 1 ohm, but that is already in the range my multimeter hasn“t precision. No ESR meter disponible for a while.
    Can I use a PFC Coil from another psu , at least to test, without fear of damaging it more ? Problem is it has an extra connector, that seems to me to be used for the motherboard monitoring the PSU fam .. to use another psu in its place would need to find a way to fool the mainboard.
    Pics tomorrow,
    Thanks for your input.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: FSP FSp400-60PFi tripping breakers
    Checked the main bridge rectifier? Also, are those pics coming soon?
    Muh-soggy-knee
    • rogfanther
      • Jul 2006
      • 458
      • Brazil
      Checked, but will fully remove the two of them from the board for further testing. Camera decided to stop working, I hope to have it fixed today or tomorrow... thanks.
      • chth96
        How can I test coil whether it is really broken or not?
        by chth96
        I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
        I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
        I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
        I want to replace this round black fuse and unidentified coil if it got broken.
        02-20-2024, 01:07 AM
      • bauto601
        KDM 480W PSU upgrade succes! (opinions?)
        by bauto601
        Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
        A "nice" YoungYear unit? - Badcaps
        The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
        12-26-2023, 03:05 PM
      • waterchill
        What part is this coil from a MacBook A2681 ?
        by waterchill
        Hi everyone
        I'm struggling to point out what part is this? It is a coil, but the parameters say: 10OHM - 50% - 1A - 0.05Ohm
        So it is a coil with 0201 dimensions, 1A max current, 0.05ohm resistance but what is 10ohm? For a coil we need specs like 1uH or so.
        IAny ideas? It is from a MacBook A2681
        Thank you...
        08-08-2024, 01:46 AM
      • Gjackson
        ADP-160FR ps4 slim PSU, shuts down under load and has severe coil whine.
        by Gjackson
        Hi all, the PSU originally had a no 12v issue where as soon as I bridged the 5v standby to the ACDC_stby the psu would switch itself off completely. I monitored the voltage on the main filter caps while doing this and saw that the PFC was bringing the voltage up to around 360vdc before shutting down. Given that I saw that as a little low I replaced the PFC feedback resistors from a donor PSU and that got it to power on, without a load no coil whine is present and there is a stable 12v however as soon as I put it in the PS4 it starts whining really badly, however 12v remains stable but after a...
        01-13-2024, 10:34 AM
      • chth96
        How Can I identify IFT coil?
        by chth96
        I have a CD unit which is came from saturn game console.
        It always perceived Any retail CD or CD-R as Audio-CD.
        Of course I changed laser head and adjust pot of laser head nearby, but It always failed to perceive as saturn game CD.
        I think that this problem probably begins When I tighten IFT coil too hard with small screw driver and suddenly I heard some kind of snap or cracking sound
        I desoldered this IFT coil and It is 7pin IFT coil and written "4120 009 62VK" on the surface.
        Is there any way to identify its frequency in order...
        11-11-2022, 05:31 AM
